Screen gets dark and flickers after signing in
Just installed a fresh copy of Manjaro, and I immediately noticed that the screen seemed way to dark despite the brightness being maxed out. When I restarted the system, the login screen was the normal brightness, but it went back to being dark as soon as I signed in. It also flickers whenever there is white on screen.
Please provide the output of:
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions :point_down:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks:
or three tildes:
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
This is a known bug in Plasma 6.7, related to the screen dimming. It will be fixed when Manjaro gets the next Plasma release. The only way around it for now is to disable the dimming.
Unfortunately, I cannot tell you when the next Plasma update will arrive (in Manjaro), but if you are impatient, then you can always switch to the Testing branch and see whether it too still has the issue. Manjaro Testing currently has Plasma 6.7.5, while Manjaro Stable is still on 6.7.4.
sudo pacman-mirrors -a -B testing && sudo pacman -Syyu
My automatic screen brightness seems to work fine most of the time.
