Following the most recent stable update, displays will occasionally freeze while watching Youtube videos, either in Firefox or in Electron-powered apps (including Discord). Switching back and forth to another tty (e.g., via Ctrl + Alt + F3) seems to recover the system, though it can take up to 30 seconds to switch to the alternate tty.
I’m not sure if this is a KDE/Plasma issue, a Wayland issue, an nVidia issue, or some combination of all three. What I do know is no such issues occurred prior to the most recent stable update.
inxi output:
kekemui@WARWOLF ~ sudo inxi --filter --verbosity=8 -z
[sudo] password for kekemui:
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=27c8f1bb-3c4b-4506-bbc1-1aa8767c1fce rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C37 v: 1.0 serial: N/A
Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0
serial: N/A UEFI: American Megatrends LLC. v: 1.M0 date: 06/29/2023
ID-1: hidpp_battery_0 charge: 87% condition: N/A volts: 4.0 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: discharging
System RAM: total: 32 GiB available: 31.26 GiB used: 10.86 GiB (34.7%)
(unregistered) size: 8 GiB speed: 3600 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3600C16-8GTZN serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
bus-ID: 00:01.0
Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
bus-ID: 00:1c.3
Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
bus-ID: 00:1c.4
Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
bus-ID: 00:1c.5
Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
bus-ID: 00:1c.6
Slot: 5 type: PCIe status: in use info: J8D1 length: short volts: 3.3
bus-ID: 00:1c.7
Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
bus-ID: 00:1e.0
Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3
bus-ID: 00:03.1 children: 1: 2d:00.0 class-ID: 0300 type: display 2: 2d:00.1
class-ID: 0403 type: audio
Slot: 13 type: PCIe status: available info: J3600 length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe status: available info: J3708 length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe status: available info: J3702 length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 4 type: PCIe status: in use info: J3703 length: short volts: 3.3
bus-ID: 21:04.0
Slot: 5 type: PCIe status: in use info: J3701, M.2 length: short
volts: 3.3 bus-ID: 21:05.0
Slot: 14 type: PCIe status: in use info: M.2 length: short volts: 3.3
bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0108 type: mass-storage
Info: model: AMD Ryzen 7 5800X3D socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 1753 min/max: 550/4550 boost: enabled
base/boost: 3400/3400 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1753 2: 1753 3: 1753 4: 1753
5: 1753 6: 1753 7: 1753 8: 1753 9: 1753 10: 1753 11: 1753 12: 1753
13: 1753 14: 1753 15: 1753 16: 1753 bogomips: 108832
xsaves xtopology
affected
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: eVga.com.
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 2d:00.0 chip-ID: 10de:2216
class-ID: 0300
Device-2: Nexight NexiGo HelloCam N930W Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.3.1:6
chip-ID: 2b7e:c569 class-ID: 0e02
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 8560x1440 s-dpi: 96 s-size: 2264x381mm (89.13x15.00")
s-diag: 2296mm (90.39")
Monitor-1: DP-2 note: disabled pos: left model: MSI MP275Q
serial: <filter> built: 2024 res: mode: 2560x1440 hz: 100 scale: 100% (1)
dpi: 109 gamma: 1.2 chroma: red: x: 0.651 y: 0.329 green: x: 0.318
y: 0.620 blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x720,
1024x768, 800x600, 720x576, 720x480, 640x480
Monitor-2: DP-3 note: disabled pos: primary,center model: Dell AW3423DWF
serial: <filter> built: 2023 res: mode: 3440x1440 hz: 100 scale: 100% (1)
dpi: 109 gamma: 1.2 chroma: red: x: 0.710 y: 0.282 green: x: 0.243
y: 0.718 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: 3440x1440,
2560x1440, 1920x1080, 1600x900, 1280x1024, 1152x864, 1280x720, 1024x768,
EDID-Warnings: 1: parse_edid: unknown tag 112
Monitor-3: HDMI-A-1 note: disabled pos: right model: MSI MP275Q
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: nvidia surfaceless: drv: nvidia x11: drv: swrast inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.4.304 layers: 3 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: N/A device-ID: 10de:2216
surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
bus-ID: 2d:00.1 chip-ID: 10de:1aef class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Schiit Audio Hel 2e driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 30be:0107 class-ID: 0300
Device-4: Nexight NexiGo HelloCam Composite Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 5-1.3.3:8 chip-ID: 2b7e:a569 class-ID: 0300
serial: <filter>
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0aa7
class-ID: e001
Local Storage: total: 9.13 TiB used: 1.96 TiB (21.5%)
ID-1: /dev/nvme0n1 maj-min: 259:9 vendor: Samsung model: SSD 990 EVO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 51.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 35.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 1.86 TiB block-size: physical: 512 B
fw-rev: SN08661 temp: 48.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NC001-1FS168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CN03 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU635 size: 894.25 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 017a scheme: GPT
ID-1: / raw-size: 698.49 GiB size: 686.46 GiB (98.28%)
used: 66.94 GiB (9.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:10 label: N/A uuid: 27c8f1bb-3c4b-4506-bbc1-1aa8767c1fce
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 32.1 MiB (33.7%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p2
maj-min: 259:2 label: N/A uuid: A84A-8190
ID-3: /data/expansion_nvme raw-size: 1.86 TiB size: 1.83 TiB (98.38%)
used: 859.88 GiB (45.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme2n1p2
maj-min: 259:8 label: N/A uuid: 753645ee-cbe9-4d33-b5ff-c435b6bb6f96
ID-4: /data/spinning_rust raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 879.35 GiB (24.0%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: Spinning Rust
uuid: 91bd4b42-3dcb-4b50-89ff-d3ed80db3c22
ID-5: /home raw-size: 1.14 TiB size: 1.12 TiB (98.34%)
used: 202.74 GiB (17.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:11 label: N/A uuid: fa96826f-8113-42e2-b44b-771d90f05943
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 4E34497A344965D5
ID-2: /dev/nvme1n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme1n1p4 maj-min: 259:4 size: 952.57 GiB fs: ntfs label: N/A
uuid: AE6465C8646593BD
ID-4: /dev/nvme1n1p5 maj-min: 259:5 size: 687 MiB fs: ntfs label: N/A
uuid: F04C8B3B4C8AFC1A
ID-5: /dev/nvme2n1p1 maj-min: 259:7 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-7: /dev/sdb1 maj-min: 8:17 size: 894.25 GiB fs: ntfs label: ADATA SSD
uuid: 0CA69C4E557B50D0
Device-1: 1-4:2 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
Device-2: 1-6:3 info: Schiit Audio Hel 2e type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-2:2 info: Transcend Information microSD/SD/CF UHS-II Card
Reader [RDF8 RDF9] type: mass storage driver: usb-storage interfaces: 1
rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
power: 896mA chip-ID: 8564:4000 class-ID: 0806 serial: <filter>
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 5-1.1:3 info: Elgato Systems GmbH Stream Deck Pedal type: HID
driver: usbfs interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 400mA chip-ID: 0fd9:0086 class-ID: 0300 serial: <filter>
Hub-8: 5-1.3:4 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 5-1.3.1:6 info: Nexight NexiGo HelloCam N930W Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 2b7e:c569 class-ID: 0e02
Device-2: 5-1.3.3:8 info: Nexight NexiGo HelloCam Composite Device
type: audio,keyboard driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 2b7e:a569 class-ID: 0300 serial: <filter>
Hub-9: 5-1.4:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 5-1.4.1:7 info: Corsair Gaming SCIMITAR PRO RGB Mouse
type: mouse,HID driver: corsair,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 1b1c:1b3e class-ID: 0300 serial: <filter>
Hub-10: 5-1.4.3:9 info: Microchip Drop Hub ports: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 04d8:eec5
Device-1: 5-1.4.3.2:11 info: Microchip CTRL type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 04d8:eed2 class-ID: 0300
serial: <filter>
Hub-11: 5-1.4.4:10 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 5-1.4.4.1:12 info: Elgato Systems GmbH Stream Deck original V2
type: HID driver: usbfs interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0fd9:006d class-ID: 0300
serial: <filter>
Device-2: 5-1.4.4.2:13 info: Elgato Systems GmbH Stream Deck type: HID
driver: usbfs interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 400mA chip-ID: 0fd9:0060 class-ID: 0300 serial: <filter>
Device-3: 5-1.4.4.3:14 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 6-2:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-14: 6-2.4:3 info: Realtek Hub ports: 4 rev: 3.2
Hub-15: 6-2.4.4:4 info: Realtek Hub ports: 4 rev: 3.2
System Temperatures: cpu: 47.1 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2084 pm: pacman pkgs: 2070 libs: 519 tools: pamac pm: flatpak
pkgs: 14
1: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
3: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 431
1: cpu: 8.3% command: kwin_wayland pid: 996 mem: 420.3 MiB (1.3%)
2: cpu: 6.1% command: firefox pid: 3203 mem: 1870.8 MiB (5.8%)
3: cpu: 4.0% command: firefox pid: 340890 mem: 435.9 MiB (1.3%)
4: cpu: 2.6% command: StreamController pid: 1670 mem: 281.7 MiB (0.8%)
5: cpu: 2.2% command: firefox pid: 410244 mem: 323.0 MiB (1.0%)
Memory top: 5 of 431
1: mem: 1870.8 MiB (5.8%) command: firefox pid: 3203 cpu: 6.1%
2: mem: 1048.2 MiB (3.2%) command: plasmashell pid: 1178 cpu: 0.2%
3: mem: 848.4 MiB (2.6%) command: firefox pid: 3545 cpu: 1.7%
4: mem: 666.0 MiB (2.0%) command: firefox pid: 3457 cpu: 0.2%
5: mem: 540.2 MiB (1.6%) command: steamwebhelper pid: 2971 cpu: 0.3%
Processes: 431 Power: uptime: 3h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Sudo (sudo)
v: 1.9.16p2 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
