Just to realize a share of the problem: do you have the sddm crash after you selected to reboot/shutdown a PC?
I went at least 20 last boots and in every I saw the same: right before to reboot I saw sddm's crashes:
journalctl --unit=sddm.service -r -o short-monotonic --no-host -b -20
Note that -r means reverse order, so last events will be in the top
Try to change -b from -1 and down to some number, do you see the same?
[63243.302832] sddm[533]: Removing display ":0" ...
[63243.300303] sddm[533]: Running display stop script "/usr/share/sddm/scripts/Xstop"
[63243.300155] sddm[533]: Display server stopped.
[63243.122241] systemd[1]: Stopping Simple Desktop Display Manager...
[63243.095363] sddm[533]: Display server stopping...
[63243.095295] sddm[533]: Socket server stopped.
[63243.095222] sddm[533]: Socket server stopping...
[63243.095148] sddm[533]: Auth: sddm-helper exited with 15
[63243.094745] sddm[533]: Authentication error: "Process crashed"
[63243.090574] sddm[533]: Auth: sddm-helper crashed (exit code 15)
[63243.072129] sddm[533]: Authentication error: "Process crashed"
[ 27.678113] sddm[533]: Session started
[ 9083.065847] sddm[587]: Auth: sddm-helper exited with 15
[ 9083.065794] sddm[587]: Authentication error: "Process crashed"
[ 9083.065734] sddm[587]: Auth: sddm-helper crashed (exit code 15)
[ 9083.065443] sddm[587]: Authentication error: "Process crashed"
[ 27.716767] sddm[587]: Session started
Looks like it is an old problem: Using KDE, sddm-helper crashed (exit code 15) during shutdown / Applications & Desktop Environments / Arch Linux Forums
I wonder, how usual is it for us: Does the sddm crash for you?
- Gnome. Almost always.
- Gnome. Rarely.
- KDE. Almost always.
- KDE. Rarely.
- XFCE. Almost always.
- XFCE. Rarely.
- Budgie. Almost always.
- Budgie. Rarely.
- Cinnamon. Almost always.
- Cinnamon. Rarely.
- Deepin. Almost always.
- Deepin. Rarely.
- i3. Almost always.
- i3. Rarely.
- Mate. Almost always.
- Mate. Rarely.
- Sway. Almost always.
- Sway. Rarely.
- A DE on ARM. Almost always.
- A DE on ARM. Rarely.
0 voters
