Screen tearing using Gnome and Nvidia (proprietary)
Hello, I’m using Manjaro with the proprietary drivers and I’m having screen tearing. My laptop is a Lenovo Legion Y740. I don’t have this screen tearing using Windows so I don’t think this is a hardware problem. I’ve tried using nvidia-settings and setting Force composition pipeline and Force full composition pipeline to no avail.
Here’s the output of my inxi -Fazy
  Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=759c5942-a42f-4370-bfe8-fa4cfa3281e8 rw quiet splash apparmor=1
  security=apparmor resume=UUID=781fe0ae-7244-4c2d-b4e0-3ef218bf3d2a
  udev.log_priority=3
  Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
  serial: <filter> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
  UEFI [Legacy]: LENOVO v: BVCN11WW(V1.07) date: 07/04/2019
  ID-1: BAT1 charge: 48.6 Wh condition: 48.6/57.4 Wh (85%) volts: 12.9/11.6
  model: Celxpert L17C3PG2 type: Li-ion serial: <filter> status: Full
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
  L2 cache: 12.0 MiB
  bogomips: 62431
  Speed: 4229 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4319 2: 4469
  3: 4388 4: 4446 5: 4403 6: 4409 7: 4236 8: 4249 9: 4400 10: 4264 11: 4253
  12: 4354
  Type: l1tf
  Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
  driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
  chip ID: 10de:1f51
  Device-2: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo
  bus ID: 1-7:5 chip ID: 04f2:b604 serial: <filter>
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia
  resolution: <xdpyinfo missing>
  OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:a348
  Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
  Sound Server: ALSA v: k5.9.11-3-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak]
  vendor: Bigfoot Networks Killer driver: iwlwifi v: kernel bus ID: 00:14.3
  chip ID: 8086:a370
  vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 3f:00.0
  chip ID: 10ec:8168
  IF: enp63s0 state: down mac: <filter>
  IF-ID-1: br-6d3840142d80 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  Local Storage: total: 953.87 GiB used: 21.66 GiB (2.3%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HALR-000L2
  size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 5L1QEXA7 scheme: MBR
  ID-1: / raw size: 919.45 GiB size: 904.02 GiB (98.32%)
  used: 21.66 GiB (2.4%) fs: ext4 dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 42 C
  Processes: 299 Uptime: 14m Memory: 31.28 GiB used: 3.67 GiB (11.7%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1270 pacman: 1263
  lib: 346 flatpak: 0 snap: 7 Shell: Zsh v: 5.8 running in: java inxi: 3.1.08
Also my /etc/X11/xorg.conf file
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 455.45.01
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "BOE Technology Group Co., Ltd"
    HorizSync       164.0 - 164.0
    VertRefresh     143.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce RTX 2060"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-5"
    Option         "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Any help is appreciated
Manjaro uses MHWD hence the proper configuration is in /etc/X11/mhwd.d/nvidia.conf
Remove the /etc/X11/xorg.conf and paste this content in the proper file location:
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    VertRefresh     143.0
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Once you save it, run this command from terminal:
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
Reboot the system after that and report back.
In addition to what @anon89812132 said above you might try to use {ForceFullCompositionPipeline=On} instead of {ForceCompositionPipeline=On} in that config.
Never used GNOME however, turning on vsync under compositor in KDE solves tearing. Maybe there is similar setting in GNOME too?
Hello! I just did it and tried also with ForceFullCompositionPipeline but the problem persists specially when I use Pycharm for some reason.
Do you know if there’s any other debugging information I can send to troubleshoot this issue?
I’ve been looking for this, but I can’t seem to find it!
I am a really nutcase ignorant when it comes to the configuration of iNvidia.
I have found the nvidia-settingsapp to be of great help. Setup your config - save it in your home - backup the mhwd confguration - then overwrite your mhwd config with the generated config and reboot.
Maybe this approach works for you too.
Yeah, I tried with different configurations but the flickering persists. Specially if I use something like pycharm or when watching a full screen video.
I’ve seen people reporting similar problems on Windows when using NVIDIA’s latest driver on the same laptop model that I have lenovo y740 screen flickering after driver update-English Community
