Thanks for the fast anwser! I tried what they told on this website. I tried installing the package over the software manager. But this failed. You can see my error message below.
Is more to building/using a custom kernel than might appear at first sight. Always read the documentation/ references to the wiki more than once, so you understand what is what.
You need just the light package and then set the keyboard mapping correctly.
I cant quite keep up. So I went to your webpage. There I read that my package has some depencies. I installed all of them with sudo pacman -S coreutils initramfs …
Then I went back to the software manager and tried to install again. Now this happended:
“Building linux-oled…
==> Making package: linux-oled 5.7.10.arch1-1 (Sa 22 Aug 2020 18:56:28 CEST)
==> Checking runtime dependencies…
==> Checking buildtime dependencies…
==> Retrieving sources…
-> Updating archlinux-linux git repo…
Fetching origin
-> Found config
-> Found sphinx-workaround.patch
-> Found 0001-drm-i915-dp-Program-source-OUI-on-eDP-panels.patch
-> Found 0002-WIP-drm-i915-Enable-Intel-s-HDR-backlight-interface-.patch
==> Validating source files with sha256sums…
archlinux-linux … Skipped
config … Passed
sphinx-workaround.patch … Passed
0001-drm-i915-dp-Program-source-OUI-on-eDP-panels.patch … Passed
0002-WIP-drm-i915-Enable-Intel-s-HDR-backlight-interface-.patch … Passed
==> Verifying source file signatures with gpg…
archlinux-linux git repo … FAILED (unknown public key 3B94A80E50A477C7)
==> ERROR: One or more PGP signatures could not be verified!
Failed to build linux-oled”
I did run your command. It download for a few minute some stuff.
After that i resarted my pc as the console told me to.
Then I tried installing it over the manjaro store as well as the console.
Still same error: “unkown public key”
Hi this unfortunately also didnt work. I still have the same error:
Hi!
Looks like there’s a problem with that gpg, here is a way to fix it
curl -s https://keybase.io/heftig/pgp_keys.asc\ … 8b0d70fc30 | gpg --with-colons --import-options import-show --dry-run --import | grep 3B94A80E50A477C7
