When I am lazy and do not turn off my computer at night, the screensaver kicks in after 10 minutes and “turn off” the monitor (blackens the screen).
However, often when I wake up in the middle of the night, I can see that the screen has turned on again, so some application must be turning it on again. Either that or I have ghosts in my apartment and they play with the mouse at night. My guess (an hope) is that an application is to blame…
Anyone recognize this “problem”?
If there's something strange
In your neighborhood
Who you gonna call?
Ghostbusters!
Inxi -Fayz
Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=fee91cd0-20ad-4ba6-b478-14e2982762a4 rw quiet apparmor=1
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.23 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop System: Inet_AB product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x serial: <filter>
UEFI [Legacy]: American Megatrends v: 2006 date: 11/13/2019
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
L2 cache: 3072 KiB
bogomips: 86268
Speed: 2792 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2792 2: 2141 3: 2393 4: 3007 5: 2041 6: 2291 7: 2349 8: 2200 9: 3218
10: 2184 11: 2090 12: 2264
conditional, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 08:00.0
chip ID: 1002:67df
Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.0x11.2")
s-diag: 1550mm (61")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 82
Monitor-3: DVI-D-0 res: 1920x1080 hz: 60 dpi: 82
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.35.0
5.4.80-2-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus ID: 08:00.1
chip ID: 1002:aaf0
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0a:00.4 chip ID: 1022:1487
Device-3: Logitech Logitech BRIO type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 4-4:2
chip ID: 046d:085e serial: <filter>
Sound Server: ALSA v: k5.4.80-2-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 07:00.0
chip ID: 10ec:8168
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.40 TiB used: 1.36 TiB (39.9%)
ID-1: /dev/sda vendor: Toshiba model: TR200 size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 15.3
scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD20EZRZ-00Z5HB0
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-4: /dev/sdd vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
rev: 3B6Q scheme: MBR
ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 201.97 GiB (22.1%) fs: ext4 dev: /dev/sdd1
System Temperatures: cpu: 50.8 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 820
Processes: 359 Uptime: 2d 15h 21m Memory: 31.36 GiB used: 9.51 GiB (30.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1285 pacman: 1282
lib: 366 flatpak: 0 snap: 3 Shell: Bash v: 5.0.18 running in: gnome-terminal
inxi: 3.1.08
