Yesterday I decided to install kernel version 5.19.7-1-MANJARO. After two hours of using the computer, I rebooted it due to lags. After a reboot, xfce stopped running.
These are all the messages that I saw at startup:
/dev/sda1: clean, 1627541/61054976 files, 75107376/244189752 blocks
[FAILED] Failed to start Load/Save Screen Backlight Brightness of leds:dell::kbd
After them, the cursor blinks on a blank screen.
Please help because this is the first time I’ve encountered this error.
so try clearing some space, run this: sudo pacman -Scc
run again: startx and see if it helped
if not, are the any logs on the screen when you run startx? if yes take a picture of them
[ 8474.272]
X.Org X Server 1.21.1.4
[ 8474.272] Current Operating System: Linux konstantin-inspiron5558 5.19.7-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Sep 5 10:16:57 UTC 2022 x86_64
[ 8474.272] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=b9f551cf-2a5d-4966-bcaa-70c45cb02b43 rw quiet udev.log_priority=3
[ 8474.272]
[ 8474.272] Current version of pixman: 0.40.0
[ 8474.272] Before reporting problems, check http://wiki.x.org
[ 8474.272] Markers: (--) probed, (**) from config file, (==) default setting,
[ 8474.273] (==) Log file: "/home/konstantin/.local/share/xorg/Xorg.0.log", Time: Wed Oct 5 18:26:31 2022
[ 8474.273] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 8474.273] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8474.273] (==) No Layout section. Using the first Screen section.
[ 8474.273] (==) No screen section available. Using defaults.
[ 8474.273] (**) |-->Screen "Default Screen Section" (0)
[ 8474.273] (**) | |-->Monitor "<default monitor>"
[ 8474.273] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 8474.273] (**) | |-->Device "Device0"
[ 8474.273] (==) No monitor specified for screen "Default Screen Section".
[ 8474.273] (==) Automatically adding devices
[ 8474.273] (==) Automatically enabling devices
[ 8474.273] (==) Automatically adding GPU devices
[ 8474.273] (==) Automatically binding GPU devices
[ 8474.273] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8474.273] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 8474.273] Entry deleted from font path.
[ 8474.273] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8474.273] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8474.273] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8474.273] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 8474.273] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 8474.273] (**) Extension "Composite" is enabled
[ 8474.273] (**) Extension "RENDER" is enabled
[ 8474.274] (II) The server relies on udev to provide the list of input devices.
[ 8474.274] (II) Module ABI versions:
[ 8474.274] X.Org ANSI C Emulation: 0.4
[ 8474.274] X.Org Video Driver: 25.2
[ 8474.274] X.Org XInput driver : 24.4
[ 8474.274] X.Org Server Extension : 10.0
[ 8474.275] (++) using VT number 2
[ 8474.276] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 8474.277] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8474.277] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 8474.277] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 8474.279] (--) PCI:*(0@0:2:0) 8086:1616:1028:06ae rev 9, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 8474.279] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 8474.279] (II) LoadModule: "glx"
[ 8474.279] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8474.281] (II) Module glx: vendor="X.Org Foundation"
[ 8474.281] compiled for 1.21.1.4, module version = 1.0.0
[ 8474.281] ABI class: X.Org Server Extension, version 10.0
[ 8474.281] (II) LoadModule: "vesa"
[ 8474.281] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 8474.281] (II) Module vesa: vendor="X.Org Foundation"
[ 8474.281] compiled for 1.21.1.3, module version = 2.5.0
[ 8474.281] Module class: X.Org Video Driver
[ 8474.281] ABI class: X.Org Video Driver, version 25.2
[ 8474.281] (II) VESA: driver for VESA chipsets: vesa
[ 8474.281] xf86EnableIO: failed to enable I/O ports 0000-03ff (Operation not permitted)
[ 8474.281] vesa: Refusing to run, Framebuffer or dri device present
[ 8474.281] (EE) No devices detected.
[ 8474.281] (EE)
Fatal server error:
[ 8474.281] (EE) no screens found(EE)
[ 8474.281] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 8474.281] (EE) Please also check the log file at "/home/konstantin/.local/share/xorg/Xorg.0.log" for additional information.
[ 8474.281] (EE)
[ 8474.291] (EE) Server terminated with error (1). Closing log file.
Remembered!
I also decided to install the hardware drivers in the Manjaro Settings Manager, and installed the latest drivers for video-linux, video-modesettings and video-vesa.
Could this affect the launch of the interface?
You really do not need those, and video-vesa most likely is not helping your system because is a generic fallback driver which should not be used in the vast majority of cases.
