Screen color profile does not exist in setting screen
I wanted to import the color profile of my screen but in the screen settings window there is no such option.
My system is:
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.5.0
Qt Version: 6.7.2
Kernel Version: 6.8.12-3-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-4790 CPU @ 3.60GHz
Memory: 15,5 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 4600
Manufacturer: ASUS
my setting windows
other setting window
You have to click that button with the floppy disk icon :point_up:, next to the field for the profile name, and navigate to where you have stored the file with the color profile settings.
OP does not have this button or section. That is the whole reason for the post.
I think this is maybe related to Wayland vs X11.
My memory is a bit fuzzy … but I know the options presented are different between the two.
If no ICC profile loading button thing is there for you then you will almost certainly be able to use
colord-kde (install it … then view/configure the new kcm).
I installed colord-kde also trying to reboot but nothing.
I also found here in the forum that manjaro-settings-manager for kcm does not work on plasma 6:
“Yes, that is correct. The -kcm module for that tool was written for Plasma 5 and qt5, and is not compatible with Plasma 6 and qt6.”
could this be the cause?
No. manjaro settings manager is the GUI frontend for things like mhwd-kernel.
And the kcm is simply that in system settings.
It has nothing to do with color profiles.
What do you mean ‘nothing’?
System Settings > Connected Devices > Color Management
is not there ?
Yes is like before
It cannot be ‘like before’ because it would not be in the same place … try to follow the path as I wrote it.
Yes is not present
As I said not the same section.
Did you really look here?
PS
I just noticed this. Your kernel is EOL.
Your system is not up to date.
In color management at side of device in profiles I found icc import, do you think is for screen?
Yes that is the kcm for color management you said was not there …
As provided by colord-kde
You can import an icc profile using that window.
I try, I did’nt see it before… :frowning_face:
Thanks a lot
and best regards from Italy
Glad we got there. :slight_smile:
