Your posts have been moved to a dedicated topic.
Please note that posting your issue in another member’s topic is not encouraged in this forum, no matter the apparent similarity to your own issue. It is always recommended to create your own Support topic in the appropriate category.
See Forum Rules: Thread Hijacking
Your own Support topic is less congested than Update Announcement threads and should allow others to more easily help with your issue.
Please help others to help you, by providing your system information as described (below) along with any other detail that might be relevant.
I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a
at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
| inxi man pages |
(manual) |
Running `inxi` within a `chroot` environment
- Add
--color=0 to the long-form command, or…
- Change the short-form command to
inxi -zv8c0
Your privacy is respected
Update Announcements
Technical Resources
