Hello,
I’m having issues with my display after latest update.
I have my TV plugged in as external display with HDMI, Display looks perfect on TV, but looks terrible on my laptop
inxi -Fazy
Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=1f729481-18eb-463d-9a6c-f05f54ad32f1 rw quiet apparmor=1
security=apparmor resume=UUID=7fe7e34f-ee1d-49c6-9ca6-264281a225d1
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80QF v: Lenovo Edge 2-1580
serial: <filter> Chassis: type: 10 v: Lenovo Edge 2-1580 serial: <filter>
Mobo: LENOVO model: Lenovo Edge 2-1580 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: D3CN34WW date: 08/31/2016
ID-1: BAT0 charge: 27.4 Wh condition: 30.8/45.0 Wh (68%) volts: 12.3/11.1
model: SMP L14M3P21 type: Li-poly serial: <filter> status: Charging
Device-1: hid-b8:f6:b1:04:11:c0-battery model: Apple Wireless Keyboard
serial: N/A charge: N/A status: Full
Info: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2
L2 cache: 4 MiB
bogomips: 20810
Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
4: 500
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus ID: 1-5:3
chip ID: 5986:0670 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.0x22.5")
s-diag: 1628mm (64.1")
Monitor-1: eDP1 res: 1680x1050 hz: 60 dpi: 126 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Monitor-2: HDMI1 res: 3840x2160 hz: 30 dpi: 68 size: 1440x810mm (56.7x31.9")
diag: 1652mm (65")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d70
Sound Server: ALSA v: k5.10.7-3-MANJARO
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
bus ID: 02:00.0 chip ID: 8086:24f3
vendor: Lenovo driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
IF-ID-1: br-48195ba776c7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: pan1 state: down mac: <filter>
IF-ID-4: vethadc09ff state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 232.89 GiB used: 136.05 GiB (58.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1B6Q
ID-1: / raw size: 226.56 GiB size: 222 GiB (97.99%) used: 134.94 GiB (60.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 6.03 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 45.0 C mobo: 42.0 C
Processes: 247 Uptime: 45m wakeups: 2 Memory: 7.57 GiB
used: 5.12 GiB (67.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1423 pacman: 1407 lib: 417 flatpak: 0 snap: 16 Shell: Bash
v: 5.1.0 running in: xfce4-terminal inxi: 3.2.02
