When a window is demaximized glitches blinking around window or on second monitor. When I disable maximize animation screen effect its OK.
Ah, so another reason to disable extra animation âeffectsâ.
PS. For better help maybe include system information, ex: inxi -Fazy
âDoctor, it hurts when I do thisâ.
âThen donât do thatâ.
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=c1a533c1-e524-4391-bd8b-92022852ce4d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: LENOVO product: 21CJS04U00 v: ThinkPad T16 Gen 1
Mobo: LENOVO model: 21CJS04U00 v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R23ET65W (1.35 ) date: 03/21/2023
ID-1: BAT0 charge: 86.0 Wh (98.6%) condition: 87.2/86.0 Wh (101.4%)
volts: 16.7 min: 15.4 model: SMP LNV-5B10W51871�� type: Li-poly
serial: <filter> status: not charging cycles: 9
Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1074 high: 2078 min/max: 400/4768 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1737 2: 1765 3: 1667
4: 1880 5: 2078 6: 1399 7: 400 8: 400 9: 2077 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 1396 bogomips: 86278
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2,
DP-3, DP-4, DP-5, DP-6 bus-ID: 04:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 47.0 C
Device-2: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 5986:2142
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1014x317mm (39.92x12.48")
s-diag: 1062mm (41.83")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,right model: AOC 2757
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: left model: AU Optronics 0xe69b
built: 2021 res: 1920x1200 hz: 60 dpi: 142 gamma: 1.2
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:1681 memory: 1000 MiB
unified: no
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 23.1.9-manjaro1.1
device-ID: 1002:1681 surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.81 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: Lenovo driver: N/A modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
Local Storage: total: 953.87 GiB used: 98.24 GiB (10.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: CL2QGXA7 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 299.57 GiB size: 293.81 GiB (98.08%)
used: 98.21 GiB (33.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.1 MiB (30.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): fan-1: 0
Processes: 429 Uptime: 1d 20h 20m wakeups: 16 Memory: total: 32 GiB
note: est. available: 30.13 GiB used: 17.82 GiB (59.1%) Init: systemd v: 254
Packages: 1598 pm: dpkg pkgs: 0 pm: pacman pkgs: 1585 libs: 483
tools: pamac,yay pm: flatpak pkgs: 13 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.30
Your problem sounds like this bug report. Some of the other reports that have been marked as duplicates there have more info. There doesnât seem to be any fix available yet apart from disabling the effect that is causing the problem.
