Hello good day, thanks for the update.
BTW I successfully install the update but, I got a small problem, the brightness level is not retained between reboots. After adjusting the brightness level then after reboot on startup the brightness level will go back to around 5 or 10 percent only.
Does anybody experience this or know how to fix it?
Thanks
P.S. My DE is KDE Plasma
Maybe you can give some more information on your system, e.g. CPU/GPU, Kernel, etc. (or just post the output of
inxi --full --verbosity=7 --filter --no-host
if you are unsure).
Personally I noticed that since switching to Kernel 5.8 I’m seeing some issues with the backlight brightness. In that case, you might try to switch back to Kernel 5.7 and see if it helps.
Actually I’m still no 5.7
BTW here is the output
System: Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0
info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: X542UN v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X542UN v: 1.0 serial: <filter> UEFI: American Megatrends v: X542UN.303 date: 01/05/2018
Battery: ID-1: BAT0 charge: 28.6 Wh condition: 29.3/38.0 Wh (77%) volts: 7.6/7.6 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: Not charging cycles: 128
Memory: RAM: total: 15.52 GiB used: 2.54 GiB (16.4%)
CPU: Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 6144 KiB
bogomips: 28808
Speed: 1455 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 1455 2: 1367 3: 1343 4: 1235 5: 1413 6: 1180 7: 1280
8: 1291
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia v: 440.100 bus ID: 01:00.0
chip ID: 10de:1d10
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus ID: 1-6:4 chip ID: 13d3:5a01
serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia resolution: 1: 1920x1080~60Hz
2: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.7.14-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: AzureWave driver: ath10k_pci v: kernel
port: d000 bus ID: 03:00.0 chip ID: 168c:0042
Drives: Local Storage: total: 1.36 TiB used: 621.60 GiB (44.5%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010B7E610 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 1A03 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WDS500G2B0B-00YS70 size: 465.76 GiB speed: 6.0 Gb/s serial: <filter>
rev: 00WD scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XAAM dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 444.61 GiB used: 107.12 GiB (24.1%) fs: ext4 dev: /dev/sdb2 label: N/A
uuid: 0273db2b-978f-4f36-98c3-0c806ebb561f
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 label: N/A uuid: 4E59-1D8D
ID-3: /hgst size: 915.89 GiB used: 514.36 GiB (56.2%) fs: ext4 dev: /dev/sda1 label: N/A
uuid: 9112270e-bbd2-4a4e-b067-dd0045d879fe
ID-4: /run/timeshift/backup raw size: 931.51 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/sda1 label: N/A uuid: 9112270e-bbd2-4a4e-b067-dd0045d879fe
ID-5: /run/user/1000/gc-chromium size: 1.55 GiB used: 120.4 MiB (7.6%) fs: overlay source: ERR-102 label: N/A
uuid: N/A
ID-6: /run/user/1000/gc-firefox-crn5rrqu.default-release size: 1.55 GiB used: 120.4 MiB (7.6%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-7: /run/user/1000/gc-firefox-xcqmtrd0.default size: 1.55 GiB used: 120.4 MiB (7.6%) fs: overlay source: ERR-102
ID-8: /run/user/1000/gc-firefox-z3l2u01j.default-nightly size: 1.55 GiB used: 120.4 MiB (7.6%) fs: overlay
ID-9: /run/user/1000/gc-google-chrome size: 1.55 GiB used: 120.4 MiB (7.6%) fs: overlay source: ERR-102 label: N/A
uuid: N/A
Swap: ID-1: swap-1 type: partition size: 12.75 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3 label: N/A
uuid: 94219b99-6a4e-4419-bf00-d5fa171784d7
Unmounted: Message: No unmounted partitions found.
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: SINO WEALTH Gaming KB type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s chip ID: 258a:002a
Device-2: 1-4:3 info: Elecom M-HT1DRBK HUGE Wireless Optical TrackBall type: Mouse driver: elecom,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s chip ID: 056e:010d
Device-3: 1-6:4 info: IMC Networks USB2.0 VGA UVC WebCam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 13d3:5a01 serial: <filter>
Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 13d3:3496
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Info: Processes: 238 Uptime: 51m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1203 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
pano
18 August 2020 14:58
4
hi, i also have this problem with recent updates.
There is my output, if it helps.
Machine: Type: Laptop System: HUAWEI product: KPL-W0X v: M1D serial: <filter>
Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <filter> UEFI: HUAWEI v: 1.22 date: 02/26/2019
Battery: ID-1: BAT1 charge: 48.3 Wh condition: 53.7/56.3 Wh (95%) volts: 8.4/7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: Discharging cycles: 59
Memory: RAM: total: 6.69 GiB used: 2.03 GiB (30.3%)
CPU: Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
L2 cache: 2048 KiB bogomips: 31949
Speed: 1370 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1462 2: 1577 3: 1368 4: 1368 5: 1368
6: 1369 7: 1484 8: 1372
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Huawei driver: amdgpu v: kernel
bus ID: 02:00.0 chip ID: 1002:15dd
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus ID: 3-1:2 chip ID: 0408:1020
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.37.0 5.7.14-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
driver: snd_hda_intel v: kernel bus ID: 02:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Huawei driver: N/A
bus ID: 02:00.5 chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Huawei driver: snd_hda_intel v: kernel
bus ID: 02:00.6 chip ID: 1022:15e3
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus ID: 01:00.0 chip ID: 8086:24fd
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 238.47 GiB used: 37.49 GiB (15.7%)
ID-1: /dev/sda vendor: LITE-ON model: CV8-8E256 size: 238.47 GiB speed: 6.0 Gb/s serial: <filter> rev: 402
scheme: GPT
Partition: ID-1: / size: 224.77 GiB used: 37.49 GiB (16.7%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: b4dd50dc-d663-4ef7-87bc-9cdfed55a6e3
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 136A-22F8
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 label: N/A
uuid: 07c55121-5b2d-49dc-a945-2981a0fadbc6
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2b
Device-2: 1-3:3 info: Microsoft Xbox360 Controller type: <vendor specific> driver: xpad interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 045e:028e serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-1:2 info: Quanta hm1091_techfront type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 0408:1020
Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 44.4 C mobo: N/A gpu: amdgpu temp: 44 C
Info: Processes: 229 Uptime: 14m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1258 pacman: 1254 flatpak: 4
Shell: Bash v: 5.0.18 running in: terminator inxi: 3.1.05
Maybe it’s a bug in the recent Mesa update or it’s related to KDE, which all of us three seem to use.
I also observe, this will only happen if I have an external monitor during power down.
You should try swapping to 5.8 and see if that actually fixes your issue or not.
I have the same problem, but it’s not just reboot , it’s happend when my laptop wakeup from suspend .
System: Kernel: 5.8.0-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11
Machine: Type: Laptop System: HUAWEI product: HLY-WX9XX v: M1010 serial: <filter>
Mobo: HUAWEI model: HLY-WX9XX-PCB v: M1010 serial: <filter> UEFI: HUAWEI v: 1.12 date: 10/24/2019
Battery: ID-1: BAT1 charge: 54.7 Wh condition: 55.2/55.3 Wh (100%) volts: 17.6/15.3 model: Sunwoda-H HB6081V1ECW-41
type: Li-ion serial: <filter> status: Charging cycles: 50
Memory: RAM: total: 14.65 GiB used: 3.21 GiB (21.9%)
CPU: Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+ rev: 1
L2 cache: 2048 KiB bogomips: 33550
Speed: 2769 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1521 2: 1425 3: 1281 4: 1280 5: 1325
6: 1305 7: 1294 8: 1387
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Huawei driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:15d8
Device-2: IMC Networks type: USB driver: uvcvideo bus ID: 1-4.2:4 chip ID: 13d3:56db serial: <filter>
alternate: fbdev,vesa s-res: 1920x1080 s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.0-2-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5 direct render: Yes
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Huawei driver: snd_hda_intel v: kernel
bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.0-2-MANJARO
Network: Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: & Tele RSH driver: rtw_8822ce v: N/A
port: 2000 bus ID: 02:00.0 chip ID: 10ec:c822
Drives: Local Storage: total: 476.94 GiB used: 74.90 GiB (15.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN720 SDAPNTW-512G-1127 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 10126000 scheme: GPT
Partition: ID-1: / size: 468.16 GiB used: 74.90 GiB (16.0%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 609fc8be-f8bc-4a2f-ad84-518308b16705
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: 5BB4-3E1B
Swap: Alert: No Swap data was found.
Hub: 1-4:2 info: Genesys Logic Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0610
Device-1: 1-4.1:3 info: Shenzhen Goodix Fingerprint Reader type: Communication,CDC-Data driver: N/A interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 27c6:5117
Device-2: 1-4.2:4 info: IMC Networks type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s
chip ID: 1358:c123 serial: <filter>
Sensors: System Temperatures: cpu: 57.5 C mobo: N/A gpu: amdgpu temp: 57 C
Info: Processes: 278 Uptime: 48m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1127 Shell: Zsh v: 5.8
I think brightness level is write into a configfile(like /sys/class/backlight/amdgpu_bl0/brightness), so it’s no bother kernel with brightness right?
Yes I tried but got no luck.
Do you think this is a kernel problem? I even tried install kernel 5.4 with no avail and got same problem.
Luckily I have timeshift installed, did quick restore and just install the latest kernel 5.7 and everything seems fine.
I think it is probably not a kernel issue. Seems to happen on 5.7 as well now for me.
On 5.8 it behaves slightly differently (first adjustment after reboot sets it to minimum, then it works) than on 5.7 (just at maximum after reboot, first adjustment works normally).
But it seems present on both and it coincides with the recent Mesa updates, so maybe it’s related to that?
gilcon
19 August 2020 07:45
11
Anyone tried to check systemctl status systemd-backlight@... service?
I just stumbled about this post FAILED to start Load/Save #ness of backlight:acpi_video0 - Newbie Corner - Manjaro Linux Forum
I can’t test this on my machine right now.
@gilcon
I have been getting this message before the issue appeared and still get it.
gilcon
20 August 2020 03:02
13
I upgrade a few hours ago and it seems to work, didn’t have the issue anymore, if you exclude Mesa from the update.
I still have Mesa 20.1.3-1.
pano
20 August 2020 17:40
14
Hi, i finally get rid of the problem.
In the system settings > energy configuration, i put the desired brightness for my screen and it keeps the level after reboot.
Hope this helps for you.
How do I do that in GNOME?
Anyway, here’s my machine detail
Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
Type: Laptop System: ASUSTeK product: X555QA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X555QA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X555QA.329 date: 05/10/2019
ID-1: BAT0 charge: 9.1 Wh condition: 30.9/38.0 Wh (81%) volts: 7.9/7.9
model: ASUSTeK X555-48 type: Li-ion serial: N/A status: Discharging
cycles: 120
RAM: total: 6.81 GiB used: 3.03 GiB (44.5%)
RAM Report:
Topology: Quad Core model: AMD A12-9720P RADEON R7 12 COMPUTE CORES 4C+8G
bits: 64 type: MCP arch: Excavator rev: 1 L2 cache: 1024 KiB
bogomips: 21564
Speed: 1396 MHz min/max: 1400/2700 MHz boost: enabled Core speeds (MHz):
1: 1558 2: 1712 3: 2115 4: 1947
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vgif
vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: ASUSTeK
driver: amdgpu v: kernel bus ID: 00:01.0 chip ID: 1002:9874
Device-2: IMC Networks type: USB driver: uvcvideo bus ID: 1-1.4:4
chip ID: 13d3:5a11
Display: x11 server: X.org 1.20.8 compositor: gnome-shell
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD Radeon R7 Graphics (CARRIZO DRM 3.37.0
5.7.15-1-MANJARO LLVM 10.0.1)
Device-1: AMD Kabini HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD Family 15h Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:09.2 chip ID: 1022:157a
Sound Server: ALSA v: k5.7.15-1-MANJARO
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: f100 bus ID: 01:00.0
chip ID: 168c:0036
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
Local Storage: total: 1.03 TiB used: 20.68 GiB (2.0%)
ID-1: /dev/sda vendor: V-Gen model: 07SM20AR128SDK 128GB size: 119.24 GiB
speed: 6.0 Gb/s serial: <filter> rev: 3A0 scheme: GPT
ID-2: /dev/sdb vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0J scheme: GPT
ID-1: / size: 116.29 GiB used: 12.38 GiB (10.6%) fs: ext4 dev: /dev/sda2
label: N/A uuid: d8f577c4-ff57-4c6a-bb35-8bd0b628b1bf
ID-2: /boot/efi size: 600.1 MiB used: 300 KiB (0.0%) fs: vfat
dev: /dev/sda1 label: N/A uuid: FCE0-7350
ID-3: /home size: 448.50 GiB used: 8.30 GiB (1.9%) fs: ext4 dev: /dev/sdb5
label: N/A uuid: dce56d89-5e6c-4351-af46-d137d3d3c394
ID-1: /dev/sdb1 size: 260.0 MiB fs: vfat label: SYSTEM uuid: C63A-50AD
ID-2: /dev/sdb2 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-3: /dev/sdb3 size: 466.34 GiB fs: ntfs label: OS uuid: 46063C9B063C8E45
ID-4: /dev/sdb4 size: 800.0 MiB fs: ntfs label: RECOVERY
uuid: 28C632ADC6327B60
ID-5: /dev/sdb6 size: 7.45 GiB fs: swap label: N/A
uuid: a46b2bbc-5b65-4ea4-9b21-e647f32eea15
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 0438:7900
Device-1: 1-1.3:5 info: Lite-On type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 04ca:3010
Device-2: 1-1.4:4 info: IMC Networks type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 13d3:5a11
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub: 2-2:2 info: Super Top 4-Port hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 14cd:8601
Device-1: 2-2.2:3 info: China Resource Semico USB 2.0 Hub
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 1a2c:2d43
Device-2: 2-2.3:4 info: [Maxxter] type: Mouse,Keyboard
chip ID: 18f8:1286
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 70.6 C mobo: N/A gpu: amdgpu temp: 70 C
Fan Speeds (RPM): cpu: 3000
Processes: 263 Uptime: 1h 13m Init: systemd v: 245 Compilers: gcc: 10.1.0
clang: 10.0.1 Packages: pacman: 1261 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
gilcon
25 August 2020 06:12
16
What version of Mesa are you in, when I downgrade to Mesa 20.1.3-1, it fixed the problem, I can just adjust the brightness using the battery widget, without changing it on the system settings.
Tried to downgrade the Mesa to 20.1.3-1, but sadly it does not work on my machine.
I use KDE Plasma too and the screen brightness resets to 1/3 - 1/2 of the maximum brightness after each restart of the laptop. I see that the reset is done just when I press the Enter key in the login form, so the OS starts up well. After I set the brightness to 100% and just log out and log in again the brightness remains 100%.
If it helps to say it, I use a dual-screen configuration and the main screen is the one with lower than usual brightness. Is there a way to configure the brightness level automatically to be 100% at log in / startup?
Thank you!
spinge
8 September 2020 06:16
19
I have the same issue since the last update. My laptop brightness resets to 5% on every startup despite changing it each time.
System: Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.20
info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: GL552JX v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GL552JX v: 1.0 serial: <filter> BIOS: American Megatrends v: GL552JX.209 date: 12/22/2015
Battery: ID-1: BAT0 charge: 41.5 Wh condition: 43.2/48.0 Wh (90%) volts: 15.0/15.0 model: ASUSTeK GL552JX type: Li-ion
Memory: RAM: total: 15.53 GiB used: 1.44 GiB (9.3%)
CPU: Topology: Quad Core model: Intel Core i7-4720HQ bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
bogomips: 41518
Speed: 1061 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 1061 2: 1012 3: 1180 4: 1026 5: 1168 6: 1045 7: 1053
8: 1125
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0416
Device-2: NVIDIA GM107M [GeForce GTX 950M] driver: N/A bus ID: 01:00.0 chip ID: 10de:139a
Device-3: IMC Networks USB2.0 UVC HD Webcam type: USB driver: uvcvideo bus ID: 2-7:5 chip ID: 13d3:5654
serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel resolution: 1: 1920x1080~60Hz 2: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.1.6 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: M-Audio type: USB driver: snd-usb-audio bus ID: 2-3.4:7 chip ID: 0763:4001
Sound Server: ALSA v: k5.4.60-2-MANJARO
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: f040 bus ID: 04:00.0 chip ID: 8086:095a
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 05:00.1 chip ID: 10ec:8168
IF: enp5s0f1 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 520.94 GiB (55.9%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A3J0 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: AS01 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / size: 19.85 GiB used: 15.58 GiB (78.5%) fs: ext4 dev: /dev/sda5 label: N/A
uuid: 24201cbc-e9b5-4d9f-a70e-704d274b73c2
ID-2: /home size: 685.63 GiB used: 461.17 GiB (67.3%) fs: ext4 dev: /dev/sda7 label: N/A
uuid: 73cd34e6-8a30-4a4b-9bd3-623fc1487244
ID-3: /run/media/sp/W10 Data size: 100.00 GiB used: 44.19 GiB (44.2%) fs: ntfs dev: /dev/sda3 label: W10 Data
uuid: CA707FC0707FB1B5
Swap: ID-1: swap-1 type: partition size: 14.04 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6 label: N/A
uuid: 3d0480a6-6119-43dc-826a-ebec1e9be189
Unmounted: ID-1: /dev/sda1 size: 500.0 MiB fs: ntfs label: System Reserved uuid: 3C8CB0218CAFD3A4
ID-2: /dev/sda2 size: 100.00 GiB fs: ntfs label: W10 uuid: CCBE32B8BE329B42
ID-3: /dev/sda4 size: 1 KiB fs: <superuser/root required> label: N/A uuid: N/A
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608
Device-1: 2-3.2:4 info: Dell Dell MS116 Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s chip ID: 413c:301a
Device-2: 2-3.3:6 info: HP USB2.0 Hub type: Printer driver: usblp interfaces: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 03f0:262a serial: <filter>
Device-3: 2-3.4:7 info: M-Audio type: Audio driver: snd-usb-audio interfaces: 4 rev: 1.1 speed: 12 Mb/s
chip ID: 0763:4001
Device-4: 2-5:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2a
Device-5: 2-7:5 info: IMC Networks USB2.0 UVC HD Webcam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 13d3:5654 serial: <filter>
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8000
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1300
Info: Processes: 253 Uptime: 14m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1428 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05
gilcon
8 September 2020 12:33
20
@silviubogan , @spinge try to downgrade mesa to Mesa 20.1.3-1, my problem solve when I downgrade.
Also is systemctl status systemd-backlight@backlight\:intel_backlight.service active?
