I have an Akasa hub with SD card and uSD card slots which are not seen. I have tested with different SD cards. The hub also has USB ports which do work (in logs, there is a Kingston USB device)
It was working a week ago, probably before I switched kernel version (to 5.15.21). I have tried with 5.10 with no success.
I have some TIMEDOUT errors:
dmesg | grep usb
[ 1.119189] usb 3-3: New USB device found, idVendor=0951, idProduct=1625, bcdDevice=13.c6
[ 1.119193] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.119195] usb 3-3: Product: DT 101 II
[ 1.119197] usb 3-3: Manufacturer: Kingston
[ 1.119198] usb 3-3: SerialNumber: 0019E06B586BA9A0C2CF0163
[ 1.121869] usb-storage 3-3:1.0: USB Mass Storage device detected
[ 1.121967] scsi host4: usb-storage 3-3:1.0
[ 1.122014] usbcore: registered new interface driver usb-storage
[ 1.173591] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1a.0-1.3/input0
[ 1.175654] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C31C.0002/input/input5
[ 1.186643] usb 1-1.4: new low-speed USB device number 4 using ehci-pci
[ 1.230201] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1a.0-1.3/input1
[ 1.230236] usbcore: registered new interface driver usbhid
[ 1.230237] usbhid: USB HID core driver
[ 1.243305] usb 3-4: new full-speed USB device number 3 using xhci_hcd
[ 1.291312] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[ 1.291316] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.291317] usb 1-1.4: Product: USB Optical Mouse
[ 1.291319] usb 1-1.4: Manufacturer: Logitech
[ 1.293597] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C077.0003/input/input6
[ 1.293678] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1a.0-1.4/input0
[ 1.366638] usb 1-1.5: new high-speed USB device number 5 using ehci-pci
[ 1.416472] usb 3-4: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 1.416476] usb 3-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.682840] usb 1-1.5: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 0.12
[ 1.682845] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 1.682846] usb 1-1.5: SerialNumber: D480A4A0
[ 1.759978] usb 1-1.6: new full-speed USB device number 6 using ehci-pci
[ 1.863419] usb 1-1.6: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 1.863423] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.863425] usb 1-1.6: Product: TTL232R-3V3
[ 1.863427] usb 1-1.6: Manufacturer: FTDI
[ 1.863429] usb 1-1.6: SerialNumber: FTA8DW5O
[ 6.183279] usb 2-1.5: device descriptor read/64, error -110
[ 6.429996] usbcore: registered new interface driver uas
[ 6.673715] usbcore: registered new interface driver btusb
[ 7.178168] usbcore: registered new interface driver ftdi_sio
[ 7.178177] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 7.253526] usb 1-1.6: Detected FT232RL
[ 7.254180] usb 1-1.6: FTDI USB Serial Device converter now attached to ttyUSB0
[ 8.513294] usb 1-1.5: set resolution quirk: cval->res = 384
[ 8.513633] usbcore: registered new interface driver snd-usb-audio
[ 8.550924] input: UVC Camera (046d:0825) as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input20
[ 8.551064] usbcore: registered new interface driver uvcvideo
[ 21.619951] usb 1-1.5: reset high-speed USB device number 5 using ehci-pci
[ 21.753276] usb 2-1.5: device descriptor read/64, error -110
[ 21.936663] usb 2-1.5: new high-speed USB device number 4 using ehci-pci
[ 27.086613] usb 2-1.5: device descriptor read/64, error -110
[ 42.656600] usb 2-1.5: device descriptor read/64, error -110
[ 42.763369] usb 2-1-port5: attempt power cycle
[ 43.356612] usb 2-1.5: new high-speed USB device number 5 using ehci-pci
[ 54.096604] usb 2-1.5: device not accepting address 5, error -110
[ 54.169943] usb 2-1.5: new high-speed USB device number 6 using ehci-pci
[ 64.763305] usb 2-1.5: device not accepting address 6, error -110
[ 64.763582] usb 2-1-port5: unable to enumerate USB device
For informations, here is the result of lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 3: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 4: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 4: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 3: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 5, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 5, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 5: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 5: Dev 5, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 6: Dev 6, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
