I am very happy to announce the release of SbK Xfce-Compiz 22.1.0.
- The 5.15.105 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New KoraSpin-Purple3 icon theme with light and dark versions of the control icons. It is part of the KoraSpin-22.1.0 package.
- The new SpinThemeDarkPurple5 matching Gtk and Kvantum themes in one package.
- The new Usplash-22.1.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
- The iso’s are up to date as of 4/7/2023.
- An optional Firefox theme, SbK Dark Purple5, that matches the color scheme is available at https://spins.tuxfamily.org/ffthemes.html just click on the image in Firefox to install it.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK http://spins.tuxfamily.org/repo.html after install.
Jim
Normally I wouldnt have a problem with releasing on Sunday, but tomorrow is Easter and I wont be home. Cinnamon will likely be released on Monday.
