SbK Xfce-Compiz 24.0.0
I am very happy to announce the release of SbK Xfce-Compiz 24.0.0.
  1. The 6.6.30 LTS kernel.
  2. Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
  3. The New KoraSpin-Lime9 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-24.0.0 package that includes all colors in the series.
  4. The new SpinThemeLime12 matching Gtk and Kvantum themes in one package.
  5. The new Usplash-24.0.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
  6. A basic Conky with matching color theme.
  7. The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
  8. The iso’s are up to date as of 5/19/2024.
  9. An optional Firefox theme, SbK Dark Lime12, that matches the color scheme is available here, Firefox Themes just click on the image in Firefox to install it.
  1. The latest LTS kernel.
  2. A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed. AUR packages are not supported by Arch or Manjaro.
  3. It is multiarch by default to make running wine games and other 32bit software you may run easier.
  4. The Spins by Kilz signed repository is enabled for SbK project packages.
  5. A signed iso. For information on checking signed iso’s visit Check ISO. Check ISO
  6. Bloatware has been removed (HP printer software and others).
  7. Flat packs and snaps are not installed. The back ends are also not installed but can be installed by the user.
  8. All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. To get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
  9. Timeshift autosnap installed. It takes a snapshot before upgrading so any bad upgrades can be easily reversed.
Jim
