When playing fullscreen games like TF2 or CSGO, I get somewhat noticeable screen tearing. I don’t really notice in my window manager (budgie in this case) and I’m finding a lot of conflicting information online. If there’s any info I’m missing I can certainly provide it. Thanks!
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.13-x86_64
root=UUID=6ab0c792-bc4f-44d2-ad5b-06077dee7105 rw rootflags=subvol=@ quiet
Desktop: Budgie 10.5.3 info: budgie-panel, vala-panel wm: budgie-wm
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
RAM: total: 15.57 GiB used: 5.71 GiB (36.7%)
Info: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 12 MiB bogomips: 88824
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f07 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: budgie-wm driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 2070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:6 chip-ID: 0c76:605d
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-10:10 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u10 state: up mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4.3:11 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 1.44 TiB used: 381.91 GiB (26.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31000G
type: SSD serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3500G
ID-3: /dev/sdc maj-min: 8:32 type: USB model: N/A size: 14.65 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.00 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
Optical-1: /dev/sr0 vendor: _NEC model: DVD+-RW ND-6650A rev: 102C
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 41.99 GiB size: 41.99 GiB (100.00%) used: 7.04 GiB (16.8%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: MANJARO
uuid: 6ab0c792-bc4f-44d2-ad5b-06077dee7105
ID-2: /boot/efi raw-size: 125 MiB size: 123 MiB (98.44%)
used: 554 KiB (0.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 4C69-5014
ID-3: /home raw-size: 889.4 GiB size: 874.36 GiB (98.31%)
used: 374.87 GiB (42.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: f289b15e-41c3-4baa-a8e3-c22a1d3207cf
ID-4: /var/cache raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
used: 7.04 GiB (16.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: MANJARO
ID-5: /var/log raw-size: 41.99 GiB size: 41.99 GiB (100.00%)
ID-1: /dev/sdc1 maj-min: 8:33 size: 14.62 GiB fs: exfat label: Ventoy
uuid: 3F2B-1B06
ID-2: /dev/sdc2 maj-min: 8:34 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 7506-0A74
ID-3: /dev/sdd1 maj-min: 8:49 size: 58.59 GiB fs: vfat label: N/A
uuid: D9AE-3423
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-1:2 info: Razer USA Razer BlackWidow V3 Tenkeyless
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0a24 class-ID: 0300
Device-2: 1-2:3 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-3: 1-3:4 info: Initio INIC-1511L PATA Bridge type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 2mA
chip-ID: 13fd:1040 class-ID: 0805 serial: <filter>
Hub-2: 1-4:5 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 1-4.1:7 info: Valve Wireless Steam Controller type: Keyboard,HID
driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28de:1142 class-ID: 0300
Device-2: 1-4.2:9 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 058f:6387 class-ID: 0806 serial: <filter>
Device-3: 1-4.3:11 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
Device-4: 1-4.4:12 info: MosArt Wireless Mouse 2.4G type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4106 class-ID: 0301
Device-5: 1-5:6 info: JMTek LLC. JOUNIVO JV605PRO type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:605d class-ID: 0300
serial: <filter>
Device-6: 1-9:8 info: USB Disk 2.0 type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: ffff:5678
Device-7: 1-10:10 info: Realtek RTL88x2bu [AC1200 Techkey] type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 340 Uptime: 41m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1039 lib: 312 Shell: Zsh v: 5.8
running-in: tilix inxi: 3.3.06
