I have just realized that my scanner tools not working anymore
by open simple-scan I get this:
❯ simple-scan --debug
[+0.00s] DEBUG: simple-scan.vala:2015: Starting simple-scan 44.0, PID=674169
[+0.00s] DEBUG: unsetenv() is not thread-safe and should not be used after threads are created
[+0.06s] WARNING: Using GtkSettings:gtk-application-prefer-dark-theme together with HdyStyleManager is unsupported. Please use HdyStyleManager:color-scheme instead.
[+0.25s] DEBUG: _g_io_module_get_default: Found default implementation dconf (DConfSettingsBackend) for ‘gsettings-backend’
[+0.28s] DEBUG: app-window.vala:2002: Loading state from /home/shaderico/.config/simple-scan/state
[+0.28s] WARNING: scanner.vala:1739: Unknown ScanType: . Please report this error.
[+0.28s] DEBUG: app-window.vala:1981: Restoring window to 600x400 pixels
[+0.31s] DEBUG: scanner.vala:1619: sane_init () -> SANE_STATUS_GOOD
[+0.31s] DEBUG: scanner.vala:1625: SANE version 1.2.1
[+0.31s] DEBUG: scanner.vala:1686: Requesting redetection of scan devices
[+0.31s] DEBUG: scanner.vala:863: Processing request
bugchk_free(ptr=(nil))@modelinf.c(464)
zsh: IOT instruction (core dumped) simple-scan --debug
and
by open xsane I get this:
❯ xsane
zsh: IOT instruction (core dumped) xsane
• I try to go from pamac-gtk
to pamac-gtk3
, tried the Adwaita
theme and reinstall xsane
and simple-scan
inxy
Kernel: 6.5.1-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A
serial: <superuser required>
Mobo: Dell model: 0D0T05 v: A00 serial: <superuser required> UEFI: Dell
v: 1.31.0 date: 03/13/2023
ID-1: BAT0 charge: 37.9 Wh (100.0%) condition: 37.9/97.0 Wh (39.1%)
Info: 6-core model: Intel Core i7-8750H bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 3758 min/max: 800/4100 cores: 1: 3900 2: 3906 3: 3900
4: 3899 5: 3900 6: 3900 7: 3900 8: 3900 9: 2200 10: 3900 11: 3900 12: 3900
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 535.104.05
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
API: OpenGL v: 4.6 Mesa 23.1.6-3 renderer: Mesa Intel UHD Graphics 630
(CFL GT2)
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
API: ALSA v: k6.5.1-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.79 status: active
Device-1: Intel Wireless-AC 9260 driver: iwlwifi
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: pan1 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: <filter> bt-v: 5.1
Local Storage: total: 1.82 TiB used: 1.6 TiB (88.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
ID-1: / size: 1.79 TiB used: 1.6 TiB (89.5%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 256 MiB used: 220 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 21.7 GiB used: 9.7 GiB (44.7%) file: /swapfile
System Temperatures: cpu: 78.0 C pch: 54.0 C mobo: 58.0 C
Fan Speeds (rpm): cpu: 3685 fan-2: 3695
Processes: 520 Uptime: 7h 3m Memory: total: 32 GiB note: est.
available: 30.98 GiB used: 10.43 GiB (33.7%) Shell: Zsh inxi: 3.3.29
