I wanted to remove the boot splash screen and Plymouth, so I followed a recent post on removing plymouth if it’s not needed and got to work with it. I already had removed the quiet parameter from /etc/default/grub and the plymouth hook from /etc/mkinitcpio.conf and regenerated both before. But today I removed splash from grub and ran sudo update-grub but didn’t remove plymouth or plymouth-theme-manjaro as I wanted to wait and see if the reboot goes OK.
Afterwards when rebooting, before I even entered my UEFI boot password, my screen would turn off for 2-3 seconds around every 6 seconds until reaching the login screen, although I could still type (first reboot hung at “Slot 0 opened” right after decrypting my LUKS so I forced shutdown). After hooks would run, it would briefly say something about starting Plymouth. So right now I added back splash and its working fine again. Would removing plymouth and plymouth-theme-manjaro solve this? How can I fix this issue?
I also don’t have Nvidia or any proprietary drivers.
Edit: my system information from inxi -Fazy:
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=[my UUID] rw
cryptdevice=UUID=[my UUID]
root=/dev/mapper/luks-[my UUID] splash
apparmor=1 security=apparmor udev.log_priority=3 page_alloc.shuffle=1
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Dell product: Latitude 5480 v: N/A
Mobo: Dell model: 0R75NX v: A00 serial: <superuser required> part-nu: 07A7
uuid: <superuser required> UEFI: Dell v: 1.31.0 date: 07/03/2023
ID-1: BAT0 charge: 56.9 Wh (99.0%) condition: 57.5/68.0 Wh (84.6%) volts: 8.5
min: 7.6 model: LGC-LGC8.820 DELL DV9NT84 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 550 high: 1000 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 400 3: 400 4: 400
bogomips: 21607
vulnerable
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: ASUS VY279 serial: <filter> built: 2022
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x14c3 built: 2016 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 238.47 GiB used: 69.28 GiB (29.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM871b M.2 2280
256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2D0Q scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.37 GiB (97.99%)
used: 69.25 GiB (29.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-[my UUID]
used: 32.4 MiB (10.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 0.0 C pch: 38.0 C mobo: 35.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.5 GiB used: 2.06 GiB (13.3%)
Processes: 228 Power: uptime: 2h 50m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.19 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1460 libs: 446 tools: gnome-software,pamac
Compilers: N/A Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.34
/etc/mkinitcpio.conf:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(usbhid xhci_hcd)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=(/crypto_keyfile.bin)
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No RAID, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect modconf block filesystems fsck)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev modconf block filesystems fsck)
## This setup assembles a mdadm array with an encrypted root file system.
## Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
# HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
## This setup loads an lvm2 volume group.
# HOOKS=(base udev modconf block lvm2 filesystems fsck)
## This will create a systemd based initramfs which loads an encrypted root filesystem.
# HOOKS=(base systemd autodetect modconf kms keyboard sd-vconsole sd-encrypt block filesystems fsck)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr and fsck hooks.
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block encrypt filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, zstd compression
# is used for Linux ≥ 5.9 and gzip compression is used for Linux < 5.9.
# Use 'cat' to create an uncompressed image.
#COMPRESSION="zstd"
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress loadable kernel modules and their firmware during initramfs
# creation. Switch (yes/no).
# Enable to allow further decreasing image size when using high compression
# (e.g. xz -9e or zstd --long --ultra -22) at the expense of increased RAM usage
# at early boot.
# Note that any compressed files will be placed in the uncompressed early CPIO
# to avoid double compression.
#MODULES_DECOMPRESS="no"
/etc/default/grub (after adding back splash):
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=1
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="cryptdevice=UUID=[my UUID] root=/dev/mapper/luks-[my UUID] splash apparmor=1 security=apparmor udev.log_priority=3 page_alloc.shuffle=1"
GRUB_CMDLINE_LINUX=""
GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
