Scrcpy install on RP4 KDE Plasma
I recently came across Scrcpy while trying TwisterOS on my RP4and cannot find any instructions as to how to install this on Manjaro.
I have done a search in Add/Remove software but nothing is showing up, my knowledge of the OS is limited. I think I did successfully launch an install via it’s Github Repository but got a message about it not being available for the architecture.
It’s in the AUR.
When installing, just change the arch=() line to include aarch64 and it should build and install just fine.
One issue you might have though, is the android-tools dependency. Not sure it’s available.
Thank you installed and seems to be working fine. I’ll update if I hit any issues
Regards
