Screen flickering on plasma 6 wayland
Hello everyone!!
This is my first post here, I apologise if I break any conventions. I switched from Windows to Linux and have been using it for the past couple months. I currently have KDE plasma 6 running on wayland.
I keep getting flickering on my main 165 Hz monitor. I figure it has something to do with the high refresh rate.
This only happens when I close a window. And it doesn’t happen on my second monitor unless the window is not maximized on the main monitor. Also on the second monitor the flickering only happens on the top title bar (idk if that makes sense).
I don’t know how to upload a video here, and I keep getting a message that I cannot include links to my post. I have a video shared on google drive about the screen flickering.
I have only done some light customization. Namely, added a top panel and installed widget.
I have a Radeon RX 7800xt and an Intel i7-12700K cpu.
If any further information is required, I would be happy to provide it.
Thank you for your help!
Welcome to the Manjaro community.
As a new forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) is often useful (and this or similar will usually be asked for in Support threads):
inxi -zv8
This gives some (privacy-filtered) information about your system.
Be prepared to provide more information and outputs from other commands when asked.
Hello!
Here is the link to the screen flickering video:
https://drive.google.com/file/d/1eA90Um8WV2LLg46rBxou2RIZWmgU0EtA/view?usp=sharing
and the output of inxi -zv8
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=4d8cba3f-f1de-489d-9043-a379e980232c rw quiet splash
    resume=UUID=437d48b0-f52a-4811-abe6-b8f279cca70f udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop Mobo: Gigabyte model: B760M AORUS ELITE AX v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F18e date: 07/15/2024
  System RAM: total: 32 GiB available: 31.11 GiB used: 4.15 GiB (13.3%)
  Device-1: DDR5-A1 type: no module installed
  Device-2: DDR5-A2 type: DDR5 detail: synchronous size: 16 GiB
    speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK32GX5M2E6000C36
    serial: N/A
  Device-3: DDR5-B1 type: no module installed
  Device-4: DDR5-B2 type: DDR5 detail: synchronous size: 16 GiB
    serial: N/A
  Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x37
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
    st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
    KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
    desc: 1x25 MiB
  Speed (MHz): avg: 800 min/max: 800/4900:5000:3800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
    active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:4680 class-ID: 0380
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-2,DP-4 empty: DP-3,HDMI-A-3,Writeback-1 bus-ID: 03:00.0
    chip-ID: 1002:747e class-ID: 0300
  Device-3: Microsoft Modern Webcam driver: hid-generic,usbhid,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2
    chip-ID: 045e:0840 class-ID: 0300 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    unloaded: radeon alternate: fbdev,vesa dri: radeonsi,iris gpu: amdgpu
    d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-2 pos: primary,left model: Dell P2722HE serial: <filter>
    built: 2023 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
    chroma: red: x: 0.667 y: 0.325 green: x: 0.310 y: 0.616 blue: x: 0.145
    y: 0.063 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
    640x480, 720x400
  Monitor-2: DP-4 pos: right model: MSI G27C5 serial: <filter> built: 2020
    res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red:
    x: 0.675 y: 0.314 green: x: 0.278 y: 0.643 blue: x: 0.149 y: 0.075 white:
    x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1440x576, 1024x768, 1440x480, 800x600,
    720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: Intel UHD
    Graphics 770 (ADL-S GT1) driver: N/A device-ID: 8086:4680
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.3:5
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 3.19 TiB used: 608.89 GiB (18.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
    model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 731030WD temp: 49.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 36310229 temp: 41.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: BarraCuda 120 SSD
    ZA1000CM10003 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: E014 scheme: GPT
  ID-1: / raw-size: 442.43 GiB size: 434.41 GiB (98.19%)
    used: 21.22 GiB (4.9%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
    label: N/A uuid: 4d8cba3f-f1de-489d-9043-a379e980232c
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
    uuid: 89F0-5AC5
  ID-3: /mnt/1tb raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 143.32 GiB (15.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: cd279156-55e6-4170-9ed9-20ec96c6f73f
  ID-4: /mnt/2tb raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 444.35 GiB (24.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:5
    label: Storage uuid: e67d0afe-6e07-43c4-9331-99a2cc70e3c9
  ID-1: swap-1 type: partition size: 34.22 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3 label: swap
    uuid: 437d48b0-f52a-4811-abe6-b8f279cca70f
  Device-1: 1-4:2 info: Microsoft Modern Webcam type: video,HID
    driver: hid-generic,usbhid,uvcvideo interfaces: 3 rev: 2.0
  Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-6.3:5 info: C-Media Blue Snowball type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-2: 1-6.4:7 info: Primax Alienware 610M type: mouse,keyboard,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 0461:4ec0 class-ID: 0300
  Hub-3: 1-9:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 1-9.1:8 info: NZXT Function Tenkeyless Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1e71:2104 class-ID: 0300 serial: <filter>
  Device-2: 1-11:6 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-3: 1-14:9 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Hub-5: 2-8:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
    chip-ID: 0bda:0411 class-ID: 0900
  System Temperatures: cpu: 39.0 C mobo: 31.2 C gpu: amdgpu temp: 60.0 C
    mem: 72.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1431 libs: 465 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    3: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    10: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    11: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    17: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    22: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    24: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    25: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    26: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    27: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    28: https://mirrors2.manjaro.org/stable/$repo/$arch
    29: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://manjaro.ynh.ovh/stable/$repo/$arch
    31: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    33: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    34: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    36: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    37: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    38: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    39: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    40: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    41: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    42: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    43: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    44: https://mirror.init7.net/manjaro/stable/$repo/$arch
    45: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    46: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    47: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    48: https://mirror.23m.com/manjaro/stable/$repo/$arch
    49: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    50: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    51: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    52: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    53: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    54: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    55: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    56: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    57: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    58: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    59: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    60: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    61: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    62: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 422
  1: cpu: 10.4% command: konsole pid: 8705 mem: 254.9 MiB (0.8%)
  2: cpu: 6.7% command: kwin_wayland pid: 1048 mem: 312.0 MiB (0.9%)
  3: cpu: 6.0% command: Discord pid: 6322 mem: 460.7 MiB (1.4%)
  4: cpu: 5.9% command: brave pid: 6604 mem: 522.9 MiB (1.6%)
  5: cpu: 5.4% command: brave pid: 6661 mem: 263.1 MiB (0.8%)
  Memory top: 5 of 422
  1: mem: 754.8 MiB (2.3%) command: plasmashell pid: 7878 cpu: 5.1%
  2: mem: 522.9 MiB (1.6%) command: brave pid: 6604 cpu: 5.9%
  3: mem: 460.7 MiB (1.4%) command: Discord pid: 6322 cpu: 6.0%
  4: mem: 322.9 MiB (1.0%) command: Discord pid: 6149 cpu: 0.6%
  5: mem: 312.0 MiB (0.9%) command: kwin_wayland pid: 1048 cpu: 6.7%
  Processes: 422 Power: uptime: 40m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.42 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Please let me know if any futher information is required :smiley:
Thank you!
Hello,
I believe the flickering was because I changed the Preferred Ozone platform flag to Wayland in my browser. I reverted it back to default and the flickering seems to have disappeared.
Putting this here in case anyone else is having this issue.
Thank you for your assistance!
