Hey all, I have some seriously bad screen tearing issues on Manjaro Gnome.
Using the video-hybrid-intel-nvidia-prime driver from mhwd. Using the latest LTS kernel and using.
Other things, my GPU is a NVIDIA GeForce RTX 2070 SUPER Mobile and my CPU is Intel i7-10750H (12) @ 5.000GHz.
How can I fix the screen tearing issue? Only things I found on Google or on the Arch Wiki seem to be related to the ordinary nvidia-4xx drivers and which I don’t have the options on installing besides, i like having the hybrid graphics option . I’ve tried those options but they have caused issues like no booting.Anyone have any ideas? I’ve considered switching to Wayland but I rely heavily on Wine/Proton for gaming so currently that isn’t an option.
This?
Basically adding the tearfree option for Intel, as it is Intel that renders your video (and you offload on-demand on Nvidia card some work for gaming or whatever, but it still is Intel which displays video from my understanding, with the hybrid driver).
I’ve tried this option but afterwards I couldn’t boot my system anymore, it would just freeze before loading GDM the user login screen .
I don’t own a laptop and can’t access hybrid laptop currently to check, but it shouldn’t forbid you to boot if you add this option to your xorg config file.
Option "TearFree" "true"
Just tried this option again and still wouldn’t load GDM. I can use Crt-Alt F2 to get into a second tty session and login without a DE but that’s it.
Where/how do you add this option exactly in detail?
Following the Arch wiki guide I put it in /etc/X11/xorg.conf.d/20-intel.conf and copy the following into it.
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
EndSection
Is there a different location I should be putting this in?
That is what I wonder, but as I told you I do not have a laptop with Prime on hand currently to check. In the folder etc/X11/ if you already have configuration files there it may be the place, but I can’t tell you which file sorry.
No worries, cheers for your input though.
I do have a 90-mhwd.conf file in /etc/X11/xorg.conf.d however it’s just filled with the following and nothing else
'## Generated by mhwd - Manjaro Hardware Detection
Going to try pasting it in here and seeing the results.
Pasting it all into 90-mhwd.conf caused the same issue.
omano
5 May 2021 01:27
12
Can you give full inxi output?
inxi -Fazy
This is the output without any X11 modifications.
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=1e76304c-c2d9-4915-b8f2-3b3bc641fa30 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=b996df8a-0e33-4fb9-9a8e-79145e767d3b udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Micro-Star product: GS66 Stealth 10SFS v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16V1 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16V1IMS.106 date: 03/11/2020
ID-1: BAT1 charge: 48.7 Wh (77.1%) condition: 63.2/95.0 Wh (66.5%)
volts: 15.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Charging
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
cache: L2: 12 MiB
bogomips: 62399
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e91
class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3 chip-ID: 8086:06f0
class-ID: 0280
Device-2: Intel driver: igc v: kernel port: 3000 bus-ID: 3c:00.0
chip-ID: 8086:3100 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 280.22 GiB (29.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: EXA7301Q temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 935.94 GiB size: 935.94 GiB (100.00%)
used: 280.22 GiB (29.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 954 MiB size: 952.1 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 935.94 GiB size: 935.94 GiB (100.00%)
ID-1: swap-1 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 320 Uptime: 5m wakeups: 1 Memory: 15.46 GiB
used: 2.47 GiB (16.0%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1190 lib: 322 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
omano
5 May 2021 01:47
14
I found a thread with exact same problem, as soon as you add configs for Intel you can not boot to desktop How to Fix Intel Screen Tearing on Xfce
The guy fixed his issue in the windows manager settings, but it was for XFCE not GNOME.
Maybe you have some options somewhere in GNOME where you could enable some kind of sync/buffer/whatever it could be.
I don’t use GNOME so I can’t really help for that.
Cheers mate, can’t find anything in the Gnome Settings GUI or Gnome Tweaks but I’ll do a bit of research online after work and see if I can find anything relating to sync/buffer settings for Gnome.
Cheers mate!
