Hi all. I have a Dell Optiplex 7780 (an AIO computer) with integrated Intel graphics card. So far, I am unable to change its brightness, it is always stuck at 100%.
I tried the solution here as well as the ddcci
and i2c-dev
kernel modules (+ several utilities to interact with them: ddcutil
, backlit_control
, brightnessctl
, light
) as partially explained in https://wiki.archlinux.org/index.php/backlight#External_monitors.
I am using Manjaro GNOME with Wayland and Kernel 5.4. I have tried with X11 and with Kernels 5.8, 5.9 and 5.10 and still the same issue.
Do you have any idea? I know that similar AIO computers need some sort of OSD (On-Screen Display) software, but I tried to find something for my particular one, and found nothing.
This is my output for the relevant info (in my opinion) of the inxi -Faz
command:
System: Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=db5cc74f-3469-4916-ab75-4023b69efe8b rw quiet splash
apparmor=1 security=apparmor resume=UUID=38f1480a-218d-419f-8e78-2e2c7500369e udev.log_priority=3
i915.enable_dpcd_backlight=0
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Manjaro Linux
Machine: Type: Desktop System: Dell product: OptiPlex 7780 AIO v: N/A serial: <filter> Chassis: type: 13 serial: <filter>
Mobo: Dell model: 04G47W v: A00 serial: <filter> UEFI: Dell v: 1.3.0 date: 10/06/2020
Graphics: Device-1: Intel vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9bc5
Device-2: Sunplus Innovation Integrated_Webcam_FHD type: USB driver: uvcvideo bus ID: 1-10:3 chip ID: 1bcf:2b9b
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CML GT2) v: 4.6 Mesa 20.3.2 direct render: Yes
Of course I will provide the output of any command at your request. Thanks a lot. Appreciated,
Jordi.
