Hello everyone
First of all, new design is awesome!! I’ve been waiting to post here
I wanted to change xscreen settings to get rid of screen tearing because that’s so annoying when playing games
But strangely, there is NO xscreen
Also my nvidia.conf in /etc/X11/mhwd.d/
is empty
My specs:
System: Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: KDE Plasma 5.19.3
tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A serial: <root required>
Chassis: type: 10 serial: <root required>
Mobo: HP model: 87B1 v: 31.17 serial: <root required> UEFI: AMI v: F.02 date: 05/14/2020
Battery: ID-1: BAT0 charge: 34.0 Wh condition: 52.1/52.1 Wh (100%) volts: 11.4/11.6
model: Hewlett-Packard Primary type: Li-ion serial: status: Discharging cycles: 469
CPU: Topology: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71895
Speed: 1395 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1394 2: 1394 3: 1395
4: 1397 5: 1575 6: 2027 7: 1394 8: 1394 9: 1397 10: 1397 11: 1397 12: 1397
Graphics: Device-1: NVIDIA vendor: Hewlett-Packard driver: nvidia v: 440.100 bus ID: 01:00.0 chip ID: 10de:1f99
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:1636
Display: x11 server: X.Org 1.20.8 driver: amdgpu,nvidia FAILED: ati unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.37.0 5.7.9-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.1.3
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A bus ID: 05:00.5 chip ID: 1022:15e2
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.9-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169
v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
IF: eno1 state: down mac: b0:5c:da:42:34:3f
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_pci v: N/A port: d000 bus ID: 03:00.0 chip ID: 10ec:c822
IF: wlo1 state: up mac: 70:66:55:bb:04:b7
Drives: Local Storage: total: 2.74 TiB used: 1.13 TiB (41.3%)
ID-1: /dev/nvme0n1 model: KBG40ZNV512G KIOXIA size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: 306PEEC9PBV1 rev: HP00AE00 scheme: GPT
ID-2: /dev/sda type: USB vendor: Western Digital model: WD My Passport 0748 size: 465.73 GiB
serial: 575842314139325638363033 rev: 1019 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Seagate model: Expansion size: 1.82 TiB serial: NA8CJH3T rev: 0707
scheme: GPT
Partition: ID-1: / size: 459.50 GiB used: 134.39 GiB (29.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 8.80 GiB used: 1.04 GiB (11.9%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 49.2 C mobo: N/A gpu: amdgpu temp: 47 C
Info: Processes: 317 Uptime: 12h 49m Memory: 7.21 GiB used: 3.33 GiB (46.1%) Init: systemd v: 245 Compilers:
gcc: 10.1.0 Shell: bash v: 5.0.18 running in: konsole inxi: 3.0.37
mhwd:
0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1f99) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-440xx-prime 2020.03.26 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
Things I’ve tested:
- Compositor in kde
- Installing other distros stupidly
Notes:
- When I record the screen using OBS everything is fine but when playing I can see screen tearing a lot
- It’s only in games
- Also sometimes I have some problems with vlc(when I hit right arrow couple times, it would take some time to show the video correctly)
