Recently, my laptop is behaving wierdly for autolocking.
Normally, I expect that when it goes to sleep, it should get locked. However, what’s happening is that when the screen turns off, it’s not locked. When I move my mouse later to turn it on, I am able to access the open windows for few seconds. After that, it locks up.
Also, unlocking takes few seconds now, although earlier it used to be instantaneous. Also, sometimes when I try to unlock, after I enter the password, I get a message saying “This session is locked - you will be redirected to the unlock dialog automatically in a few seconds”. Then I am redirected to the login session and have to enter password again.
Seems like some issue with sleep. Happens both on 5.13 and 5.10 kernels. Haven’t tried other kernels. Not sure how to debug this further.
System info:
Host: me-pc Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8136 v: 31.36 serial: <superuser required> UEFI: Insyde
v: F.1F date: 01/18/2016
ID-1: BAT1 charge: 19.9 Wh (96.6%) condition: 20.6/31.7 Wh (64.9%)
volts: 16.1 min: 14.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: 41167 status: Unknown
Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 cache: L2: 3 MiB
bogomips: 19204
Speed: 721 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 721 2: 656
3: 565 4: 500
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0bda:57d6 class-ID: 0e02 serial: DEWKP01BI9L83M
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati,modesetting,radeon alternate: fbdev,vesa resolution:
1: 1920x1080~60Hz 2: 2560x1440~75Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0
chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0 state: down mac: dc:4a:3e:d7:70:0d
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlp3s0 state: up mac: 48:e2:44:b1:d8:85
IF-ID-1: br-06f9136fed06 state: down mac: 02:42:bf:95:c5:14
IF-ID-2: docker0 state: down mac: 02:42:34:1a:73:0a
IF-ID-3: mpqemubr0 state: down mac: 52:54:00:e8:da:67
IF-ID-4: virbr0 state: down mac: 52:54:00:a3:29:1f
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b006 class-ID: e001 serial: 00e04c000001
Local Storage: total: 465.76 GiB used: 242.02 GiB (52.0%)
ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: 1926E20F554B rev: 023 scheme: GPT
ID-1: / size: 63.48 GiB used: 44.27 GiB (69.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 98.4 MiB used: 266 KiB (0.3%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 377.62 GiB used: 197.75 GiB (52.4%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4
System Temperatures: cpu: 53.5 C mobo: 29.8 C gpu: radeon temp: 57.0 C
Processes: 227 Uptime: 19m wakeups: 1 Memory: 7.67 GiB
used: 3.05 GiB (39.8%) Init: systemd v: 249 Compilers: gcc: 11.1.0
Packages: 2154 pacman: 2143 snap: 11 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.07
