Hello, how do I quarantine infected files with ClamAV after I scan my system using clamscan -r /
Is there a clamscan command to quarantine the infected files and then alert me?
Output to inxi --admin --verbosity=7 --filter --no-host --width
is:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=41b5e77f-aea6-4e67-93a5-664479adb001 rw quiet
cryptdevice=UUID=77b502ae-f416-426b-aedc-de4e854f3e72:luks-77b502ae-f416-426b-aedc-de4e854f3e72
root=/dev/mapper/luks-77b502ae-f416-426b-aedc-de4e854f3e72 apparmor=1
security=apparmor
resume=/dev/mapper/luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 82DQ v: Lenovo V14-ARE serial: <filter>
Chassis: type: 10 v: Lenovo V14-ARE serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697WIN serial: <filter>
UEFI: LENOVO v: DZCN33WW date: 09/24/2020
ID-1: BAT0 charge: 32.1 Wh condition: 33.3/35.3 Wh (94%) volts: 8.5/7.6
model: CPT-COS L16C2PB1 type: Li-poly serial: <filter> status: Unknown
cycles: 6
RAM: total: 7.21 GiB used: 5.28 GiB (73.3%)
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 L2 cache: 3 MiB bogomips: 28454
Speed: 1397 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 3986 5: 1774 6: 1774
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:1636 class ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:4
chip ID: 04f2:b624 class ID: 0e02 serial: <filter>
Device-3: DisplayLink ASUSTEK MB169B+ type: USB driver: usbfs bus ID: 4-1:2
chip ID: 17e9:ff0b class ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: DVI-I-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637 class ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2 class ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus ID: 01:00.0
chip ID: 168c:003e class ID: 0280
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
bus ID: 3-3:3 chip ID: 0cf3:e300 class ID: e001
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus ID: 3-3:3 chip ID: 0cf3:e300 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 853.2 GiB used: 393.81 GiB (46.2%)
model: PC SN520 SDAPMUW-256G-1101 size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD
serial: <filter> rev: 20290001 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 90WD scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC MS PRO
size: 119.08 GiB block size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 1.00 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Flash Drive FIT size: 29.88 GiB block size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%)
used: 82.35 GiB (36.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-77b502ae-f416-426b-aedc-de4e854f3e72 label: N/A
uuid: 41b5e77f-aea6-4e67-93a5-664479adb001
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 02D5-A444
ID-3: /home/<filter>/pCloudDrive raw size: N/A size: 8 GiB
used: 251.4 MiB (3.1%) fs: fuse source: ERR-102 label: N/A uuid: N/A
ID-4: /media/SystemBackup raw size: 232.83 GiB size: 228.18 GiB (98.00%)
used: 110.31 GiB (48.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: SystemBackup uuid: fe8f544c-218e-473c-b9f1-9dd7377320ff
ID-5: /run/media/noah/VirtualBoxETC raw size: 232.93 GiB
size: 228.27 GiB (98.00%) used: 200.05 GiB (87.6%) fs: ext4 dev: /dev/sda2
maj-min: 8:2 label: VirtualBoxETC uuid: e8075768-a6e2-4484-9437-be58ae3505fa
ID-6: /run/media/noah/writable raw size: 27.41 GiB size: 26.86 GiB (97.97%)
used: 46.1 MiB (0.2%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35 label: writable
uuid: ede1fb28-ab65-41f7-8bd9-1f7127509ed9
ID-7: /run/timeshift/backup raw size: 232.83 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.8 GiB used: 827.2 MiB (9.2%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 label: N/A
uuid: a3c4745a-3fbd-40e1-9d38-a4bb513d2d09
ID-1: /dev/sdb1 maj-min: 8:17 size: 119.07 GiB fs: exfat label: Backup
uuid: 3534-6433
ID-2: /dev/sdc1 maj-min: 8:33 size: 2.46 GiB fs: iso9660
label: Kubuntu 20.04.2.0 LTS amd64 uuid: 2021-02-09-19-24-16-00
ID-3: /dev/sdc2 maj-min: 8:34 size: 3.9 MiB fs: vfat label: N/A
uuid: 54C5-9C6C
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 248a:8367 class ID: 0301
Hub-2: 1-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2813 class ID: 0900
Device-1: 1-3:4 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b624 class ID: 0e02
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 2-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 2109:0813 class ID: 0900
Device-1: 2-2.4:3
info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
chip ID: 090c:1000 class ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Realtek USB2.0-CRW type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:0177 class ID: 0806 serial: <filter>
Device-2: 3-3:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0cf3:e300
class ID: e001
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: DisplayLink ASUSTEK MB169B+ type: Video driver: usbfs
interfaces: 2 rev: 3.2 speed: 5 Gb/s chip ID: 17e9:ff0b class ID: fe01
serial: <filter>
System Temperatures: cpu: 67.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 335 Uptime: 18h 31m wakeups: 3 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 1523 pacman: 1505 lib: 424 flatpak: 7
snap: 11 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
