Ok odd title, but the area in the box is brighter. How can I get my screen to look that way by defualt?
Hi @Edward78,
Iâve just checked again to make sure. The section is only brighter because the rest of the screen is dimmer. Or in differently put, that section isnât brighter than usual, the rest of the screen is dimmer.
I mean I want the whole screen to be that bright by default, at all times. It is much easier to see videos and images.
It is already like that. That is your current settings. They only look brighter because the rest of the screen dims, making the contrast greater.
Sorry about that DUG question.
You didnât know, so you asked. Thatâs actually fair.
If you are on the laptop, Plasma supports changing the screen brightness.
If so, check your âSaving energyâ settings and see what level of brightness is set by default for laptop powered with AC or battery and change it to your liking or needs. Of course, it should also work to make it brighter or darker with FN+ specified key (which varies between vendors). Obviously, you canât set it above 100%.
And the name of the effect, Dim Inactive, just confirms my point that itâs not the selection that5âs brighter, but everything else thatâs dimmer.
