Hello, i have a problem with screen locker. Sometimes after closing laptop lid and then opening it again screen locker does not appear. After it i can lock it manually with Meta+L. Journalctl shows that kscreenlocker is unable to establish screen lock. Unfortunately my technical expertise ends about here, so where else can i look? This problem also existed on xubuntu distro, so maybe its hardware? Latest updates are installed. Thank you.
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=116713ee-9163-4142-8a6a-90f9278537f2 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: S300CA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: S300CA v: 1.0 serial: <filter>
UEFI: American Megatrends v: S300CA.305 date: 07/04/2013
ID-1: BAT0 charge: 32.2 Wh condition: 32.5/45.3 Wh (72%) volts: 11.2/11.2
model: ASUSTeK X402--40 type: Li-ion serial: N/A status: Unknown cycles: 450
Topology: Dual Core model: Intel Core i5-3317U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 13575
Speed: 817 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 817 2: 802 3: 829
4: 801
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: IMC Networks type: USB driver: uvcvideo bus ID: 1-1.2:4
chip ID: 13d3:5195 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 120 size: 290x160mm (11.4x6.3")
diag: 331mm (13")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.1.7 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel port: f040 bus ID: 02:00.0 chip ID: 168c:0032
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: e000 bus ID: 03:00.0 chip ID: 1969:1091
Local Storage: total: 298.09 GiB used: 152.26 GiB (51.1%)
ID-1: /dev/sda vendor: Hitachi model: HTS543232A7A384 size: 298.09 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: A60W scheme: GPT
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 21.27 GiB (22.2%)
fs: ext4 dev: /dev/sda2
ID-2: /home raw size: 191.92 GiB size: 187.91 GiB (97.91%)
used: 130.99 GiB (69.7%) fs: ext4 dev: /dev/sda4
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.21 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2200
Processes: 190 Uptime: 1h 20m Memory: 3.73 GiB used: 1.85 GiB (49.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1354 lib: 364 flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake
inxi: 3.1.05
[emile@emile-s300ca ~]$ journalctl --since "2020-09-10 00:10:40" --until "2020-09-10 00:10:50"
-- Logs begin at Fri 2020-07-24 02:45:18 MSK, end at Thu 2020-09-10 01:12:59 MSK. --
сен 10 00:10:42 emile-s300ca systemd-logind[823]: Lid closed.
сен 10 00:10:42 emile-s300ca org_kde_powerdevil[1424]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
сен 10 00:10:43 emile-s300ca org_kde_powerdevil[1424]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, t>
сен 10 00:10:43 emile-s300ca org_kde_powerdevil[1424]: powerdevil: Starting Login1 suspend job
сен 10 00:10:43 emile-s300ca org_kde_powerdevil[1424]: powerdevil: Pausing all media players before sleep
сен 10 00:10:43 emile-s300ca kded5[1291]: bluedevil: About to suspend
сен 10 00:10:43 emile-s300ca ModemManager[933]: <info> [sleep-monitor] system is about to suspend
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.2414] manager: sleep: sleep requested (sleeping: no enabled: yes)
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.2414] device (enp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-stat>
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.2462] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-i>
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.2476] manager: NetworkManager state is now ASLEEP
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.2488] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-sta>
сен 10 00:10:43 emile-s300ca kded5[1291]: plasma-nm: Unhandled active connection state change: 3
сен 10 00:10:43 emile-s300ca dbus-daemon[817]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.>
сен 10 00:10:43 emile-s300ca systemd[1]: Starting Network Manager Script Dispatcher Service...
сен 10 00:10:43 emile-s300ca ksmserver[1318]: kscreenlocker: Could not establish screen lock
сен 10 00:10:43 emile-s300ca kernel: audit: type=1130 audit(1599685843.282:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager->
сен 10 00:10:43 emile-s300ca kernel: wlp2s0: deauthenticating from f8:df:a8:77:ab:b4 by local choice (Reason: 3=DEAUTH_LEAVING)
сен 10 00:10:43 emile-s300ca audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" ex>
сен 10 00:10:43 emile-s300ca systemd[1]: Started Network Manager Script Dispatcher Service.
сен 10 00:10:43 emile-s300ca dbus-daemon[817]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7464] device (wlp2s0): supplicant interface state: completed -> disconnected
сен 10 00:10:43 emile-s300ca wpa_supplicant[869]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=f8:df:a8:77:ab:b4 reason=3 locally_generated=1
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7466] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface->
сен 10 00:10:43 emile-s300ca wpa_supplicant[869]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7608] dhcp4 (wlp2s0): canceled DHCP transaction
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Withdrawing address record for fe80::8cfd:3ffb:2f72:e6ca on wlp2s0.
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7609] dhcp4 (wlp2s0): state changed bound -> done
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::8cfd:3ffb:2f72:e6ca.
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7730] device (wlp2s0): set-hw-addr: set MAC address to 92:89:31:81:12:1E (scanning)
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.0.127.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Withdrawing address record for 192.168.0.127 on wlp2s0.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.0.127.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: New relevant interface wlp2s0.IPv4 for mDNS.
сен 10 00:10:43 emile-s300ca avahi-daemon[814]: Registering new address record for 192.168.0.127 on wlp2s0.IPv4.
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7978] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.7979] device (wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-sta>
сен 10 00:10:43 emile-s300ca NetworkManager[818]: <info> [1599685843.8085] device (wlp2s0): set-hw-addr: reset MAC address to 6C:71:D9:50:4D:D5 (unmanage)
сен 10 00:10:43 emile-s300ca kded5[1291]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
сен 10 00:10:43 emile-s300ca wpa_supplicant[869]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
сен 10 00:10:48 emile-s300ca systemd-logind[823]: Delay lock is active (UID 1000/emile, PID 1318/ksmserver) but inhibitor timeout is reached.
сен 10 00:10:48 emile-s300ca systemd[1]: Reached target Sleep.
сен 10 00:10:48 emile-s300ca systemd[1]: Starting Suspend...
сен 10 00:10:48 emile-s300ca systemd-sleep[24884]: Suspending system...
сен 10 00:10:48 emile-s300ca kernel: PM: suspend entry (deep)
lines 13-51/51 (END)
