Hi, just switched my main to Manjaro KDE a week ago.
Reason was continued Windows AMD driver stability/crash issues with a multi monitor setup and infrequently even with a single high refresh vrr monitor. No driver versions ever truly fixed it for me.
So KDE with Wayland, still ran a single connected monitor and that has been very stable and enjoyable so far. No GPU related stability issues, even with a known stable overclock it has been stress testing solidly.
On connecting my secondary monitor I started experiencing screen glitches/flickering, almost like horizontal screen tearing on both monitors when any full screen game or 3D benchmark starts to run. This reminded me of refresh rates set to high on fixed Hz displays, where it glitches when running a 60Hz on 75Hz.
After some seconds this flickering/tearing on both screens stops and the full screen game of 3D benchmark continues to run normal and stable. Some games though like Fallout 4, keep periodically exhibiting this when the engine loads new world data when you move around. This is a bit of an annoyance.
Running 60-60Hz, with adaptive sync disabled, the issue still happens.
My question. Is this an issue in KDE 5.26 and Wayland, or is this perhaps still a GPU issue?
Any help is much appreciated.
monitor specs
BenQ EX2510, FHD 144Hz Freesync, connected via DP1.2 cable
Samsung BW226, 1680x1050 60Hz, connected via DP>HDMI
OR
Samsung FHD TV connected via HDMI
inxi -v7azy
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw quiet splash
udev.log_priority=3 amd_pstate=passive amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: UEFI: American Megatrends LLC. v: 3.D0
date: 04/01/2022
RAM: total: 15.54 GiB used: 5.46 GiB (35.1%)
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 607 high: 783 min/max: 550/4663 boost: enabled scaling:
driver: amd-pstate governor: conservative cores: 1: 550 2: 550 3: 550 4: 783
5: 550 6: 550 7: 550 8: 550 9: 550 10: 550 11: 783 12: 768 13: 550 14: 783
15: 550 16: 550 bogomips: 108845
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 28:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 15.0.7 DRM 3.49 6.1.7-1-MANJARO) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 4.14 TiB used: 1.07 TiB (25.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: ECFM32.1 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
lanes: 4 type: SSD serial: rev: V1.23 temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: rev: 022 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: rev: CC43 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 type: USB model: TO Exter nal USB 3.0
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%)
used: 224.26 GiB (26.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 159.59 GiB (18.9%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/storage raw-size: 833.85 GiB size: 833.85 GiB (100.00%)
used: 663.11 GiB (79.5%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: STORAGE
uuid: B0A0696BA069394C
ID-5: /run/media/gkirmathal/MAIN_SSD raw-size: 79.88 GiB
size: 79.88 GiB (100.00%) used: 45.65 GiB (57.1%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: MAIN_SSD uuid: 5C828893828872F6
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: AC98EB3A98EB01A6
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: A8EF-469B
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs:
label: N/A uuid: N/A
ID-4: /dev/sda5 maj-min: 8:5 size: 331.05 GiB fs: ntfs label: DATA_GAMES
uuid: FC8038908038537E
ID-5: /dev/sdb2 maj-min: 8:18 size: 97.66 GiB fs: ntfs label: BACKUP
uuid: 2028757C28755230
ID-6: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs
label: EXT_STORAGE_1TB uuid: 683A0A0C7F46D31B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-8:2 info: SONiX USB DEVICE type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 320f:500c class-ID: 0301
Device-2: 1-9:3 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: JMS578 based SATA bridge type: Mass Storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 0080:a001 class-ID: 0806 serial:
System Temperatures: cpu: 28.0 C mobo: 27.0 C gpu: amdgpu temp: 36.0 C
mem: 36.0 C
Fan Speeds (RPM): fan-1: 512 fan-2: 485 fan-3: 0 fan-4: 820 fan-5: 0
fan-6: 0 gpu: amdgpu fan: 0
Processes: 365 Uptime: 2h 6m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1409 libs: 440 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
mhwd -l
0000:22:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
0000:28:00.0 (0300:1002:731f) Display controller ATI Technologies Inc:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Kernel & Manjaro release
mhwd-kernel -li
Currently running: 6.1.7-1-MANJARO (linux61)
- linux61
lsb_release -sirc
ManjaroLinux 22.0.1 Sikaris
