Scanner Epson XP-6105 won't work
Hi all, i have tried everything but this scanner won’t work. Simple-scan don’t see it. Work’s only with imagiscan utsushi but I don’t like the GUI and it’s not possible to scan many sheets in sequence. I wanna use simple scan.
Anyway, some info…
sane-find-scanner
Riepilogo
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x1058/0x2621 at 002:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0003 at 002:001: Access denied (insufficient permissions)
could not fetch string descriptor: Pipe error
found USB scanner (vendor=0x04b8, product=0x114c) at libusb:001:004
could not open USB device 0x248a/0x00da at 001:003: Access denied (insufficient permissions)
could not open USB device 0x3938/0x1031 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0a2a at 001:006: Access denied (insufficient permissions)
could not open USB device 0x058f/0x6390 at 001:005: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
You may want to run this program as root to find all devices. Once you
found the scanner devices, be sure to adjust access permissions as
necessary.
scanimage -L
Riepilogo
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
lsusb
Riepilogo
Bus 002 Device 002: ID 1058:2621 Western Digital Technologies, Inc. Elements 2621
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04b8:114c Seiko Epson Corp. XP-6100 Series
Bus 001 Device 003: ID 248a:00da Maxxter Wireless Receiver
Bus 001 Device 002: ID 3938:1031 MOSART Semi. 2.4G Wireless Mouse
Bus 001 Device 006: ID 8087:0a2a Intel Corp. Bluetooth wireless interface
Bus 001 Device 005: ID 058f:6390 Alcor Micro Corp. USB 2.0-IDE bridge
gedit /etc/sane.d/dll.conf
Riepilogo
dll.conf - Configuration file for the SANE dynamic backend loader
Backends can also be enabled by configuration snippets under the dll.d/
directory – third party backends can drop their configuration file in
this in this directory, named after the backend.
The next line enables the network backend; comment it out if you don’t
need to use a remote SANE scanner over the network – see sane-net(5)
and saned(8) for details.
net
abaton
agfafocus
apple
artec
artec_eplus48u
as6e
avision
bh
canon
canon630u
canon_dr
canon_lide70
#canon_pp
cardscan
coolscan
#coolscan2
coolscan3
#dc210
#dc240
#dc25
dell1600n_net
dmc
epjitsu
epson
epson2
epsonds
epkowa
escl
fujitsu
genesys
#gphoto2
gt68xx
hp
hp3500
hp3900
hp4200
hp5400
hp5590
hpljm1005
hpsj5s
hs2p
ibm
kodak
kodakaio
kvs1025
kvs20xx
kvs40xx
leo
lexmark
ma1509
magicolor
microtek
microtek2
mustek
#mustek_pp
mustek_usb
mustek_usb2
nec
niash
#p5
pie
pieusb
pint
pixma
plustek
#plustek_pp
#pnm
qcam
ricoh
ricoh2
rts8891
s9036
sceptre
sharp
sm3600
sm3840
snapscan
sp15c
#st400
#stv680
tamarack
teco1
teco2
teco3
#test
u12
umax
umax1220u
#umax_pp
#v4l
xerox_mfp
gedit /etc/sane.d/epson2.conf
Riepilogo
epson2.conf
here are some examples for how to configure the EPSON2 backend
SCSI
scsi EPSON
for the GT-6500:
#scsi “EPSON SC”
Parallel port
#pio 0x278
#pio 0x378
#pio 0x3BC
USB
usb
For libusb support for unknown scanners use the following command
usb
e.g.:
usb 0x4b8 0x110
Network
net 192.168.1.123
net autodiscovery
gedit /etc/sane.d/epkowa.conf
Riepilogo
epkowa.conf – sample configuration for the EPKOWA SANE backend
Copyright (C) 2004, 2008, 2009 Olaf Meeuwissen
See sane-epkowa(5), sane-usb(5) and sane-scsi(5) for details.
Detect all devices supported by the backend.
If you don’t have a SCSI device, you can comment out the “scsi”
keyword. Similarly for the other keywords.
usb
scsi
For any USB scanner not known to the backend (yet), you may, at your
own peril(!!), force the backend to recognise and use it via libusb.
You can do so by the following configuration command:
usb
SEIKO EPSON’s USB vendor ID is ‘0x04b8’ (without quotes). In order
to find the USB product ID, use lsusb(1).
A sample configuration for the Epson Perfection 1650 (Epson GT-8200),
which has a product ID of 0x0110, would look as follows:
usb 0x04b8 0x0110
For SCSI devices not detected, you can add an entry like:
scsi EPSON GT-20000
where the GT-20000 bit corresponds to the SCSI model information as
shown in the output of dmesg(1) or in the /var/log/kern.log file.
Network attached devices may be made to work by first installing the
(non-free) iscan-network-nt package and then adding configuration lines
as per information below.
For each network attached device, you must add an entry as follows:
net <IP-address|hostname> [port-number]
Ask your network administrator for the device’s IP address or check
for yourself on the panel (if it has one). The port-number is very
optional and defaults to 1865.
Note that network attached devices are not queried unless configured
in this file.
Examples:
#net 192.16.136.2 1865
#net 10.0.0.1
#net scanner.mydomain.com
Some backend behaviour can be customized by using the option keyword
followed by an option name, as shown below.
option
Currently available options:
Makes the automatic document feeder the default document source
#option prefer-adf
Thanks in advance
Solved the problem
The scanner support the AirPrint protocol, you can just install ipp-usb
sudo pacman -S ipp-usb
sudo systemctl enable --now ipp-usb.service
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
