Blank screen following wake from sleep. I can hear Teams pinging, so I assume the computer wakes but I cannot get the screen to turn on. Have to do a hard reset. Errors on kernal log:
19/10/2021 08:32 kernel thermal thermal_zone0: failed to read out thermal zone (-61)
19/10/2021 08:32 kernel kvm: disabled by bios
19/10/2021 08:32 kernel resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff window]
19/10/2021 08:32 kernel caller _nv000722rm+0x1ad/0x200 [nvidia] mapping multiple BARs
19/10/2021 08:32 kernel ACPI: \: failed to evaluate _DSM (0x1001)
19/10/2021 08:32 kernel nvidia-gpu 0000:09:00.3: i2c timeout error e0000000
19/10/2021 08:32 kernel ucsi_ccg 0-0008: i2c_transfer failed -110
19/10/2021 08:32 kernel ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
19/10/2021 08:32 kernel ucsi_ccg: probe of 0-0008 failed with error -110
19/10/2021 08:32 kernel kauditd_printk_skb: 57 callbacks suppressed
19/10/2021 08:32 sddm-greeter QFont::fromString: Invalid description '(empty)'
19/10/2021 08:32 kernel usb 6-3.2: current rate 16000 is different from the runtime rate 24000
19/10/2021 08:32 sddm-greeter QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffde6fe4730), parent's thread is QThread(0x55b959c0edf0), current thread is QThread(0x55b959cd53e0)
19/10/2021 08:32 sddm-greeter QObject::installEventFilter(): Cannot filter events for objects in a different thread.
19/10/2021 08:32 kernel usb 6-3.2: current rate 16000 is different from the runtime rate 32000
19/10/2021 08:32 kernel usb 6-3.2: current rate 16000 is different from the runtime rate 48000
19/10/2021 08:32 sddm-greeter file:///usr/share/sddm/themes/breath2/components/VirtualKeyboard.qml:23:1: Type InputPanel unavailable
19/10/2021 08:32 sddm-greeter qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
19/10/2021 08:32 sddm-greeter qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
19/10/2021 08:32 sddm-greeter file:///usr/share/sddm/themes/breath2/Main.qml:465:13: Unable to assign [undefined] to QUrl
19/10/2021 08:32 sddm-greeter QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.38'
19/10/2021 08:32 kernel Bluetooth: hci0: Reading supported features failed (-16)
19/10/2021 08:32 kernel kauditd_printk_skb: 10 callbacks suppressed
19/10/2021 08:32 systemd-xdg-autostart-generator Configuration file /home/nick/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
19/10/2021 08:32 klauncher Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
19/10/2021 08:32 kcminit_startup QDBusConnection: error: could not send signal to service "" path "//home/nick/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/nick/.kde4/share/config/kdeglobals
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 kwin_x11 kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
19/10/2021 08:32 ksmserver Qt: Session management error: networkIdsList argument is NULL
19/10/2021 08:32 backlighthelper org.kde.powerdevil: no kernel backlight interface found
19/10/2021 08:32 org_kde_powerdevil org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
19/10/2021 08:32 org_kde_powerdevil org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
19/10/2021 08:32 org_kde_powerdevil org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
19/10/2021 08:32 org_kde_powerdevil org.kde.powerdevil: Handle button events action could not check for screen configuration
19/10/2021 08:32 kwin_x11 kwin_core: XCB error: 10 (BadAccess), sequence: 854, resource id: 465, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 884, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 kded5 QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.10'
19/10/2021 08:32 user@1000.service A backend call failed: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
19/10/2021 08:32 user@1000.service Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_24/gtk1805206571'
19/10/2021 08:32 plasmashell trying to show an empty dialog
19/10/2021 08:32 plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
19/10/2021 08:32 pulseaudio stat('/etc/pulse/default.pa.d'): No such file or directory
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1752, resource id: 14680124, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 plasmashell qt.svg: <input>:406:376: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:407:130: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:408:130: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:408:393: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:409:130: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:410:129: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:411:129: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:412:129: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:413:129: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:413:379: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 plasmashell qt.svg: <input>:413:631: Could not add child element to parent element because the types are incorrect.
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1995, resource id: 60817416, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2085, resource id: 60817416, major code: 12 (ConfigureWindow), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 447, resource id: 60817416, major code: 7 (ReparentWindow), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 60817416, major code: 142 (Unknown), minor code: 1
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 450, resource id: 60817416, major code: 6 (ChangeSaveSet), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 451, resource id: 60817416, major code: 25 (SendEvent), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 452, resource id: 60817416, major code: 12 (ConfigureWindow), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 60817416, major code: 12 (ConfigureWindow), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 455, resource id: 60817416, major code: 8 (MapWindow), minor code: 0
19/10/2021 08:32 xembedsniproxy qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 456, resource id: 60817416, major code: 61 (ClearArea), minor code: 0
19/10/2021 08:32 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 2239, resource id: 14680132, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property "height"
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property "height"
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:553:5: QML Label: Binding loop detected for property "height"
19/10/2021 08:32 plasmashell Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:75:17: Unable to assign [undefined] to int
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:30:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
19/10/2021 08:32 plasmashell Error: cannot change the containment to AppletsLayout
19/10/2021 08:32 plasmashell Both point size and pixel size set. Using pixel size.
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:66:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
19/10/2021 08:32 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 2933, resource id: 14680096, major code: 143 (DAMAGE), minor code: 3 (Subtract)
19/10/2021 08:32 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 2952, resource id: 14680096, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2958, resource id: 4194329, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/LeaveButtons.qml:69:5: QML ToolButton: Binding loop detected for property "display"
19/10/2021 08:32 plasmashell QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
19/10/2021 08:32 plasmashell file:///usr/lib/qt/qml/org/kde/plasma/components/ModelContextMenu.qml:38:1: QML ModelContextMenu: Accessible must be attached to an Item
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6159, resource id: 58720264, major code: 15 (QueryTree), minor code: 0
19/10/2021 08:32 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 6658, resource id: 14680141, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7059, resource id: 25165923, major code: 15 (QueryTree), minor code: 0
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8899, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
19/10/2021 08:32 kernel kauditd_printk_skb: 18 callbacks suppressed
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10427, resource id: 25165937, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10432, resource id: 25165938, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:32 plasmashell qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
19/10/2021 08:37 plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:116:15: QML QQuickItem: Binding loop detected for property "height"
19/10/2021 08:37 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46071, resource id: 25165940, major code: 15 (QueryTree), minor code: 0
19/10/2021 08:37 plasmashell qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
19/10/2021 08:39 plasmashell libpng warning: iCCP: known incorrect sRGB profile
19/10/2021 08:40 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21313, resource id: 25165979, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:40 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21449, resource id: 81788933, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:40 kwin_x11 qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24118, resource id: 81788948, major code: 18 (ChangeProperty), minor code: 0
19/10/2021 08:40 audit USER_AUTH pid=3015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
19/10/2021 08:40 audit USER_ACCT pid=3015 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix acct="root" exe="/usr/bin/su" hostname=? addr=? terminal=/dev/pts/3 res=success'
19/10/2021 08:41 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 35723, resource id: 14694699, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:41 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 36283, resource id: 14694714, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:41 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 39257, resource id: 14694894, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:41 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 43390, resource id: 14695100, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:41 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 44562, resource id: 14695126, major code: 143 (DAMAGE), minor code: 2 (Destroy)
19/10/2021 08:43 kwin_x11 kwin_core: XCB error: 152 (BadDamage), sequence: 18941, resource id: 14697558, major code: 143 (DAMAGE), minor code: 2 (Destroy)
