I am happy to announce the release of SbK Xfce-Compiz 21.2.0. I think its one of the best SbK Xfce releases to date.
The Xfce desktop had theme work on the Thunar file manager to match the rest of the applications. The places sidebar is now the same color as the top of the window. Hover and select highlights now work correctly on the places sidebar.
- The 5.10.79 LTS kernel.
- Compiz 9 with the rotating cube for virtual desktops, faded windows in the background, wobbly windows, and other effects.
- The New FlatRemixSpin-Lemon icon theme with light and dark versions of the control icons.
- The new KvSpinDarkLemon matching Gtk and Kvantum themes in one package.
- The new Usplash-21.2.0 desktop wallpapers. One of them is the background for the grub, desktop, and login screen backgrounds.
- The menu icon in the dock is the Xfce mouse icon and it is color matched to the other themes.
- Lots of updates since the 21.1.5 release. The iso’s are up to date as of 11/22/2021.
- The latest LTS kernel.
- A Manjaro stable install that is also AUR compatible. In the full iso there are also a lot of packages used to build packages installed.
- A signed iso. For information on checking signed iso’s visit https://spins.tuxfamily.org/check.html
- All SbK iso’s contain Manjaro Architect script in case you want to do a custom install. Sadly to get any SbK packages like themes, icons, and other goodies you will have to add the SbK Repository after install. http://spins.tuxfamily.org/repo.html
Jim
