I have been trying to get an old and underpowered windows tablet to work:
terra mobile 1062
Intel Atom x5-Z8350
Intel integrated graphics
When installing cinnamon or any other DE with the lightDM diplay manger the installation works fine.
On Gnome however the screens remains active for about 5 seconds until turning off. I can then unlock the screen for another 5 seconds and so on. This is regardless of power settings or what I do.
For Plasma it does not even turn on after the login screen.
This issue is happening regardless of distro.
For Gnome: it works flawless on the live-system and only turns unusable after hard installing.
The screen is not recognized at all. However the touch recognition always works.
External screens that are connected via mini hdmi do not have this issue and stay activated.
If you wish support you need to disclose essentials of your system by posting output of
inxi -Fza
Maybe you are lacking of RAM.
Thank you This is the output when botted from a mint live usb
Kernel: 5.15.0-91-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
parameters: BOOT_IMAGE=/casper/vmlinuz boot=casper username=mint
hostname=mint quiet splash --
Desktop: Cinnamon 6.0.4 tk: GTK 3.24.33 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Detachable System: Wortmann_AG product: 1220551;1470050
v: 1062-DE-10401 serial: <superuser required> Chassis: WISKY type: 32
Mobo: WISKY model: F1T serial: <superuser required>
UEFI: American Megatrends v: 5.11 date: 04/20/2018
ID-1: axp288_fuel_gauge charge: 75% condition: N/A volts: 4.1 min: N/A
model: N/A type: Li-ion serial: N/A status: Charging
Info: model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont family: 6
model-id: 0x4C (76) stepping: 4 microcode: 0x411
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1671 high: 1845 min/max: 480/1920 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1845 2: 1823 3: 1503
4: 1514 bogomips: 11520
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
driver: i915 v: kernel ports: active: DSI-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b0
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1280 s-dpi: 96 s-size: 508x338mm (20.0x13.3")
s-diag: 610mm (24")
Monitor-1: DSI-1 res: 1920x1280 hz: 60 size: N/A modes: 1920x1280
OpenGL: renderer: Mesa Intel HD Graphics (CHV)
v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
Imaging Unit
driver: N/A alternate: atomisp bus-ID: 00:03.0 chip-ID: 8086:22b8
class-ID: 0480
Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
bus-ID: 1-4:3 chip-ID: 8087:0a2a class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2 sub-v: 1000 hci-v: 4.2 rev: 1000
Info: acl-mtu: 1021:5 sco-mtu: 96:6 link-policy: rswitch hold sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 172.84 GiB used: 3 MiB (0.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: HP model: DF4064
size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: N/A size: 1.87 GiB used: 21 MiB (1.1%) fs: overlay
source: ERR-102
ID-2: /var/log raw-size: 111.74 GiB size: 109.43 GiB (97.93%)
used: 3 MiB (0.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 271 Uptime: 4m wakeups: 13 Memory: 3.75 GiB
used: 1.11 GiB (29.6%) Init: systemd v: 249 runlevel: 5 tool: systemctl
Compilers: gcc: 11.4.0 alt: 11/12 Packages: apt: 2120 lib: 1034 flatpak: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
satsuma:
Memory: 3.75 GiB
Here we are, 4GiB is small, not necessary too small but a reason to choose a distro with small RAM consumption.
Goddamnit
well… Thank you for your time : )
Appreciate it
system
Closed
27 June 2024 08:25
6
