SbK Xfce-Compiz 21.2.1 release
I am very happy to announce the release of SbK Xfce-Compiz 21.2.1.
This spin is the first release to move to the 5.15 kernel since I found out it is the newest LTS kernel.
  1. The 5.15.12 LTS kernel.
  2. Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
  3. The New FlatRemixSpin-Red2 icon theme with light and dark versions of the control icons.
  4. The new SpinThemeDarkRed5 matching Gtk and Kvantum themes in one package.
  5. The new Usplash-21.2.1 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
  6. A basic Conky with matching color theme.
  7. The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
  8. The iso’s are up to date as of 1/9/2022.
  9. Minimize and maximise controls return, they were missing on some windows in 21.2.0.
  1. The latest LTS kernel.
  2. A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
  3. It is multiarch by default to make running wine games and other 32bit software you may run easier.
  4. The Spins by Kilz signed repository is enabled for SbK project packages.
  5. A signed iso. For information on checking signed iso’s visit Checking
  6. Bloatware has been removed (HP printer software and others).
  7. Flat packs and snaps are not installed. The back ends are also not installed but can be installed by the user.
  8. All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install.
  9. Timeshift autosnap installed. It takes a snapshot before upgrading so any bad upgrades can be easily reversed.
Jim
Housekeeping … no activity …
