Hi. I installed the latest Manjaro Linux 26.1 test version with KDE Plasma. After a while I found out that the Linux kernel does not support scx profiles, so I will not be able to use them in the popular Falcond GUI. Is it specific to this Manjaro test version that the kernel does not support scx? I think that in the stable version of Manjaro, scx worked for me in the Falcond GUI.
Welcome to the forum. What exactly are SCX profiles?
Also this might help.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a
at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
inxi -zv8
I have no idea what exactly those schedulers do and how they are configured, but they certainly seem to be available - for every newer kernel there is an optional dependency scx-scheds. Install it and try again whatever you are trying.
He’ll probably also need to install scx-tools — I haven’t checked the dependency chain, but it’s in the repo. ![]()
scx-tools will install scx-scheds as a dependency:
❯ pamac info scx-tools scx-scheds | grep -Ei 'name|depends'
Depends On : libgcc glibc polkit scx-scheds
Depends On : bash bpf libgcc glibc jq libseccomp libbpf libelf
If I am understanding your topic correct, you can check
$ zcat /proc/config.gz | grep CONFIG_SCHED_CLASS_EXT
CONFIG_SCHED_CLASS_EXT=y
As pointed out by other members you may need to add the necessary tools.
Tweaking kernel parameters for response time consistency - Gaming - ArchWiki
it is recommended to test different schedulers as described in Improving performance#CPU scheduler. For example, the scx_cosmos scheduler from scx-scheds shows promise for improving response time consistency, as it optimizes task-to-CPU locality (enhancing cache hit consistency between runs), reduces locking contention, and is suitable for general usage scenarios, prioritizing interactive tasks under load. Similarly, scx_lavd is specifically optimized for consistent gaming performance. You should test different schedulers to see which is the most successful for your workload.
