My LENOVO T14s is running MANJARO with kernel 5,15 and allows to set screen brightness using F5 / F6 keys.
I found this and switched to kernel 6.1 or 6.6 where these keys do not change anything.
Any proposal, how to solve this?
Kernel: 5.15.160-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: hpet avail: acpi_pm
root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw apparmor=1
security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01
udev.log_priority=3 acpi_backlight=none
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 20UH001QGE v: ThinkPad T14s Gen 1
Mobo: LENOVO model: 20UH001QGE v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20UH_BU_Think_FM_ThinkPad
T14s Gen 1 uuid: <superuser required> UEFI: LENOVO v: R1CET65W(1.34 )
date: 06/17/2021
ID-1: BAT0 charge: 19.3 Wh (42.7%) condition: 45.2/57.0 Wh (79.3%)
power: 6.8 W volts: 11.3 min: 11.5 model: SMP 5B10W139 type: Li-poly
serial: <filter> status: discharging cycles: 1775
System RAM: total: 32 GiB available: 30.58 GiB used: 3.01 GiB (9.8%)
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATS2G64HZ-3G2B1 serial: N/A
Info: model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1423 high: 1813 min/max: 1400/1700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1433 2: 1813
3: 1396 4: 1396 5: 1397 6: 1398 7: 1397 8: 1397 9: 1366 10: 1397 11: 1397
12: 1397 13: 1397 14: 1397 15: 1397 16: 1395 bogomips: 54318
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
prctl and seccomp
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 46.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:2 chip-ID: 13d3:5405
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14f2 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 17.0.6 DRM 3.42 5.15.160-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.9-manjaro1.1
device-ID: 1002:1636 surfaces: xcb,xlib
