pretty much what the title says, when i open my lid after closing it and my laptop sleeping, i can see the light on the laptop that indicates it’s awake but the display doesnt turn on at all (not a black screen with the display on)
ive noticed this happened whether my laptop turned off only on battery or plugged in (i maybe wrong about this, not a 100% but i think it happens more when my laptop is plugged in to a/c while waking up, ill keep an eye out); it’s not consistent with when it happens from what ive noticed
some guesses as to what may cause the problem;
- I installed a package to stop my laptop from charging past a certain %
- mesa-nonfree drivers
but i dont think those are the issues since i didn’t notice that problem after i installed them some time ago, the issues started propping up relatively recently
any help is appreciated, thanks
output from running command
“inxi --admin --verbosity=7 --filter --no-host --width”
Kernel: 6.8.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=316507c8-98b0-4f27-8516-f32a2b5f4491 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
serial: <superuser required>
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.04
date: 07/28/2021
ID-1: BAT1 charge: 44.4 Wh (99.8%) condition: 44.5/53.2 Wh (83.6%)
volts: 12.9 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: not charging
System RAM: total: 8 GiB available: 7.12 GiB used: 3.96 GiB (55.7%)
Array-1: capacity: 64 GiB note: check slots: 2 modules: 2 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR4 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 4266 MT/s volts: min: 0.6 max: 0.6
width (bits): data: 32 total: 32 manufacturer: Micron
part-no: MT53E512M32D2NP-046 serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 400 min/max: 400/4372 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 57506
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 37.0 C
Device-2: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b6dd
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
alternate: amdgpu,fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3244x1825
display-ID: 0
Monitor-1: DP-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 1324x745 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-arch10.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.57 6.8.8-1-MANJARO) device-ID: 1002:164c memory: 500 MiB
unified: no display-ID: :1.0
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.8.8-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IP v6: <filter> scope: link
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:5 chip-ID: 04ca:3802
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2
lmp-v: 11 sub-v: 2402 hci-v: 11 rev: 1911 class-ID: 6c010c
Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 476.94 GiB used: 215.38 GiB (45.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 215.38 GiB (46.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 316507c8-98b0-4f27-8516-f32a2b5f4491
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 6E70-0BB3
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 1ed1e8b3-9e58-4b1e-852b-9d1b163fbac3
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-1.2:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-1.2.3:7 info: Apple Aluminium Keyboard (ANSI)
type: keyboard,mouse driver: apple,usbhid interfaces: 2 rev: 2.0
chip-ID: 05ac:024f class-ID: 0301
Device-2: 1-1.2.4:8 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Device-3: 1-1.4:6 info: xxxxxxxx USB Type-C Digital AV Adapter
type: billboard driver: N/A interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 496mA
chip-ID: 343c:0000 class-ID: 1100 serial: <filter>
Device-4: 1-3:3 info: Chicony HD User Facing type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b6dd class-ID: 0e02 serial: <filter>
Device-5: 1-4:5 info: Lite-On Wireless_Device type: bluetooth driver: btusb
interfaces: 3 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 100mA chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-5: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: LighTuning EgisTec EH575 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 1c7a:0575 class-ID: ff00 serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 50.1 C mobo: 34.0 C gpu: amdgpu temp: 38.0 C
Fan Speeds (rpm): N/A
Processes: 385 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 2.83 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1799 libs: 449 tools: pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: yakuake inxi: 3.3.34
