Screensharing stopped working after Stable Update 2023-04-11 with Chromium (+Wayland + Pipewire)
I have been using manjaro (i3 edition) for several years now and recently switched to sway edition. I really like this distro and I’m glad I can say, that I haven’t had any real issue in these years (besides minor hickups due to misconfiguration on my side or during system updates) I couldn’t solve.
But after a recent update I ran into an issue, I seem to not be able to solve myself:
I can’t use Screensharing in Chromium (v 112.0.5615.49) anymore after the Stable Update 2023-04-11 :
E.g. in the MS Teams Webapp I can select the option to share an entire screen (and which screen of a multi-screen setup), but only a blank/white image will be transmitted / shown to others. I had this working before the update, therefore I assume something in the update is causing this issue, but I’m out of my depth in finding the actual reason.
My research indicates, that the issue is probly somewhere in the area of:
  • chrmoium 112.0.5615.49
  • wayland 1.22.0-1
  • pipewire 1:0.3.68-1
  • xdg-desktop-portal 1.16.0-1
  • slurp 1.4.0-1
I suspect chromium or pipewire to be the culprit since it was included in the update:
  • chromium: 111.0.5563.64-0.1 → 112.0.5615.49-1
  • pipewire: 1:0.3.65-6 → 1:0.3.68-1
This PipeWire issue describes similar symptoms but didn’t help me and was closed 9 months ago.
Any advice on what I could try or where / how I could find out more?
Some more information & logs:
$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.106-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=a0c78903-3d08-40dd-a117-221346504f1f rw quiet
    cryptdevice=UUID=0f22fe04-e22d-4385-9473-dcec07f15cc1:luks-0f22fe04-e22d-4385-9473-dcec07f15cc1
    root=/dev/mapper/luks-0f22fe04-e22d-4385-9473-dcec07f15cc1 apparmor=1
  Desktop: sway v: 1.8.1 info: waybar vt: 2 dm: greetd Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21A8S0000P v: ThinkPad T15p Gen 2i
  Mobo: LENOVO model: 21A8S0000P v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: N38ET29W (1.10 )
    date: 08/03/2021
  ID-1: BAT0 charge: 63.6 Wh (94.8%) condition: 67.1/68.0 Wh (98.7%)
    volts: 12.8 min: 11.5 model: Celxpert 5B10W13961 type: Li-poly
    serial: <filter> status: not charging cycles: 17
  RAM: total: 31.06 GiB used: 9.74 GiB (31.3%)
  RAM Report: missing: Required tool dmidecode not installed. Check
    --recommends
  Info: model: 11th Gen Intel Core i7-11850H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x42
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 862 high: 1009 min/max: 800/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 955 2: 1009 3: 953 4: 775
    5: 918 6: 809 7: 783 8: 854 9: 996 10: 860 11: 866 12: 798 13: 824 14: 801
    15: 791 16: 801 bogomips: 79888
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: DP-2,HDMI-A-1,eDP-1 empty: DP-1, DP-3, DP-4, DP-5 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA TU117M vendor: Lenovo driver: nouveau v: kernel
    non-free: 530.xx+ status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0302 temp: 36.0 C
  Device-3: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 3-4:6
    chip-ID: 5986:9106 class-ID: 0e02
  Display: wayland server: Xwayland v: 23.1.1 compositor: sway v: 1.8.1
    driver: gpu: i915 d-rect: 5760x2280 display-ID: 1
  Monitor-1: DP-2 pos: primary,top-left model: Lenovo LEN T2454pA
    serial: <filter> built: 2017 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
    scale: 1 size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
    modes: max: 1920x1200 min: 720x400
  Monitor-2: HDMI-A-1 pos: top-right model: Lenovo LEN T24d-10
    serial: <filter> built: 2018 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
  Monitor-3: eDP-1 pos: bottom-c model: ChiMei InnoLux 0x151e built: 2019
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 scale: 1
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl bus-ID: 3-7:10
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 047f:c053 class-ID: 0300 chip-ID: 8086:43c8 class-ID: 0401
    serial: <filter>
  Device-2: Plantronics Blackwire C5220 headset (remote control and 3.5mm
    audio adapter) type: USB driver: plantronics,snd-usb-audio,usbhid
  API: ALSA v: k5.15.106-1-MANJARO status: kernel-api tools: N/A
  Server-3: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15f9 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
    bus-ID: 3-14:15 chip-ID: 8087:0026 class-ID: e001
  Device-1: luks-0f22fe04-e22d-4385-9473-dcec07f15cc1 maj-min: 254:0
    type: LUKS dm: dm-0 size: 275.69 GiB
  Components:
  p-1: nvme1n1p5 maj-min: 259:9 size: 275.69 GiB
  Local Storage: total: 953.88 GiB used: 59.03 GiB (6.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S512G
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: EIFK31.6 temp: 22.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Toshiba model: N/A
    lanes: 4 type: SSD serial: <filter> rev: 5108AGLA temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 275.69 GiB size: 270.3 GiB (98.04%) used: 59.01 GiB (21.8%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-0f22fe04-e22d-4385-9473-dcec07f15cc1 label: N/A
    uuid: a0c78903-3d08-40dd-a117-221346504f1f
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 29.5 MiB (11.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
    label: SYSTEM uuid: 6EE6-2694
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 2A0E-9CF9
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 476.82 GiB fs: bitlocker
  ID-4: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
  ID-5: /dev/nvme1n1p3 maj-min: 259:7 size: 200 GiB fs: bitlocker label: N/A
    uuid: N/A
  ID-6: /dev/nvme1n1p4 maj-min: 259:8 size: 1000 MiB fs: ntfs
    label: WinRE_DRV uuid: 8666E89E66E8906B
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 2-1:2 info: Lenovo USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 17ef:722a class-ID: 0900
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Hub-5: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2811 class-ID: 0900
  Device-1: 3-1.3:12 info: STMicro 84M-RGB type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 200mA
    chip-ID: 0483:4011 class-ID: 0301 serial: <filter>
  Device-2: 3-1.4:14 info: Kensington Orbit Fusion Wireless Trackball
    type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 047d:807b class-ID: 0300
  Device-3: 3-3:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-4: 3-4:6 info: Bison Integrated Camera type: Video driver: uvcvideo
    interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9106
    class-ID: 0e02
  Hub-6: 3-5:7 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
    chip-ID: 17ef:7229 class-ID: 0900
  Device-1: 3-5.4:16 info: wheatek WP17_EEA type: Still Imaging driver: usbfs
    interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 2a96:2008
    class-ID: 0601 serial: <filter>
  Device-2: 3-5.5:11 info: Lenovo USB-C 7-in-1 Hub type: Billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 17ef:722c class-ID: 1100 serial: <filter>
  Device-3: 3-7:10 info: Plantronics Blackwire C5220 headset (remote control
    and 3.5mm audio adapter) type: Audio,HID
    driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 047f:c053 class-ID: 0300
    serial: <filter>
  Device-4: 3-9:13 info: Alcor Micro AU9540 Smartcard Reader type: Smart Card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
    chip-ID: 058f:9540 class-ID: 0b00
  Device-5: 3-14:15 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-7: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
  Hub-8: 4-1:2 info: VIA Labs Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 2109:8110 class-ID: 0900
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 36.0 C
  Fan Speeds (RPM): fan-1: 1978
  Processes: 461 Uptime: 3h 53m wakeups: 23 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1269 libs: 296 tools: pamac,yay Shell: Zsh v: 5.9
  running-in: foot inxi: 3.3.26
$ chromium --profile-directory=Default --app-id=cifhbcnohmdccbgoicgdjpfamggdegmo
# to start ms teams in app chromium
# following lines are repeated like a hundred times, when trying to screen-share
[50430:53089:0414/120400.400977:ERROR:egl_dmabuf.cc(569)] Failed to record frame: Error creating EGLImage - EGL_BAD_ALLOC
[50430:53089:0414/120400.400988:ERROR:shared_screencast_stream.cc(791)] Dropping DMA-BUF modifier: 72057594037927944 and trying to renegotiate stream parameters
$ journalctl -xe | grep pipewire
# following line is reapeated a lot (multiple times per second)
Apr 14 12:04:07 christoph-21a8s0000p pipewire[7600]: invalid memory type 8
$ journalctl -xe | grep wireplumber
# following line is repeated a couple of times
Apr 14 12:04:07 christoph-21a8s0000p wireplumber[7601]: <WpPortalPermissionStorePlugin:0x56072bf15f70> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
$ cat /var/log/pacman.log
...truncated...
[2023-04-12T14:59:50+0200] [PAMAC] synchronizing package lists
[2023-04-12T15:00:01+0200] [ALPM] transaction started
[2023-04-12T15:00:01+0200] [ALPM] upgraded archlinux-keyring (20230130-1 -> 20230320-1)
[2023-04-12T15:00:01+0200] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-04-12T15:00:03+0200] [ALPM-SCRIPTLET] gpg: public key DB323392796CA067 is 3037 days newer than the signature
[2023-04-12T15:00:03+0200] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-04-12T15:00:03+0200] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-07-12
[2023-04-12T15:00:03+0200] [ALPM] upgraded manjaro-keyring (20221028-4 -> 20230318-1)
[2023-04-12T15:00:03+0200] [ALPM-SCRIPTLET] ==> Appending keys from manjaro.gpg...
[2023-04-12T15:00:04+0200] [ALPM-SCRIPTLET] gpg: public key DB323392796CA067 is 3037 days newer than the signature
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] gpg: error reading key: No public key
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET]   -> Locally signed 2 keys.
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] ==> Importing owner trust values...
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET]   -> Disabled 8 keys.
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-07-12
[2023-04-12T15:00:05+0200] [ALPM] upgraded manjaro-system (20221227-1 -> 20230401-1)
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking for 'os-prober' setup ...e[1;0m
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET]     'os-prober' was already enabled by the user.
[2023-04-12T15:00:05+0200] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking if graphic drivers need an update ...e[1;0m
[2023-04-12T15:00:06+0200] [ALPM] transaction completed
[2023-04-12T15:00:06+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-04-12T15:00:07+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T15:01:02+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-04-12T15:01:02+0200] [ALPM] running 'ghc-unregister.hook'...
[2023-04-12T15:01:06+0200] [ALPM] running 'texinfo-remove.hook'...
[2023-04-12T15:01:07+0200] [ALPM] transaction started
[2023-04-12T15:01:07+0200] [ALPM] upgraded adobe-source-code-pro-fonts (2.038ro+1.058it+1.018var-1 -> 2.040u+1.060i+1.024vf-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded alsa-topology-conf (1.2.5.1-1 -> 1.2.5.1-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded iana-etc (20230105-1 -> 20230306-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded filesystem (2023.01.30-1 -> 2023.03.21-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded tzdata (2022g-2 -> 2023c-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded util-linux-libs (2.38.1-1 -> 2.38.1-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded gdbm (1.23-1 -> 1.23-2)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libldap (2.6.3-2 -> 2.6.4-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded audit (3.0.9-2 -> 3.1-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libnsl (2.0.0-2 -> 2.0.0-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded python (3.10.9-1 -> 3.10.10-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded apparmor (3.1.2-1 -> 3.1.3-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded brotli (1.0.9-9 -> 1.0.9-10)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libnghttp2 (1.52.0-1 -> 1.52.0-2)
[2023-04-12T15:01:07+0200] [ALPM] upgraded xz (5.4.1-1 -> 5.4.2-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded zstd (1.5.2-8 -> 1.5.4-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libcap (2.67-1 -> 2.68-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded attr (2.5.1-2 -> 2.5.1-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded coreutils (9.1-3 -> 9.2-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded findutils (4.9.0-2 -> 4.9.0-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded systemd-libs (252.5-1 -> 252.9-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded ca-certificates-mozilla (3.88.1-1 -> 3.89-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded curl (7.87.0-3 -> 8.0.1-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded dbus (1.14.6-1 -> 1.14.6-2)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libsysprof-capture (3.46.0-4 -> 3.48.0-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded glib2 (2.74.5-1 -> 2.76.1-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded device-mapper (2.03.18-5 -> 2.03.20-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded cryptsetup (2.6.1-1 -> 2.6.1-3.1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded hwdata (0.367-1 -> 0.369-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libelf (0.188-3 -> 0.189-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded file (5.44-2 -> 5.44-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded util-linux (2.38.1-1 -> 2.38.1-3)
[2023-04-12T15:01:07+0200] [ALPM] upgraded libnftnl (1.2.4-1 -> 1.2.5-1)
[2023-04-12T15:01:07+0200] [ALPM] upgraded systemd (252.5-1 -> 252.9-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libxau (1.0.11-1 -> 1.0.11-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libxdmcp (1.1.4-1 -> 1.1.4-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libxi (1.8-2 -> 1.8-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded at-spi2-core (2.46.0-2 -> 2.48.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded harfbuzz (7.0.0-1 -> 7.1.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded iso-codes (4.12.0-1 -> 4.13.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gnutls (3.7.9-1 -> 3.8.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libcups (1:2.4.2-5 -> 1:2.4.2-6)
[2023-04-12T15:01:08+0200] [ALPM] upgraded pango (1:1.50.12-1 -> 1:1.50.14-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libjpeg-turbo (2.1.5-2 -> 2.1.5.1-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libtiff (4.5.0-1 -> 4.5.0-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded librsvg (2:2.55.1-1 -> 2:2.56.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gsettings-desktop-schemas (43.0-1 -> 44.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded glib-networking (1:2.74.0-1 -> 1:2.76.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded sqlite (3.40.1-1 -> 3.41.2-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libsoup3 (3.2.2-1 -> 3.4.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded tracker3 (3.4.2-2 -> 3.5.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded wayland (1.21.0-2 -> 1.22.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded hicolor-icon-theme (0.17-2 -> 0.17-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.8.3-3 -> 1:4.10.1-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded lcms2 (2.14-2 -> 2.15-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libdrm (2.4.114-1 -> 2.4.115-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libedit (20210910_3.1-2 -> 20221030_3.1-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded llvm-libs (15.0.7-1 -> 15.0.7-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded vulkan-icd-loader (1.3.240-1 -> 1.3.245-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded mesa (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gtk3 (1:3.24.36-1 -> 1:3.24.37-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded libassuan (2.5.5-1 -> 2.5.5-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded npth (1.6-3 -> 1.6-4)
[2023-04-12T15:01:08+0200] [ALPM] upgraded lib32-openssl (1:3.0.8-0.1 -> 1:3.0.8-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded lib32-libldap (2.6.3-3 -> 2.6.4-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded lib32-libcap (2.67-1 -> 2.68-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gnupg (2.2.40-1 -> 2.2.41-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gpgme (1.18.0-2 -> 1.19.0-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gettext (0.21.1-2 -> 0.21.1-5)
[2023-04-12T15:01:08+0200] [ALPM] upgraded gawk (5.2.1-1 -> 5.2.1-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded grep (3.8-3 -> 3.10-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded sed (4.9-2 -> 4.9-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded python-urllib3 (1.26.12-1 -> 1.26.13-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded python-requests (2.28.1-1 -> 2.28.2-1)
[2023-04-12T15:01:08+0200] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2023-04-12T15:01:08+0200] [ALPM] upgraded pacman (6.0.2-7 -> 6.0.2-10)
[2023-04-12T15:01:08+0200] [ALPM] upgraded appstream-glib (0.8.2-1 -> 0.8.2-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded archlinux-appstream-data (20230115-1 -> 20230220-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded m4 (1.4.19-2 -> 1.4.19-3)
[2023-04-12T15:01:08+0200] [ALPM] upgraded autoconf (2.71-1 -> 2.71-4)
[2023-04-12T15:01:08+0200] [ALPM] upgraded automake (1.16.5-1 -> 1.16.5-2)
[2023-04-12T15:01:08+0200] [ALPM] upgraded babl (0.1.98-1 -> 0.1.102-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded bison (3.8.2-4 -> 3.8.2-5)
[2023-04-12T15:01:08+0200] [ALPM] upgraded btrfs-progs (6.1.3-1 -> 6.2.2-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded bubblewrap (0.7.0-1 -> 0.8.0-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded nftables (1:1.0.6-1 -> 1:1.0.7-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded crun (1.8-1 -> 1.8.3-1)
[2023-04-12T15:01:08+0200] [ALPM] upgraded containers-common (1:0.51.0-1 -> 1:0.51.2-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded skopeo (1.11.0-1 -> 1.11.2-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded buildah (1.29.0-1 -> 1.29.1-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded nss (3.88.1-1 -> 3.89-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded mpg123 (1.31.2-2 -> 1.31.3-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libpulse (16.1-3 -> 16.1-6)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libva (2.17.0-1 -> 2.18.0-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded dav1d (1.0.0-1 -> 1.1.0-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libass (0.17.0-1 -> 0.17.1-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libavc1394 (0.5.4-4 -> 0.5.4-5)
[2023-04-12T15:01:09+0200] [ALPM] installed gperftools (2.10-1)
[2023-04-12T15:01:09+0200] [ALPM] installed highway (1.0.4-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded imath (3.1.6-2 -> 3.1.7-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded openexr (3.1.5-1 -> 3.1.7-1)
[2023-04-12T15:01:09+0200] [ALPM] installed libjxl (0.8.1-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libmfx (23.1.0-1 -> 23.1.3-2)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libsamplerate (0.2.2-1 -> 0.2.2-2)
[2023-04-12T15:01:09+0200] [ALPM] installed portaudio (1:19.7.0-2)
[2023-04-12T15:01:09+0200] [ALPM] installed libopenmpt (0.6.9-2)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libvpx (1.12.0-2 -> 1.13.0-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.240-1 -> 1.3.245-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libusb (1.0.26-1 -> 1.0.26-2)
[2023-04-12T15:01:09+0200] [ALPM] upgraded hidapi (0.13.1-1 -> 0.13.1-2)
[2023-04-12T15:01:09+0200] [ALPM] upgraded sdl2 (2.26.3-1 -> 2.26.4-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded v4l-utils (1.22.1-1 -> 1.24.1-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libgit2 (1:1.5.1-2 -> 1:1.6.3-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded l-smash (2.14.5-2 -> 2.14.5-3)
[2023-04-12T15:01:09+0200] [ALPM] upgraded ffmpeg (2:5.1.2-1 -> 2:6.0-4)
[2023-04-12T15:01:09+0200] [ALPM] upgraded re2 (1:20230201-1 -> 1:20230301-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libice (1.1.1-1 -> 1.1.1-2)
[2023-04-12T15:01:09+0200] [ALPM] upgraded chromium (111.0.5563.64-0.1 -> 112.0.5615.49-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded libwbclient (4.17.5-1 -> 4.18.1-1)
[2023-04-12T15:01:09+0200] [ALPM] upgraded cifs-utils (7.0-2 -> 7.0-3)
[2023-04-12T15:01:09+0200] [ALPM] upgraded ckbcomp (1.212-1 -> 1.215-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded clang (15.0.7-1 -> 15.0.7-2)
[2023-04-12T15:01:10+0200] [ALPM] upgraded cmake (3.25.2-1 -> 3.26.3-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded electron19 (19.1.9-4 -> 19.1.9-5)
[2023-04-12T15:01:10+0200] [ALPM] upgraded code (1.75.1-1 -> 1.77.1-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded conmon (1:2.1.6-1 -> 1:2.1.7-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded cpupower (6.1-1 -> 6.2-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded debugedit (5.0-4 -> 5.0-5)
[2023-04-12T15:01:10+0200] [ALPM] upgraded efivar (38-2 -> 38-3)
[2023-04-12T15:01:10+0200] [ALPM] upgraded efibootmgr (18-1 -> 18-2)
[2023-04-12T15:01:10+0200] [ALPM] upgraded electron17 (17.4.11-5 -> 17.4.11-6)
[2023-04-12T15:01:10+0200] [ALPM] upgraded enchant (2.3.3-2 -> 2.3.4-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded faac (1.30-3 -> 1.30-4)
[2023-04-12T15:01:10+0200] [ALPM] upgraded ffmpegthumbnailer (2.2.2-4 -> 2.2.2-5)
[2023-04-12T15:01:10+0200] [ALPM] upgraded tar (1.34-1 -> 1.34-2)
[2023-04-12T15:01:10+0200] [ALPM] upgraded hwloc (2.8.0-1 -> 2.9.0-1)
[2023-04-12T15:01:10+0200] [ALPM] upgraded openpmix (4.2.3-1 -> 4.2.3-2)
[2023-04-12T15:01:10+0200] [ALPM] upgraded openssh (9.2p1-1 -> 9.3p1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded openmpi (4.1.4-4 -> 4.1.5-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded fftw (3.3.10-3 -> 3.3.10-4)
[2023-04-12T15:01:11+0200] [ALPM] upgraded firefox (111.0-0.1 -> 111.0.1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded flex (2.6.4-4 -> 2.6.4-5)
[2023-04-12T15:01:11+0200] [ALPM] upgraded foot (1.13.1-2 -> 1.14.0-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded foot-terminfo (1.13.1-2 -> 1.14.0-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded freeimage (3.18.0-17 -> 3.18.0-18)
[2023-04-12T15:01:11+0200] [ALPM] upgraded fuse-common (3.13.1-1 -> 3.14.1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded fuse3 (3.13.1-1 -> 3.14.1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded fzf (0.37.0-1 -> 0.39.0-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded galculator (2.1.4-7 -> 2.1.4-8)
[2023-04-12T15:01:11+0200] [ALPM] upgraded luajit (2.1.0.beta3.r467.gd0e88930-1 -> 2.1.0.beta3.r471.g505e2c03-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded poppler (23.02.0-1 -> 23.03.0-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded poppler-glib (23.02.0-1 -> 23.03.0-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded gegl (0.4.40-4 -> 0.4.44-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded libpaper (1.1.28-2 -> 2.0.10-2)
[2023-04-12T15:01:11+0200] [ALPM] upgraded ghostscript (10.0.0-4 -> 10.01.1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded libde265 (1.0.11-1 -> 1.0.11-2)
[2023-04-12T15:01:11+0200] [ALPM] upgraded libheif (1.14.2-1 -> 1.15.2-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded gsfonts (20200910-2 -> 20200910-3)
[2023-04-12T15:01:11+0200] [ALPM] upgraded netpbm (10.73.42-2 -> 10.73.43-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded graphviz (7.1.0-1 -> 8.0.1-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded gimp (2.10.32-3 -> 2.10.34-1)
[2023-04-12T15:01:11+0200] [ALPM] upgraded girara (0.3.7-1 -> 0.4.0-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded git (2.39.2-1 -> 2.40.0-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gitui (0.22.1-1 -> 0.22.1-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded glibmm (2.66.5-1 -> 2.66.6-1)
[2023-04-12T15:01:12+0200] [ALPM] installed libgirepository (1.76.1-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gobject-introspection-runtime (1.74.0-1 -> 1.76.1-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded groff (1.22.4-7 -> 1.22.4-10)
[2023-04-12T15:01:12+0200] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2023-04-12T15:01:12+0200] [ALPM] upgraded grub (2.06.r261.g2f4430cc0-3 -> 2.06.r456.g65bc45963-4)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gstreamer (1.22.0-3 -> 1.22.1-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gst-plugins-base-libs (1.22.0-3 -> 1.22.1-2)
[2023-04-12T15:01:12+0200] [ALPM] installed libpipewire (1:0.3.68-1)
[2023-04-12T15:01:12+0200] [ALPM] installed libcamera-ipa (0.0.4-3)
[2023-04-12T15:01:12+0200] [ALPM] upgraded libcamera (0.0.4-1 -> 0.0.4-3)
[2023-04-12T15:01:12+0200] [ALPM] upgraded pipewire (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded libwireplumber (0.4.13-1 -> 0.4.14-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded wireplumber (0.4.13-1 -> 0.4.14-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded libaio (0.3.113-1 -> 0.3.113-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded thin-provisioning-tools (1.0.1-1 -> 1.0.3-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded lvm2 (2.03.18-5 -> 2.03.20-1)
[2023-04-12T15:01:12+0200] [ALPM] installed libtraceevent (1:1.7.2-1)
[2023-04-12T15:01:12+0200] [ALPM] installed libtracefs (1.6.4-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded ndctl (75-1 -> 76.1-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded liburcu (0.13.2-1 -> 0.14.0-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded xfsprogs (6.1.1-2 -> 6.2.0-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gvfs (1.50.3-1 -> 1.50.4-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded gvfs-mtp (1.50.3-1 -> 1.50.4-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded harfbuzz-icu (7.0.0-1 -> 7.1.0-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-base-orphans (0.8.7-43 -> 0.8.7-50)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-onetuple (0.3.1-50 -> 0.3.1-53)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-splitmix (0.1.0.4-126 -> 0.1.0.4-132)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-random (1.2.1.1-94 -> 1.2.1.1-103)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-quickcheck (2.14.2-396 -> 2.14.2-405)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-data-array-byte (0.1.0.1-5 -> 0.1.0.1-11)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hashable (1.4.2.0-10 -> 1.4.2.0-17)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-primitive (0.7.4.0-61 -> 0.7.4.0-67)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-scientific (0.3.7.0-88 -> 0.3.7.0-91)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-attoparsec (0.14.4-49 -> 0.14.4-52)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-base-compat-batteries (0.12.2-36 -> 0.12.2-42)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-data-fix (0.3.2-77 -> 0.3.2-80)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-dlist (1.0-203 -> 1.0-208)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-generically (0.1-1 -> 0.1.1-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-indexed-traversable (0.1.2-2 -> 0.1.2.1-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-tagged (0.8.6.1-5 -> 0.8.7-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unordered-containers (0.2.19.1-56 -> 0.2.19.1-64)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-vector (0.13.0.0-32 -> 0.13.0.0-39)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-indexed-traversable-instances (0.1.1.1-33 -> 0.1.1.1-44)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-distributive (0.6.2.1-180 -> 0.6.2.1-184)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-comonad (5.0.8-177 -> 5.0.8-182)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-bifunctors (5.5.14-8 -> 5.5.15-3)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-semigroupoids (5.3.7-84 -> 5.3.7-95)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-assoc (1.0.2-176 -> 1.0.2-182)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-these (1.1.1.1-177 -> 1.1.1.1-183)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-semialign (1.2.0.1-100 -> 1.2.0.1-111)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-strict (0.4.0.1-150 -> 0.4.0.1-156)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-text-short (0.1.5-54 -> 0.1.5-57)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-time-compat (1.9.6.1-72 -> 1.9.6.1-75)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-uuid-types (1.0.5-92 -> 1.0.5-95)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-witherable (0.4.2-41 -> 0.4.2-52)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-aeson (2.1.1.0-14 -> 2.1.2.0-8)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-cmdargs (0.10.21-4 -> 0.10.22-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-aeson-pretty (0.8.9-113 -> 0.8.9-127)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-colour (2.3.6-160 -> 2.3.6-166)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-ansi-terminal (0.11.4-15 -> 0.11.4-22)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-ansi-wl-pprint (0.6.9-368 -> 0.6.9-374)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hourglass (0.2.12-221 -> 0.2.12-224)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-memory (0.17.0-42 -> 0.17.0-45)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-asn1-types (0.3.4-182 -> 0.3.4-185)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-asn1-encoding (0.9.6-203 -> 0.9.6-206)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-asn1-parse (0.9.5-203 -> 0.9.5-206)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-async (2.2.4-147 -> 2.2.4-155)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-attoparsec-iso8601 (1.1.0.0-25 -> 1.1.0.0-28)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-auto-update (0.1.6-294 -> 0.1.6-301)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-base16-bytestring (1.0.2.0-55 -> 1.0.2.0-58)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-base64 (0.4.2.4-41 -> 0.4.2.4-44)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-base64-bytestring (1.2.1.0-77 -> 1.2.1.0-80)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-bitvec (1.1.3.0-32 -> 1.1.3.0-45)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-blaze-markup (0.8.2.8-105 -> 0.8.2.8-108)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-blaze-html (0.9.1.2-199 -> 0.9.1.2-202)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-boring (0.2-4 -> 0.2-5)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-bsb-http-chunked (0.0.0.4-338 -> 0.0.0.4-345)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-call-stack (0.4.0-135 -> 0.4.0-141)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-case-insensitive (1.2.1.0-178 -> 1.2.1.0-181)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-data-default-instances-dlist (0.0.1-281 -> 0.0.1-286)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-data-default (0.7.1.1-268 -> 0.7.1.1-273)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-syb (0.7.2.2-25 -> 0.7.2.3-3)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-pandoc-types (1.23-3 -> 1.23-16)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-text-icu (0.8.0.2-24 -> 0.8.0.2-27)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-th-lift (0.8.2-13 -> 0.8.3-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-th-lift-instances (0.1.20-20 -> 0.1.20-24)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unicode-collation (0.1.3.3-15 -> 0.1.3.4-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-uniplate (1.6.13-172 -> 1.6.13-181)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-split (0.2.3.5-21 -> 0.2.3.5-24)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-vector-algorithms (0.9.0.1-32 -> 0.9.0.1-45)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-mono-traversable (1.0.15.3-109 -> 1.0.15.3-122)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-resourcet (1.2.6-26 -> 1.2.6-29)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-conduit (1.3.4.3-24 -> 1.3.4.3-38)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-network (3.1.2.7-53 -> 3.1.2.8-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-zlib (0.6.3.0-35 -> 0.6.3.0-38)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-streaming-commons (0.2.2.5-11 -> 0.2.2.5-15)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-typed-process (0.2.10.1-30 -> 0.2.11.0-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-conduit-extra (1.3.6-56 -> 1.3.6-71)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-xml-conduit (1.9.1.1-170 -> 1.9.1.2-5)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-citeproc (0.8.1-6 -> 0.8.1-25)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unicode-data (0.4.0.1-8 -> 0.4.0.1-11)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unicode-transforms (0.4.0.1-45 -> 0.4.0.1-48)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-commonmark (0.2.2-32 -> 0.2.2-35)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-emojis (0.1.2-49 -> 0.1.2-52)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-th-compat (0.1.4-18 -> 0.1.4-21)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-network-uri (2.6.4.2-5 -> 2.6.4.2-8)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-commonmark-extensions (0.2.3.3-16 -> 0.2.3.4-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-commonmark-pandoc (0.2.1.3-4 -> 0.2.1.3-18)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-socks (0.6.1-207 -> 0.6.1-211)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-cryptonite (0.30-46 -> 0.30-49)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-pem (0.2.4-259 -> 0.2.4-262)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-x509 (1.7.7-32 -> 1.7.7-35)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-x509-store (1.6.9-57 -> 1.6.9-60)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-x509-validation (1.6.12-62 -> 1.6.12-65)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-tls (1.6.0-29 -> 1.6.0-33)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-x509-system (1.6.7-60 -> 1.6.7-63)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-connection (0.3.1-231 -> 0.3.1-235)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-constraints (0.13.4-24 -> 0.13.4-27)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-dec (0.0.5-1 -> 0.0.5-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-digest (0.0.1.5-1 -> 0.0.1.7-1)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-doclayout (0.4-27 -> 0.4-31)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-text-conversions (0.3.1.1-36 -> 0.3.1.1-39)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-doctemplates (0.11-3 -> 0.11-16)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-easy-file (0.2.2-19 -> 0.2.3-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unix-compat (0.6-50 -> 0.6-61)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-unix-time (0.4.8-17 -> 0.4.9-2)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-fast-logger (3.1.2-2 -> 3.1.2-15)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-glob (0.10.2-65 -> 0.10.2-68)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-gridtables (0.1.0.0-14 -> 0.1.0.0-18)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-haddock-library (1.10.0-197 -> 1.10.0-215)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-lua (2.2.1-25 -> 2.2.1-28)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-core (2.2.1-39 -> 2.2.1-51)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-marshalling (2.2.1-33 -> 2.2.1-45)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-aeson (2.2.1-29 -> 2.2.1-43)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-classes (2.2.0-45 -> 2.2.0-57)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-objectorientation (2.2.1-29 -> 2.2.1-41)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-packaging (2.2.1-25 -> 2.2.1-37)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua (2.2.1-28 -> 2.2.1-42)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-list (1.1.0.1-3 -> 1.1.1-7)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-doclayout (1.0.4-78 -> 1.0.4-92)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-path (1.0.3-37 -> 1.0.3-51)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-temporary (1.3-506 -> 1.3-516)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-system (1.0.2-33 -> 1.0.3-12)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-text (1.0.3.1-5 -> 1.0.3.1-17)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-version (1.0.3-34 -> 1.0.3-48)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-zip-archive (0.4.2.2-17 -> 0.4.3-4)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hslua-module-zip (1.0.0-3 -> 1.0.0-20)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-types (0.12.3-287 -> 0.12.3-298)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-api-data (0.5-20 -> 0.5.1-5)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-iproute (1.7.12-53 -> 1.7.12-57)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-client (0.7.13.1-36 -> 0.7.13.1-48)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-client-tls (0.3.6.1-80 -> 0.3.6.1-92)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-date (0.0.11-111 -> 0.0.11-114)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-utf8-string (1.0.2-125 -> 1.0.2-128)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http-media (0.8.0.0-180 -> 0.8.0.0-183)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-network-byte-order (0.1.6-153 -> 0.1.6-156)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-psqueues (0.2.7.3-57 -> 0.2.7.3-60)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-time-manager (0.0.0-291 -> 0.0.0-298)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-http2 (3.0.3-22 -> 3.0.3-38)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-hunit (1.6.2.0-177 -> 1.6.2.0-183)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-ipynb (0.2-75 -> 0.2-88)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-jira-wiki-markup (1.5.0-2 -> 1.5.0-5)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-juicypixels (3.3.8-6 -> 3.3.8-9)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-libyaml (0.1.2-278 -> 0.1.2-292)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-lpeg (1.0.3-24 -> 1.0.3-27)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-transformers-base (0.4.6-77 -> 0.4.6-80)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-monad-control (1.0.3.1-77 -> 1.0.3.1-80)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-optparse-applicative (0.17.0.0-34 -> 0.17.0.0-41)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting-core (0.13.2.1-1 -> 0.13.2.1-17)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting-format-ansi (0.1-36 -> 0.1-52)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting-format-blaze-html (0.1.1-32 -> 0.1.1-48)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting-format-context (0.1.0.2-1 -> 0.1.0.2-17)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting-format-latex (0.1-36 -> 0.1-52)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-skylighting (0.13.2.1-2 -> 0.13.2.1-18)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-tagsoup (0.14.8-201 -> 0.14.8-204)
[2023-04-12T15:01:12+0200] [ALPM] upgraded haskell-texmath (0.12.6-1 -> 0.12.6-14)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-yaml (0.11.10.0-2 -> 0.11.11.0-10)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-pandoc (3.0.1-3 -> 3.0.1-32)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-pandoc-lua-marshal (0.2.0-3 -> 0.2.1-3)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-pandoc-lua-engine (0.1-7 -> 0.1-40)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-some (1.0.4.1-1 -> 1.0.5-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-singleton-bool (0.1.6-7 -> 0.1.6-9)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-string-conversions (0.4.0.1-146 -> 0.4.0.1-149)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-vault (0.3.1.5-135 -> 0.3.1.5-143)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-servant (0.19.1-18 -> 0.19.1-33)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-wai (3.2.3-173 -> 3.2.3-185)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-wai-logger (2.4.0-195 -> 2.4.0-233)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-recv (0.1.0-1 -> 0.1.0-5)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-simple-sendfile (0.2.30-339 -> 0.2.30-354)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-safe-exceptions (0.1.7.3-33 -> 0.1.7.3-36)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-unliftio (0.2.23.0-11 -> 0.2.24.0-2)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-warp (3.3.24-1 -> 3.3.25-6)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-wai-extra (3.1.13.0-44 -> 3.1.13.0-82)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-wai-app-static (3.1.7.4-113 -> 3.1.7.4-132)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-servant-server (0.19.2-23 -> 0.19.2-44)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-wai-cors (0.2.7-290 -> 0.2.7-302)
[2023-04-12T15:01:13+0200] [ALPM] upgraded haskell-pandoc-server (0.1-9 -> 0.1-43)
[2023-04-12T15:01:13+0200] [ALPM] upgraded hdf5 (1.12.2-1 -> 1.14.0-2)
[2023-04-12T15:01:13+0200] [ALPM] upgraded hslua-cli (1.2.0-3 -> 1.2.0-15)
[2023-04-12T15:01:13+0200] [ALPM] upgraded vigra (1.11.1.r67+g093d57d1-6 -> 1.11.1.r67+g093d57d1-8)
[2023-04-12T15:01:13+0200] [ALPM] upgraded libnotify (0.8.1-1 -> 0.8.2-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded hugin (2022.0.0-3 -> 2022.0.0-5)
[2023-04-12T15:01:13+0200] [ALPM] upgraded imlib2 (1.10.0-3 -> 1.11.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded inetutils (2.3-1 -> 2.4-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded inotify-tools (3.22.6.0-1 -> 3.22.6.0-2)
[2023-04-12T15:01:13+0200] [ALPM] upgraded intel-ucode (20221108-1 -> 20230214-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded libbpf (1.0.1-1 -> 1.1.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded iproute2 (6.1.0-5 -> 6.2.0-2)
[2023-04-12T15:01:13+0200] [ALPM] upgraded libwacom (2.6.0-1 -> 2.6.0-2)
[2023-04-12T15:01:13+0200] [ALPM] upgraded libinput (1.22.1-1 -> 1.23.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded qt5-base (5.15.8+kde+r181-1 -> 5.15.8+kde+r185-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded kcoreaddons (5.103.0-1 -> 5.104.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded kauth (5.103.0-1 -> 5.104.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded kitemmodels (5.103.0-1 -> 5.104.0-1)
[2023-04-12T15:01:13+0200] [ALPM] upgraded kwindowsystem (5.103.0-1 -> 5.104.0-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lapce (0.2.5-1 -> 0.2.7-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lmdb (0.9.30-2 -> 0.9.30-3)
[2023-04-12T15:01:14+0200] [ALPM] upgraded ldb (2:2.6.1-2 -> 2:2.7.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-libpsl (0.21.1-3 -> 0.21.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-zstd (1.5.2-1 -> 1.5.4-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-curl (7.87.0-1 -> 8.0.1-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-libdrm (2.4.114-1 -> 2.4.115-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-xz (5.4.1-1 -> 5.4.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-libelf (0.188-1 -> 0.189-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-libx11 (1.8.3-1.1 -> 1.8.4-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-mesa (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-mesa-vdpau (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-systemd (252.5-1 -> 252.9-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-vulkan-intel (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded vulkan-radeon (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded lib32-vulkan-radeon (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libatomic_ops (7.6.14-1 -> 7.8.0-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libhandy (1.8.1-1 -> 1.8.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded liblc3 (1.0.1-1 -> 1.0.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libmad (0.15.1b-9 -> 0.15.1b-10)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libmanette (0.2.6-3 -> 0.2.6-4)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libmm-glib (1.20.4-1 -> 1.20.6-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libmpdclient (2.20-2 -> 2.20-3)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libnm (1.42.2-0 -> 1.42.4-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded libnsgif (0.2.1-7 -> 0.2.1-8)
[2023-04-12T15:01:14+0200] [ALPM] warning: /etc/pamac.conf installed as /etc/pamac.conf.pacnew
[2023-04-12T15:01:14+0200] [ALPM] upgraded libpamac (11.4.1-3 -> 11.5.2-1)
[2023-04-12T15:01:14+0200] [ALPM] upgraded zxing-cpp (2.0.0-1 -> 2.0.0-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded raptor (2.0.15-21 -> 2.0.16-2)
[2023-04-12T15:01:14+0200] [ALPM] upgraded rasqal (1:0.9.33-5 -> 1:0.9.33-6)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libreoffice-fresh (7.5.0-1 -> 7.5.2-1)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libsynctex (2022.62885-3 -> 2023.66539-1)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libva-mesa-driver (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libwpe (1.14.1-1 -> 1.14.1-2)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libx86emu (3.5-2 -> 3.5-3)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libxaw (1.0.14-1 -> 1.0.15-1)
[2023-04-12T15:01:15+0200] [ALPM] upgraded xorg-fonts-encodings (1.0.6-1 -> 1.0.7-1)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libxfont2 (2.0.6-1 -> 2.0.6-2)
[2023-04-12T15:01:15+0200] [ALPM] upgraded libxvmc (1.0.13-1 -> 1.0.13-2)
[2023-04-12T15:01:15+0200] [ALPM] upgraded licenses (20220125-1 -> 20220125-2)
[2023-04-12T15:01:15+0200] [ALPM] upgraded linux-firmware-whence (20230210.bf4115c-1 -> 20230310.588dd07-1)
[2023-04-12T15:01:18+0200] [ALPM] upgraded linux-firmware (20230210.bf4115c-1 -> 20230310.588dd07-1)
[2023-04-12T15:01:18+0200] [ALPM] upgraded mkinitcpio (34-1.1 -> 35.2-2)
[2023-04-12T15:01:19+0200] [ALPM] upgraded linux515 (5.15.102-1 -> 5.15.106-1)
[2023-04-12T15:01:19+0200] [ALPM] upgraded llvm (15.0.7-1 -> 15.0.7-2)
[2023-04-12T15:01:19+0200] [ALPM] upgraded make (4.4-1 -> 4.4.1-2)
[2023-04-12T15:01:19+0200] [ALPM] upgraded mako (1.7.1-2 -> 1.7.1-3)
[2023-04-12T15:01:19+0200] [ALPM] upgraded man-pages (6.02-1 -> 6.04-1)
[2023-04-12T15:01:19+0200] [ALPM] upgraded manjaro-release (22.0.5-1 -> 22.1.0-1)
[2023-04-12T15:01:19+0200] [ALPM] upgraded zsh-theme-powerlevel10k (1.17.0-1 -> 1.17.0+23+g1cff2249-1)
[2023-04-12T15:01:19+0200] [ALPM] upgraded manjaro-zsh-config (0.24-3 -> 0.25-1)
[2023-04-12T15:01:19+0200] [ALPM] upgraded matcha-gtk-theme (20221115-1 -> 20230403-1)
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET]
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET] To force Libadwaita appliations to use the gtk-4.0 theme,
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET] symlink the gtk-4.0 theme to config folder
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET] (replace Matcha-dark-sea with chosen theme variant):
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET] mkdir -p ~/.config/gtk-4.0/
[2023-04-12T15:01:19+0200] [ALPM-SCRIPTLET] ln -sf /usr/share/themes/Matcha-dark-sea/gtk-4.0/{assets,gtk.css,gtk-dark.css} ~/.config/gtk-4.0/
[2023-04-12T15:01:19+0200] [ALPM] upgraded menu-cache (1.1.0-3 -> 1.1.0-4)
[2023-04-12T15:01:19+0200] [ALPM] upgraded mesa-vdpau (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:20+0200] [ALPM] upgraded meson (1.0.0-2 -> 1.0.1-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mhwd-nvidia (525.89.02-1 -> 530.41.03-4)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mhwd-nvidia-390xx (390.157-1 -> 390.157-5)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mhwd-nvidia-470xx (470.161.03-2 -> 470.182.03-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mhwd-db (0.6.5-23 -> 0.6.5-25)
[2023-04-12T15:01:20+0200] [ALPM] upgraded perl-http-daemon (6.14-2 -> 6.16-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mhwd (0.6.5-23 -> 0.6.5-25)
[2023-04-12T15:01:20+0200] [ALPM] upgraded smbclient (4.17.5-1 -> 4.18.1-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded openal (1.23.0-1 -> 1.23.0-2)
[2023-04-12T15:01:20+0200] [ALPM] upgraded mplayer (38407-1 -> 38412-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded pcsclite (1.9.9-2 -> 1.9.9-3)
[2023-04-12T15:01:20+0200] [ALPM] upgraded networkmanager (1.42.2-0 -> 1.42.4-2)
[2023-04-12T15:01:20+0200] [ALPM] upgraded p7zip (1:17.04-4 -> 1:17.05-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded pamac-cli (10.4.3-3 -> 10.5.0-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded pamac-gtk (10.4.3-3 -> 10.5.0-1)
[2023-04-12T15:01:20+0200] [ALPM] upgraded pandoc-cli (0.1-9 -> 0.1-47)
[2023-04-12T15:01:23+0200] [ALPM] upgraded papirus-icon-theme (20230104-1 -> 20230301-1)
[2023-04-12T15:01:23+0200] [ALPM] installed libmysofa (1.3.1-2)
[2023-04-12T15:01:23+0200] [ALPM] upgraded tinycompress (1.2.8-1 -> 1.2.8-2)
[2023-04-12T15:01:23+0200] [ALPM] upgraded pipewire-audio (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:23+0200] [ALPM] upgraded pipewire-alsa (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:23+0200] [ALPM] upgraded pipewire-pulse (1:0.3.65-6 -> 1:0.3.68-1)
[2023-04-12T15:01:23+0200] [ALPM] upgraded pkgconf (1.8.0-1 -> 1.8.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded podman (4.4.1-2 -> 4.4.4-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded polkit-gnome (0.105-9 -> 0.105-10)
[2023-04-12T15:01:24+0200] [ALPM] upgraded vulkan-headers (1:1.3.240-1 -> 1:1.3.246-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded qt6-translations (6.4.2-1 -> 6.4.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded qt6-base (6.4.2-1 -> 6.4.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded qt6-declarative (6.4.2-1 -> 6.4.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded shiboken6 (6.4.2-5 -> 6.4.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded pyside6 (6.4.2-5 -> 6.4.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-cryptography (39.0.1-1 -> 40.0.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-fastjsonschema (2.16.2-1 -> 2.16.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-gobject (3.42.2-1 -> 3.44.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-more-itertools (9.0.0-1 -> 9.1.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-jaraco.functools (3.5.2-1 -> 3.6.0-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-numpy (1.24.1-1 -> 1.24.2-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-wheel (0.38.4-1 -> 0.40.0-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-pip (23.0-1 -> 23.0.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-typing_extensions (4.4.0-1 -> 4.5.0-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-platformdirs (2.6.2-1 -> 3.1.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-pydantic (1.10.4-1 -> 1.10.7-2)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-trove-classifiers (2023.2.8-1 -> 2023.3.9-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-validate-pyproject (0.12.1-1 -> 0.12.2-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-setuptools (1:67.3.0-1 -> 1:67.6.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded python-xlib (0.31-4 -> 0.33-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded qt5-wayland (5.15.8+kde+r58-1 -> 5.15.8+kde+r63-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded qt5ct (1.5-2 -> 1.7-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded xxhash (0.8.1-3 -> 0.8.1-4)
[2023-04-12T15:01:24+0200] [ALPM] upgraded rsync (3.2.7-3 -> 3.2.7-4)
[2023-04-12T15:01:24+0200] [ALPM] upgraded seatd (0.7.0-2 -> 0.7.0-3)
[2023-04-12T15:01:24+0200] [ALPM] upgraded sudo (1.9.12.p2-2 -> 1.9.13.p3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded swayr (0.24.0-2 -> 0.24.1-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded sworkstyle (1.3.2-3 -> 1.3.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded systemd-sysvcompat (252.5-1 -> 252.9-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded texinfo (7.0.2-2 -> 7.0.3-1)
[2023-04-12T15:01:24+0200] [ALPM] upgraded texlive-bin (2022.62885-3 -> 2023.66539-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded vim-runtime (9.0.1302-1 -> 9.0.1420-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded vim (9.0.1302-1 -> 9.0.1420-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded vulkan-intel (22.3.5-1 -> 23.0.2-2)
[2023-04-12T15:01:25+0200] [ALPM] installed gssdp (1.6.2-1)
[2023-04-12T15:01:25+0200] [ALPM] installed gupnp (1:1.6.3-1)
[2023-04-12T15:01:25+0200] [ALPM] installed gupnp-igd (1.2.0-3)
[2023-04-12T15:01:25+0200] [ALPM] installed libnice (0.1.21-1)
[2023-04-12T15:01:25+0200] [ALPM] installed gst-plugins-bad-libs (1.22.1-2)
[2023-04-12T15:01:25+0200] [ALPM] upgraded wpebackend-fdo (1.14.0-1 -> 1.14.2-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded webkit2gtk (2.38.4-1 -> 2.40.0-2)
[2023-04-12T15:01:25+0200] [ALPM] upgraded wf-recorder (0.3.0-2 -> 0.3.0-5)
[2023-04-12T15:01:25+0200] [ALPM] upgraded wireless-regdb (2022.08.12-1 -> 2023.02.13-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded wl-clipboard (1:2.1.0-2 -> 1:2.1.0-3)
[2023-04-12T15:01:25+0200] [ALPM] upgraded xcursor-breeze (5.24.6-1 -> 5.27.3-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded xf86-video-amdgpu (22.0.0-1 -> 23.0.0-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded xorg-setxkbmap (1.3.3-1 -> 1.3.3-2)
[2023-04-12T15:01:25+0200] [ALPM] upgraded xorg-server-common (21.1.7-1 -> 21.1.8-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded xorg-xwayland (22.1.8-1 -> 23.1.1-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded yay (11.3.2-1 -> 12.0.3-1)
[2023-04-12T15:01:25+0200] [ALPM] upgraded zathura (0.5.1-1 -> 0.5.2-2)
[2023-04-12T15:01:25+0200] [ALPM] upgraded zathura-pdf-poppler (0.3.0-1 -> 0.3.1-2)
[2023-04-12T15:01:25+0200] [ALPM] transaction completed
[2023-04-12T15:01:27+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2023-04-12T15:01:27+0200] [ALPM] running '30-systemd-catalog.hook'...
[2023-04-12T15:01:27+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-04-12T15:01:27+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '30-update-mime-database.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '40-update-ca-trust.hook'...
[2023-04-12T15:01:28+0200] [ALPM] running '60-depmod.hook'...
[2023-04-12T15:01:33+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img --microcode /boot/intel-ucode.img
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET] ==> Starting build: '5.15.106-1-MANJARO'
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-04-12T15:01:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-04-12T15:01:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-04-12T15:01:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-04-12T15:01:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-04-12T15:01:34+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-04-12T15:01:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [encrypt]
[2023-04-12T15:01:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-04-12T15:01:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-04-12T15:01:36+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-04-12T15:01:36+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET] ==> Starting build: '5.15.106-1-MANJARO'
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-04-12T15:01:37+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-04-12T15:01:38+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-04-12T15:01:38+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-04-12T15:01:38+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-04-12T15:01:38+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-04-12T15:01:38+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-04-12T15:01:39+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-04-12T15:01:40+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-04-12T15:01:41+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-04-12T15:01:41+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-04-12T15:01:41+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-04-12T15:01:41+0200] [ALPM-SCRIPTLET]   -> Running build hook: [encrypt]
[2023-04-12T15:01:43+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-04-12T15:01:43+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-04-12T15:01:46+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-04-12T15:01:47+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
[2023-04-12T15:01:50+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-04-12T15:01:50+0200] [ALPM] running '99-grub.hook'...
[2023-04-12T15:01:50+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-04-12T15:01:51+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2023-04-12T15:01:51+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2023-04-12T15:01:51+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2023-04-12T15:01:51+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-04-12T15:01:51+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme1n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2023-04-12T15:01:53+0200] [ALPM-SCRIPTLET] done
[2023-04-12T15:01:53+0200] [ALPM] running 'dbus-reload.hook'...
[2023-04-12T15:01:53+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2023-04-12T15:01:53+0200] [ALPM] running 'fontconfig.hook'...
[2023-04-12T15:01:53+0200] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2023-04-12T15:01:53+0200] [ALPM] running 'ghc-register.hook'...
[2023-04-12T15:01:58+0200] [ALPM] running 'gio-querymodules.hook'...
[2023-04-12T15:01:58+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2023-04-12T15:01:58+0200] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2023-04-12T15:01:58+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-04-12T15:02:01+0200] [ALPM] running 'gvfsd.hook'...
[2023-04-12T15:02:01+0200] [ALPM] running 'networkmanager-connectivity.hook'...
[2023-04-12T15:02:01+0200] [ALPM] running 'texinfo-install.hook'...
[2023-04-12T15:02:02+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-04-12T15:02:02+0200] [ALPM] running 'vimdoc.hook'...
[2023-04-12T15:02:12+0200] [ALPM] transaction started
[2023-04-12T15:02:12+0200] [ALPM] upgraded trilium-bin (0.59.2-1 -> 0.59.3-1)
[2023-04-12T15:02:12+0200] [ALPM] transaction completed
[2023-04-12T15:02:12+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T15:02:12+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-04-12T15:06:23+0200] [PAMAC] synchronizing package lists
[2023-04-12T15:06:34+0200] [ALPM] transaction started
[2023-04-12T15:06:34+0200] [ALPM] installed libgtop (2.40.0+2+g31db82ef-2)
[2023-04-12T15:06:34+0200] [ALPM] installed whois (5.5.16-1)
[2023-04-12T15:06:34+0200] [ALPM] installed gnome-nettool (42.0-1)
[2023-04-12T15:06:34+0200] [ALPM] installed lua53 (5.3.6-1)
[2023-04-12T15:06:34+0200] [ALPM] installed nmap (7.93-1)
[2023-04-12T15:06:34+0200] [ALPM] installed libmaxminddb (1.7.1-1)
[2023-04-12T15:06:34+0200] [ALPM] installed jemalloc (1:5.3.0-1)
[2023-04-12T15:06:34+0200] [ALPM] installed bind (9.18.13-1)
[2023-04-12T15:06:34+0200] [ALPM] installed net-tools (2.10-2)
[2023-04-12T15:06:34+0200] [ALPM] transaction completed
[2023-04-12T15:06:34+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2023-04-12T15:06:34+0200] [ALPM-SCRIPTLET] Creating group 'named' with GID 40.
[2023-04-12T15:06:34+0200] [ALPM-SCRIPTLET] Creating user 'named' (BIND DNS Server) with UID 40 and GID 40.
[2023-04-12T15:06:34+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running 'texinfo-install.hook'...
[2023-04-12T15:06:34+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-04-12T17:21:28+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux61'
[2023-04-12T17:21:31+0200] [ALPM] transaction started
[2023-04-12T17:21:31+0200] [ALPM] installed linux61 (6.1.23-1)
[2023-04-12T17:21:31+0200] [ALPM] transaction completed
[2023-04-12T17:21:31+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T17:21:31+0200] [ALPM] running '60-depmod.hook'...
[2023-04-12T17:21:32+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.23-1-MANJARO'
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-04-12T17:21:32+0200] [ALPM-SCRIPTLET]   -> Running build hook: [encrypt]
[2023-04-12T17:21:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-04-12T17:21:33+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-04-12T17:21:33+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-04-12T17:21:33+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.1.23-1-MANJARO'
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-04-12T17:21:34+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-04-12T17:21:35+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET]   -> Running build hook: [encrypt]
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-04-12T17:21:36+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-04-12T17:21:37+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-04-12T17:21:37+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-04-12T17:21:42+0200] [ALPM] running '99-grub.hook'...
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.15-x86_64
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-04-12T17:21:42+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-04-12T17:21:43+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/efi/Microsoft/Boot/bootmgfw.efi
[2023-04-12T17:21:43+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme1n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2023-04-12T17:21:43+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-04-12T17:21:43+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-04-12T17:21:43+0200] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2023-04-12T17:21:44+0200] [ALPM-SCRIPTLET] done
[2023-04-12T23:05:46+0200] [PAMAC] synchronizing package lists
[2023-04-12T23:05:50+0200] [ALPM] transaction started
[2023-04-12T23:05:51+0200] [ALPM] upgraded firefox (111.0.1-1 -> 112.0-1)
[2023-04-12T23:05:51+0200] [ALPM] transaction completed
[2023-04-12T23:05:51+0200] [ALPM] running '30-systemd-update.hook'...
[2023-04-12T23:05:51+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-04-12T23:05:51+0200] [ALPM] running 'update-desktop-database.hook'...
...truncated...
I found a reddit post, which helped: It mentioned an xdg-desktop-portal-wlr issue #266 which is supposedly fixed in xdg-desktop-portal-wlr v.0.7.0.
A comment in the reddit post suggests to install xdg-desktop-portal-wlr-git from AUR (which is currently at v0.7.0.r0.g776113a-1).
This seems to be the current solution, since xdg-desktop-portal-wlr is at version 0.6.0-1 in the official repositires (community).
After installing xdg-desktop-portal-wlr-git and rebooting, screensharing is working again now. Once xdg-desktop-portal-wlr v0.7.0 becomes available in the official repositories I will try to switch back.
thanks for this! Having the same issue and will give this a try.
