using kernel 5.9 or 5.10 makes the display of my Acer ES15 unreadable.
inxi -G
Device-1: Intel HD Graphics 620 driver: i915 v: kernel
Device-2: Chicony VGA Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
with Kernel 5.4 or 5.8 it works norml:
Is there any solution for this problem?
thx
bankman
moson
2
Wow, that looks ugly
It’s not screen tearing though.
Anyways, you could try it with the modesetting rather then the intel driver.
Just remove xf86-video-intel
package.
Removing xf86-video-intel caused a blackscreen. Had to chroot into my system to repair it.
moson
4
Woops. Was switching to tty not even working?
Maybe you have a xorg config file left like:
/etc/X11/xorg.conf.d/20-intel.conf
Which would need to be removed also (or better rename to .bak)
Thanks a lot @moson !
Now it works
system
Closed
6
