Screen sharing / recording not working
hi, I am new to noob to linux, so please pardon me if I am missing anything.
My screen sharing is not working, plus even the screen recording is not working, I saw in blogs that there some option in the gnome to record screen but somehow I am not able to see that option, when we hit the PtrScr button the only option i see is to capture the screen there is no option to record the screen.
Please let me know what i can do to resolve these.
Thanks
output of sudo inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=0590d97d-38b6-42d9-940c-72c3454a856b rw quiet splash apparmor=1
    security=apparmor resume=UUID=f366e3ff-2db1-4a0c-be53-2c2f458d48cf
    udev.log_priority=3
  Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: Dell product: XPS 13 9380 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0KTW76 v: A00 serial: <filter> UEFI: Dell v: 1.23.1
    date: 12/16/2022
  ID-1: BAT0 charge: 23.6 Wh (97.5%) condition: 24.2/51.1 Wh (47.4%) volts: 8.8
    min: 7.4 model: LGC-LGC6.73 DELL H754V79 type: Li-poly serial: <filter>
    status: charging
  RAM: total: 15.28 GiB used: 8.49 GiB (55.5%)
  Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
    note: est.
  Device-1: System Board Memory type: LPDDR3 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: SK Hynix part-no: H9CCNNNCLGALAR-NVD serial: N/A
  Device-2: System Board Memory type: LPDDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i7-8565U socket: BGA1528 (U3E1) note: check bits: 64
    type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 8 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xF4
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2629 high: 2997 min/max: 400/4600 base/boost: 2500/4600
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 2854 2: 2323 3: 2654 4: 2480 5: 2944 6: 2470
    7: 2997 8: 2316 bogomips: 32012
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
    ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0x5b2d built: 2018 res: 1920x1080
    hz: 60 dpi: 168 gamma: 1.2 size: 290x160mm (11.42x6.3") diag: 335mm (13.2")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 620 (WHL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    tools: pacat,pactl
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 51.0 C
  IF-ID-1: br-d50adbe2b2db state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: vethde15c9b state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-7:6
    chip-ID: 0489:e0a2 class-ID: e001
  Local Storage: total: 476.94 GiB used: 206.98 GiB (43.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF512G8 NVMe
    512GB size: 476.94 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: D06N temp: 46.9 C
    scheme: GPT
  ID-1: / raw-size: 459.83 GiB size: 451.54 GiB (98.20%)
    used: 206.98 GiB (45.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 0590d97d-38b6-42d9-940c-72c3454a856b
    used: 328 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: B957-952B
  ID-1: swap-1 type: partition size: 16.81 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: f366e3ff-2db1-4a0c-be53-2c2f458d48cf
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-7:6 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e0a2
    class-ID: e001
  Device-2: 1-10:7 info: Shenzhen Goodix Fingerprint Reader
    type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 27c6:5385 class-ID: 0a00
    serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 75.0 C pch: 70.0 C mobo: 57.0 C
  Fan Speeds (RPM): cpu: 7322 mobo: 6996
  Processes: 451 Uptime: 14m wakeups: 866 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1353 libs: 334 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.26
Install gst-plugin-pipewire and gst-plugin-good. You probably also need switch to pipewire.
Interesting. You run the gpu with the generic vesa driver? Why? Did you install it because more is better or is the native driver buggy? Probably installed it with the “Manjaro Settings”?
didn’t work
don’t know maybe accidentally installed it mostly by “Manjaro Settings”
Then remove video-vesa, video-linux and maybe video-modesetting is all you need. By default, video-vesa will be the first driver which will be loaded.
Removed others
but still screen sharing and recording is an issue
now the graphic is
inxi -G
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] driver: i915 v: kernel
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell v: 43.4 driver: X: loaded: modesetting dri: iris
    gpu: i915 resolution: 1920x1080~60Hz
    GT2)
got it resolved
installed manjaro-pipewire
In other words, you switched from PulseAudio to PipeWire. That is neither made clear in the linked upstream issue nor here. Please correct it in both places otherwise it will help no one.
