Screen wakes up immediately after an automatic turn off screen
Hello. A few days ago, I changed from Windows to Mnajaro, so I’m sorry if I don’t understand some things.
I set up the power management settings to turn off the screen after 10 minutes, but I have a problem that immediately after the screen turns off, it turns right back on, I tried doing xset dpms force off to make sure it isn’t the keyboard or the mouse, after that i wanted to get more information about what is coursing the problem I did journalctl -f, but I’m not sure what it means, I wanted to know if any of you have any idea what is causing the issue ?
Jan 17 22:08:15 <Username Filtered> kernel: amdgpu 0000:0c:00.0: [drm] REG_WAIT timeout 1us * 100 tries - dcn32_program_compbuf_size line:139
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15212010
Jan 17 22:08:21 <Username Filtered> VirtualBox[4359]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  85
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Property:  "EDID"
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         State (newValue, Deleted):  1
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_OutputChange
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15173620
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  79
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  98
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Connection:  "Disconnected"
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Subpixel Order:  0
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRScreenChangeNotify
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Config_timestamp:  15212077
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Window: 44040198
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Root: 996
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size ID: 65535
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size:  4480 1440
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         SizeMM:  1185 381
Jan 17 22:08:21 <Username Filtered> plasmashell[1263]: kde.plasmashell: requesting unexisting screen available rect -1
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 85 update
        m_connected: 0
        m_crtc XRandRCrtc(0x5e06ee0fbf30)
        CRTC: 79
        MODE: 98
        Connection: 1
Jan 17 22:08:21 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 85 : connected = false , enabled = true
        m_connected: 1
        CRTC: 79
        MODE: 98
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Emitting configChanged()
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandR::setConfig
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Requested screen size is QSize(2560, 1440)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Needed CRTCs:  1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Actions to perform:
        Priorities: false
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Change Screen Size: true
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                 Old: QSize(4480, 1440)
        Intermediate: QSize(4480, 1440)
        New: QSize(2560, 1440)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Disable outputs: true
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                  QList(85)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Change outputs: true
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                  QList(83)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Enable outputs: false
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetCrtcConfig (disable output)
        CRTC: 79
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Result: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 85 update
        m_connected: 1
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Disconnected output 85 from CRTC 79
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetCrtcConfig (change output)
        Output: 83 ( "DisplayPort-1" )
        CRTC: 78
        Pos: QPoint(0,0)
        Mode: KScreen::Mode(Id: "88" , Size: QSize(2560, 1440) @ 239.998 ) Preferred: "87"
        Rotation: KScreen::Output::None
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  78  m_timestamp update  15173614  =>  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Result:  0  timestamp:  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 83 update
        m_connected: 0
        m_crtc XRandRCrtc(0x5e06ee0f88c0)
        CRTC: 78
        MODE: 88
        Connection: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetOutputPrimary
        New priority: 0
        New priority: 1
        New priority: 0
        New priority: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetScreenSize
        DPI: 96
        SizeMM: QSize(677, 381)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandR::setConfig done!
Jan 17 22:08:22 <Username Filtered> VirtualBox[4359]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:22 <Username Filtered> VirtualBox[3233]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:22 <Username Filtered> VirtualBox[2464]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_CrtcChange
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15173620
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  79
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Geometry:  0 0 0 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_OutputChange
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  85
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Connection:  "Disconnected"
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Subpixel Order:  0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRScreenChangeNotify
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Config_timestamp:  15212077
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Window: 44040198
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Root: 996
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size ID: 65535
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size:  4480 1440
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         SizeMM:  1185 381
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15212777
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  78
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  88
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Geometry:  0 0 2560 1440
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Connection:  "Connected"
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Config_timestamp:  15213011
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size ID: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size:  2560 1440
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         SizeMM:  677 381
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  80
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  81
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  82
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  83
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  84
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 85 : connected = false , enabled = false
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  78  m_configTimestamp update 15173620  =>  15212777
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 0
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: Failed to focus 0x4203565 (error 3)
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 85 : connected = true , enabled = false
        m_connected: 0
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  78  m_configTimestamp update 15212777  =>  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  79  m_configTimestamp update 15173620  =>  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  80  m_configTimestamp update 15173620  =>  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  81  m_configTimestamp update 15173620  =>  15212778
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 82 update
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 82 : connected = false , enabled = false
        m_connected: 0
        CRTC: 78
        MODE: 88
        Connection: 0
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 83 : connected = true , enabled = true
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 84 update
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:22 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 84 : connected = false , enabled = false
        m_connected: 0
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 0
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28373, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28376, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28377, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28393, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28396, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 28397, resource id: 69219685, major code: 129 (SHAPE), minor code: 3 (Combine)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 30842, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 30843, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 30844, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:22 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 30990, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Emitting configChanged()
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandR::setConfig
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Requested screen size is QSize(4480, 1440)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Needed CRTCs:  2
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Actions to perform:
        Priorities: true
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Output 85
        Old: "0"
        New: "2"
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Change Screen Size: true
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                 Old: QSize(2560, 1440)
        New: QSize(4480, 1440)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Disable outputs: false
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Change outputs: true
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                  QList(83)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Enable outputs: true
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:                  QList(85)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetScreenSize
        DPI: 96
        SizeMM: QSize(1185, 381)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetCrtcConfig (change output)
        CRTC: 78
        Pos: QPoint(1920,0)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  78  m_timestamp update  15212778  =>  15213831
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Result:  0  timestamp:  15213831
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 83 update
        m_connected: 0
        CRTC: 78
        MODE: 88
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: QMap((78, XRandRCrtc(0x5e06ee0f88c0))(79, XRandRCrtc(0x5e06ee0fbf30))(80, XRandRCrtc(0x5e06ee0fbd70))(81, XRandRCrtc(0x5e06ee0fbec0)))
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Testing CRTC 78
        Free: false
        Mode: 88
        Possible outputs: QList(82, 83, 84, 85)
        Connected outputs: QList(83)
        Geometry: QRect(1920,0 2560x1440)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Testing CRTC 79
        Free: true
        Mode: 0
        Connected outputs: QList()
        Geometry: QRect(0,360 0x0)
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetCrtcConfig (enable output)
        Output: 85 ( "HDMI-A-1" )
        New CRTC: 79
        Pos: QPoint(0,360)
        Mode: KScreen::Mode(Id: "98" , Size: QSize(1920, 1080) @ 60 ) Preferred: "98"
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  79  m_timestamp update  15173620  =>  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr:         Result:  0  timestamp:  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 85 update
        m_connected: 0
        m_crtc QObject(0x0)
        CRTC: 79
        MODE: 98
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Connected output 85 to CRTC 79
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: RRSetOutputPrimary
        New priority: 0
        New priority: 1
        New priority: 0
        New priority: 2
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandR::setConfig done!
Jan 17 22:08:23 <Username Filtered> VirtualBox[3233]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:23 <Username Filtered> VirtualBox[2464]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:23 <Username Filtered> VirtualBox[4359]: Qt WARNING: TGAHandler::canRead() error while reading the header
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRScreenChangeNotify
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15212778
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Config_timestamp:  15213011
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Window: 44040198
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Root: 996
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Rotation:  "Rotate_0"
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size ID: 65535
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Size:  4480 1440
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         SizeMM:  1185 381
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_CrtcChange
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  78
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  88
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Geometry:  1920 0 2560 1440
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15213831
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  79
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  98
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Geometry:  0 360 1920 1080
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper: RRNotify_OutputChange
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  85
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Connection:  "Connected"
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Subpixel Order:  0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Timestamp:  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  80
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Mode:  0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Geometry:  0 0 0 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  81
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  82
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         CRTC:  0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Connection:  "Disconnected"
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  83
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xcb.helper:         Output:  84
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  79  m_configTimestamp update 15212778  =>  15213831
        m_connected: 0
        CRTC: 79
        MODE: 98
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 85 : connected = true , enabled = true
        m_connected: 0
        CRTC: 79
        MODE: 98
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  78  m_configTimestamp update 15212778  =>  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  79  m_configTimestamp update 15213831  =>  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  80  m_configTimestamp update 15212778  =>  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandRCrtc  81  m_configTimestamp update 15212778  =>  15213837
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 82 update
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 82 : connected = false , enabled = false
        m_connected: 0
        CRTC: 78
        MODE: 88
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 83 : connected = true , enabled = true
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: XRandROutput 84 update
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
Jan 17 22:08:23 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Output 84 : connected = false , enabled = false
        m_connected: 0
        CRTC: 79
        MODE: 98
        Connection: 0
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
        m_connected: 0
        CRTC: 78
        MODE: 88
        Connection: 0
        m_connected: 1
        m_crtc QObject(0x0)
        CRTC: 0
        MODE: 0
        Connection: 1
        m_connected: 0
        CRTC: 79
        MODE: 98
        Connection: 0
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 35046, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 35048, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 35049, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 35050, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 35051, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38327, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38328, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38329, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38331, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38332, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38334, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:23 <Username Filtered> kwin_x11[1203]: kwin_core: XCB error: 3 (BadWindow), sequence: 38335, resource id: 0, major code: 129 (SHAPE), minor code: 8 (GetRectangles)
Jan 17 22:08:24 <Username Filtered> kscreen_backend_launcher[1396]: kscreen.xrandr: Emitting configChanged()
hardware:
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=758f6a05-9345-46d8-ab6e-c034d9a3d2bf rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_x11 tools: avail: xfce4-screensaver vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F37a
    date: 02/16/2022
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3653 min/max: 550/4651 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3653 2: 3653 3: 3653
    4: 3653 5: 3653 6: 3653 7: 3653 8: 3653 9: 3653 10: 3653 11: 3653 12: 3653
    bogomips: 88845
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
    XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1
    bus-ID: 0c:00.0 chip-ID: 1002:747e class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,top-right
    model: Gigabyte M27Q X serial: <filter> built: 2022 res: N/A dpi: 109
    gamma: 1.2 size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9
    modes: max: 2560x1440 min: 640x480
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: bottom-l model: BenQ RL2455
    serial: <filter> built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
    ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
    surfaces: xcb,xlib
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Audio-Technica AT2020USB+
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 0909:001c class-ID: 0300
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:1528 class-ID: 0200
  IF: enp5s0f0 state: down mac: <filter>
  Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
  IF: enp5s0f1 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
  Local Storage: total: 6.37 TiB used: 156.37 GiB (2.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 43.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 156.37 GiB (8.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
  System Temperatures: cpu: 41.4 C mobo: 30.0 C gpu: amdgpu temp: 55.0 C
    mem: 67.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Memory: total: 32 GiB available: 31.27 GiB used: 10.51 GiB (33.6%)
  Processes: 334 Power: uptime: 4h 43m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1678 pm: pacman pkgs: 1672 libs: 495 tools: pamac,yay pm: flatpak
    pkgs: 6 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Wow, journalctl certainly is getting a lot of spam from X11 right there
  • perhaps it might be an idea to try logging in a Wayland session to see if the same happens.
  • Try creating a new user to see if it happens there too.
Also, maybe a less spammy journalctl:
journalctl -p3 -xb --no-hostname
Apart from this, rather than doing xset dpms force off I actually turn off my mouse before triggering suspend to avoid waking it up again…
Then, just to eliminate any kernel worries it might be a plan to boot Linux 6.6 to see if that clears it.
Hey Ben, changing from X11 to Wayland seems to have solved the issue :smiley:
Thank you for your help. That problem has been driving me mad
Sure, join the club
:crazy_face:
