After last(Or one before last) update, I see strange behavior in my screen.
I considered that KWin is unable to render transparent windows correctly.
A sample situation is as below:
- I located
Cairo-Duckon right side of my screen. NOTE: I think Cairo-Duck uses OpenGL but Iβm not sure. - I use a transparent background for
Konsolewhich is my typical terminal. - When Cairo-Duck appears, it causes screen to tear on left side.
To make it more clear, I recorded a sample video from this problem:
A recorded GIF of problem
A recorded MKV video of problem
As you can see, when Cairo-Duck is hide, everything is good but when it appears the color of terminal on left side changes frequently. If you need a better Video-Record from problem, feel free to tell me.
Itβs really annoying me and any help or suggestion is appreciated ![]()
NOTE1: This problem is not limited to Cairo-Duck. Some other applications such as xsnow, oneko and β¦ causes this problem too and thatβs why itβs annoying to me!
Also when I right click in Visual Studio Code, I see this problem again exactly around opened window or pop-up.
But this problem just happens in case of transparent windows and borders
NOTE2: I didnβt have this problem before! This problem is caused by last update or one before last updateβ¦ Iβm not sure which one caused this.
My Suggestion:
I think this problem is related to OpenGL but backend rendering option is missed in system settings and I canβt make sure if this problem is related to OpenGL or not:
Tried Solutions:
- Clearing the Plasma Cache didnβt help
System Information
$ uname -a
Linux milad-pc 5.4.184-1-MANJARO #1 SMP PREEMPT Fri Mar 11 13:59:07 UTC 2022 x86_64 GNU/Linux
$ screenfetch
ββββββββββββββββββ ββββββββ milad@milad-pc
ββββββββββββββββββ ββββββββ OS: Manjaro 21.2.5 Qonos
ββββββββββββββββββ ββββββββ Kernel: x86_64 Linux 5.4.184-1-MANJARO
ββββββββββββββββββ ββββββββ Uptime: 1h 20m
ββββββββ ββββββββ Packages: 2356
ββββββββ ββββββββ ββββββββ Shell: zsh 5.8.1
ββββββββ ββββββββ ββββββββ Resolution: 1366x768
ββββββββ ββββββββ ββββββββ DE: KDE 5.91.0 / Plasma 5.24.3
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ WM Theme: Kvantum
ββββββββ ββββββββ ββββββββ GTK Theme: [GTK2/3]
ββββββββ ββββββββ ββββββββ Icon Theme: breath
ββββββββ ββββββββ ββββββββ Disk: 61G / 73G (88%)
ββββββββ ββββββββ ββββββββ CPU: Intel Core i5-5200U @ 4x 2.7GHz [56.0Β°C]
GPU: Intel Corporation HD Graphics 5500 (rev 09)
RAM: 3400MiB / 7879MiB
