Hi,
I have a freshly installed KDE (minimal). The system is fully updated. The scrolling is choppy in all the applications (browsers, file manager etc). When scrolling, it just move some lines in a chunk. I have tried kernel linux54 and 58 and even the latest rc. I appreciate your help for any solution.
System: Kernel: 5.9.0-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=8fc03ec0-d95b-42dc-acbc-721f7abe0d56 rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Vostro 5471 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 08X87Y v: A00 serial: <filter> UEFI: Dell v: 1.15.0 date: 07/03/2020
CPU: Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 8E (142)
stepping: A (10) microcode: D6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 900 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 900 2: 901 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:4 chip ID: 0c45:6a06
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.0-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: e000
bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:3165
IF: wlp2s0 state: down mac: <filter>
Device-3: Samsung GT-I9070 (network tethering USB debugging enabled) type: USB driver: rndis_host bus ID: 1-4:3
chip ID: 04e8:6864 serial: <filter>
IF: enp0s20f0u4 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 698.65 GiB used: 9.54 GiB (1.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SKC2000M8500G size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: S2681102 scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 2B6Q scheme: GPT
Partition: ID-1: / raw size: 30.00 GiB size: 29.40 GiB (98.01%) used: 8.03 GiB (27.3%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /home raw size: 15.00 GiB size: 14.70 GiB (98.01%) used: 1.52 GiB (10.3%) fs: ext4 dev: /dev/nvme0n1p7
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 42.0 C mobo: 38.0 C sodimm: 35.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 225 Uptime: 10m Memory: 15.54 GiB used: 1.12 GiB (7.2%) Init: systemd v: 246 Compilers: gcc: N/A
Packages: pacman: 1038 lib: 286 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
