Screen Rotation Command for Manjaro Phosh Beta 29/PinePhone Beta/Physical Keyboard?
When I return from a blanked screen (not a locked screen), the PinePhone is often in portrait mode when it should be in landscape. If set on Auto-Rotate, I need to physically rotate the phone to restore landscape mode.
I understand that xrandr is a non-starter in wayland, but installation/use of wdisplays has no effect and wlr-randr apparently won’t work on the PinePhone:
https://forum.pine64.org/showthread.php?tid=9543
Any other terminal command available simply to rotate screen either left or right?
Thanks.
long press the auto rotate icon to set manual rotate.
Thank you for the tip. The trouble is, I’d like to do it in terminal, then make it into a keystroked command.
Any idea about how to go about it?
After investigation, wlr-randr actually does work, at least for screen rotation. Download, build via meson, and after switching into wlr’s build directory, run:
./wlr-randr --ouput DSI-1 --transform 270
