Screen is glitching
Hi guys, this is my first time posting here cause it’s really urgent. Any help you can provide would be extremely appreciated, thanks.
Yesterday when I was going to bed, I press the power button on my laptop to suspend, then closed the lid. As I was doing so, I noticed the screen start glitching, but I didn’t pay it any mind.
Today morning, I resumed it only to see the glitching continue. I have restarted several times, but to no avail.
I know the issue isn’t with the laptop screen cause the bios looks fine, and I have windows installed alongside, which also displays just fine.
This is my work and personal laptop, and I’m scared I’ll have to reinstall.
Info that might help:
I use gnome, but added hyprland many months ago.
The glitching starts as soon as the Manjaro loading screen shows after bios.
I installed waydroid package yesterday, but I didn’t do all that kernel stuff; just simply the aur package.
My laptop is Lenovo yoga 510
Thank you very much for whatever help you can provide.
Forum won’t let me add image, so here it is:
https://ibb.co/dGZdkzV
SYSTEM INFO:
  Kernel: 5.15.128-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=ce9a470c-3f89-4b06-99dc-12b2d3a4864e rw quiet splash apparmor=1
  Desktop: Hyprland vt: 2 dm: GDM v: 43.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Convertible System: LENOVO product: 80S7 v: Lenovo YOGA 510-14ISK
    serial: <superuser required> Chassis: type: 31 v: Lenovo YOGA 510-14ISK
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> UEFI-[Legacy]: LENOVO v: 0VCN31WW(V1.15)
    date: 06/19/2018
  ID-1: BAT1 charge: 4.2 Wh (11.5%) condition: 36.4/52.5 Wh (69.3%)
    power: 19.5 W volts: 11.9 min: 11.2 model: SIMPLO PABAS0241231 type: Li-ion
    serial: <filter> status: charging
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1303 high: 1309 min/max: 400/3100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1300 2: 1303 3: 1300
    4: 1309 bogomips: 20810
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
    class-ID: 0300
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
    520 Mobile] vendor: Lenovo driver: radeon v: kernel alternate: amdgpu
    arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8 bus-ID: 01:00.0
    chip-ID: 1002:6660 class-ID: 0380 temp: 51.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    compositor: Hyprland driver: X: loaded: modesetting,radeon
    alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14b1 built: 2015 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 308x173mm (12.13x6.81") diag: 353mm (13.9")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel HD Graphics 520 (SKL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k5.15.128-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 0.3.81 status: off with: wireplumber status: off
    tools: pw-cli,wpctl
  Server-4: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
    tools: pacat,pactl,pamixer
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0cf3:e360
    class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.1
    lmp-v: 7 sub-v: 25a hci-v: 7
  Info: acl-mtu: 1024:8 sco-mtu: 50:8 link-policy: rswitch hold sniff
    link-mode: peripheral accept
  Local Storage: total: 471.44 GiB used: 312.36 GiB (66.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZYTY256HDHP-000L2
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1L1Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: USB 3.2Gen1
    size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1.00 scheme: MBR
  ID-1: / raw-size: 78.96 GiB size: 77.16 GiB (97.73%) used: 51.81 GiB (67.1%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4
  ID-2: /home raw-size: 82.69 GiB size: 80.83 GiB (97.76%)
    used: 71.94 GiB (89.0%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
  ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap
  System Temperatures: cpu: 51.0 C pch: 50.5 C mobo: N/A gpu: radeon
    temp: 52.0 C
  Fan Speeds (rpm): N/A
  Processes: 168 Uptime: 4m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 7.5 GiB used: 936.6 MiB (12.2%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: 2091 pm: pacman pkgs: 2054 libs: 419
  tools: gnome-software,pamac,yay pm: flatpak pkgs: 37 Shell: Zsh v: 5.9
  running-in: foot inxi: 3.3.29```
System info is a good start:
inxi -Fazy
This guide covers how to find and share information, format code, etc:
I’ve edited post to add photo and system info, thanks
Uninstall Waydroid.
If the issue you noticed only started when shutting down after installing Waydroid, that might be among the first things I’d try.
Then shutdown completely, go and make a coffee, tea, glass of koolaid, or whatever you desire. Come back after five minutes, and start the computer again (a cold start) and see if any magic happens.
You have been reading yet another drive-by comment from @soundofthunder .
Oh, and @jojo2 Welcome to the Manjaro community.
I’ve uninstalled waydroid and issue still persists.
It temporary stopped when i pressed SUPER+M to log out of hyprland. However, on the third and onward tries, it didn’t work.
You could try updating your kernel, to the latest 6.6, for example, or the kernel 6.1 (LTS). See if that makes a difference. See Manjaro Kernels.
Also, check that your monitor cables are properly connected and secured (both ends). Cheers.
