I recently started using Manjaro-i3 with an AMD graphics card. Certain action cause the screen to flicker.
By flickering I mean that a bottom part of the screen (of varying height) is momentarily filled with a solid color. This happens repeatedly very quickly until the X server is restarted.
This flickering is causes by launching a game in fullscreen mode. It either starts immediately or after the game is exited.
Another possible trigger: during watching a fullscreen Youtube video in a browser, xautolock locked the screen due to inactivity, when the screen was unlocked the flickering started.
The system information:
$ inxi -v7azy
Kernel: 5.15.89-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ccbe7454-2b45-4a06-88d9-9e92253f9bd9 rw quiet apparmor=1
security=apparmor resume=UUID=e20b6835-1d13-4165-a1c9-1e2565e4cfc4
udev.log_priority=3
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513IA_D513IA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X513IA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X513IA.306 date: 05/26/2021
ID-1: BAT0 charge: 40.4 Wh (100.0%) condition: 40.4/42.1 Wh (96.0%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
RAM: total: 34.67 GiB used: 5.45 GiB (15.7%)
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1463 high: 1734 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1588
3: 1734 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 bogomips: 31950
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: Picom v: git-b700a driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x15e7 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.89-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek USB 10/100/1G/2.5G LAN type: USB driver: cdc_ncm
bus-ID: 2-1:2 chip-ID: 0bda:8156 class-ID: 0a00 serial: <filter>
IF: enp3s0f3u1c2 state: up speed: 100 Mbps duplex: half mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Local Storage: total: 931.51 GiB used: 34.9 GiB (3.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P2SSD8
lanes: 4 type: SSD serial: <filter> rev: P2CR033 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 16.05 GiB (16.4%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: ccbe7454-2b45-4a06-88d9-9e92253f9bd9
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
label: NO_LABEL uuid: F629-E408
ID-3: /home raw-size: 827.12 GiB size: 813.06 GiB (98.30%)
used: 18.85 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ee81e396-3304-4130-bbaa-5740ae93b9cb
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: e20b6835-1d13-4165-a1c9-1e2565e4cfc4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Logitech USB Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s power: 90mA
chip-ID: 046d:c34b class-ID: 0300
Device-2: 1-4:3 info: Primax 0Y357C PMX-MMOCZUL (B) [Dell Laser Mouse]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d51 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Realtek USB 10/100/1G/2.5G LAN
type: Communication,CDC-Data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s power: 256mA chip-ID: 0bda:8156 class-ID: 0a00
serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 0
Processes: 277 Uptime: 2h 34m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1169 libs: 354 tools: pamac,yay Shell: Bash
v: 5.1.16 running-in: kitty inxi: 3.3.24
