I am encountering a persistent issue where my screen freezes after rebooting following system updates. This problem has occurred across multiple installations of Manjaro (four in total), including on my main OS, and even after installing Arch Linux. The issue seems to arise after applying updates through the Pacman GUI. No significant change was observed when loading different kenels.
System Information
- any Arch Linux with gnome
- ASUS Duo (2024)
Steps to Reproduce
- Install Manjaro or Arch Linux on an ASUS Duo laptop
- Apply system updates using the Pacman GUI.
- Reboot the system.
Behavior
After rebooting, the screen freezes, rendering the system unusable. The behavior is unexpected, it starts either from the initial login screen, upon login, during a random time to one of the displays freezing. There is also sometimes a gray screen after login.
I believe the issue is linked to a recent update in Gnome, which seems to be the trigger for the screen freeze.
I am looking for guidance on how to diagnose the root cause of this issue without the need to install each package one by one. Any advice or troubleshooting tips from the community would be greatly appreciated.
