That is the right option.
Try restarting.
Restarted still does it.
Can’t see the top edge from your screenshot. Did you disable all the actions from that area?
This is what no edge only window actions enabled on edges should look like:
Shouldn’t the “Maximize” and “Tile” options be unchecked?
Correct
Thanks.
