Screen brightness Monitor/OS sync issue
OS brightness and monitor brightness not in sync. The OS 1% seems to be the 32% on the monitor settings. Dimming the brightness to 1% on the monitor works but Manjaro changes it back to 32% when: I press the brightness keyboard key; brightness change on the settings slider or power management slider; and the most annoying, when the OS goes to blank screen / lock screen. I’ve never had this issue before. Making any changes in the settings Power Management seems to not affect the issue.
inxi -Fxxxz         ✔
  Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop Mobo: ASRock model: X570 Steel Legend
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: P5.60 date: 01/18/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master 2S
    status: discharging
  Info: 8-core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP smt: enabled
    arch: Zen 2 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
  Speed (MHz): avg: 3593 min/max: 550/4426 boost: enabled cores: 1: 3593
    2: 3593 3: 3593 4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593
    11: 3593 12: 3593 13: 3593 14: 3593 15: 3593 16: 3593 bogomips: 115038
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: XFX Pine driver: amdgpu v: kernel arch: RDNA-1
    pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2,DP-3,HDMI-A-1 bus-ID: 11:00.0 chip-ID: 1002:731f
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: DP-1 mapped: DisplayPort-0 model: NX-EDG27 serial: <filter>
    res: 2560x1440 hz: 144 dpi: 85 size: 768x432mm (30.24x17.01")
    diag: 686mm (27") modes: max: 2560x1440 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 18.1.8 DRM 3.59 6.11.2-4-MANJARO) device-ID: 1002:731f
  API: Vulkan v: 1.3.295 layers: 9 surfaces: xcb,xlib device: 0
    type: discrete-gpu hw: amd driver: mesa radv device-ID: 1002:731f
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 11:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
    lanes: 16 bus-ID: 13:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Logi Z407 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 bus-ID: 3-4:2 chip-ID: 046d:0a4c
    class-ID: 0102 serial: <filter>
  API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
    type: oss-emulator
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 8086:1539
    class-ID: 0200
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
    v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:2526
    class-ID: 0280
  IF: wlp10s0 state: down mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-3:3 chip-ID: 8087:0025
    class-ID: e001
  Local Storage: total: 5.92 TiB used: 973.58 GiB (16.0%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 002C
    temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
    size: 1.82 TiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 2B2QEXM7 temp: 36.9 C scheme: GPT
  ID-3: /dev/sda vendor: Western Digital model: WD20EZAZ-00GGJB0
    size: 1.82 TiB speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-4: /dev/sdb vendor: Western Digital model: WD Blue SA510 2.5 2TB
    size: 1.82 TiB speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 09WD
    scheme: GPT
  ID-1: / size: 78.19 GiB used: 40.33 GiB (51.6%) fs: ext4 dev: /dev/nvme0n1p3
  ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 1.79 TiB used: 436.18 GiB (23.8%) fs: ext4
    dev: /dev/sdb1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: partition size: 18 GiB used: 0 KiB (0.0%) priority: -3
    dev: /dev/nvme0n1p2
  System Temperatures: cpu: 44.6 C mobo: N/A gpu: amdgpu temp: 55.0 C
    mem: 56.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 724
  Memory: total: 16 GiB available: 15.54 GiB used: 3.67 GiB (23.6%)
  Processes: 394 Power: uptime: 21h 0m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 256 default: graphical
  Packages: 1800 pm: pacman pkgs: 1729 pm: flatpak pkgs: 50 pm: snap
    pkgs: 21 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
