Screenshot of the whole screen with Spectacle?
How do I get the whole screen, with mouse pointer, in Spectackle?
Hi @Edward78,
The only way I know how to do this with Spectacle is:
Open your Application launcher and locate Spectacle shortcut. Right-click it to open the context menu and select Launch without taking a screenshot._ The will open the window on the right of the below image.
In that Setting window it allows you to set capture screenshots of the Current screen as well as select the option to capture the mouse pointer, and title bars and borders.
Hope this helps!
ShiftPrint does it for me… but yes, you should just check the settings first.
