Screen turns black whenever I try to switch users
Hello same problem here, the screen just turns black whenever I try to switch users, I can’t even restart or shutdown the system I have to press ctrl+alt+fx in order to be able to restart or shutdown the system. Is this a KDE bug?
BTW “start new session” is able in both users.
Welcome to the Manjaro community @tutan_kbron.
I have moved your post to a new support topic.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
Be prepared to provide more information and outputs from other commands when asked.
I will provide the info as soon as I get home, however I think It’s the same problem/topic described here: System freezes when switching users - #12 by soundofthunder
First I made sure Start with an empty session option was enabled
However As NickTouik described is his post
  1. Logging in as user A.
  2. As user A, switch user → Brought to the login screen → Select and log in as user B.
  3. black screen.
  4. Press ctrl-alt-F1 or F2 and It takes some time to be able to log in in terminal session… sometime its not even possible and I have to press different Fx keys to switch back to user A and try to restart or shutdown the system, if it’s not frozen
    I can log in perfectly with user A or B, the problem is when I try to switch between users. I don’t know if my english let me explain the problem clearly
It looks like this might indeed be the result of a KDE bug, as mentioned by @Aragorn in the previous thread.
Good news: The KDE bug seems to have been fixed.
  • 500038 Attempting to switch user via Kicker caused Plasma Shell to crash
Bad news: It’s fixed in Plasma 6.4.0 – you might have to wait a little bit longer before you can reap the benefit.
In the meantime, I suggest using the workarounds mentioned in the thread you referenced; it’s only a temporary inconvenience.
The commit from KDE for anyone interested;
I just want to report that I currently have plasma-desktop 6.5.4-1 installed and user switching is still broken.
@tutan_kbron
@NickTouik
ReuseSession=false (default) is a setting in sddm.conf – it should ideally allow creating a new session, but instead, it causes Plasma to display a black screen. User switching therefore fails.
At this time, creating two concurrent sessions is explicitly unsupported by KDE, and they have no intention of changing that – this means that user switching will inevitably fail.
However, there is some light on the horizon.
The much anticipated KDE Login Manager destined to replace SDDM will not expose ReuseSession= to the user at all – instead, it will always default to re-use the session.
TL/DR: User switching will work with KDE Login Manager.
It’s only a question of how long we must wait for Arch to adopt the KDE Login Manager, and for it to then trickle through both the Arch and Manjaro branches; it could take a while.
Fedora 44 is the first distribution to adopt the KDE Login Manager, but that won’t be until sometime in April – when that time comes, you might like to download their ISO and experiment with it in a VM.
That’s likely the best I can suggest in the meantime.
